cabin heat cables where and how?
pascal(at)rv10builder.net
PostPosted: Sat Sep 27, 2008 8:36 pm    Post subject: cabin heat cables where and how? Reply with quote
I can't locate where in the plans it tells one how to run cables for the cabin heat. I see under Section 27 to bolt the Vents but other than the AN3-3A setup there is nothing for the brackets nor cables or anything else.
Any feedback on this is appreciated!
Pascal
dlm46007(at)cox.net
PostPosted: Sat Sep 27, 2008 9:10 pm    Post subject: cabin heat cables where and how? Reply with quote
The firewall forward runs are in FF1-3. the inside runs are user choice. Mine are two knobs on the right side of the throttle quadrant. see picture
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal
Sent: Saturday, September 27, 2008 9:36 PM
To: rv10-list
Subject: cabin heat cables where and how?
Pascal
 Filesize:  543.45 KB
 Viewed:  372 Time(s)
AirMike
PostPosted: Sun Sep 28, 2008 1:56 pm    Post subject: cabin heat cables where and how? Reply with quote
Note - do not do a permanent install till your panel is all ready to install as the heater cables have to be removed and run thru the hole in the bracket or panel.
See you OSH '18
Q/B - sold.
