Fuses or Cuircut Breakers.... Which are you using.
Gig Giacona
PostPosted: Thu Sep 25, 2008 7:59 am    Post subject: Fuses or Cuircut Breakers.... Which are you using. Reply with quote
OK I'm at that point. What have you installed or are planing to install in your plane.
W.R. "Gig" Giacona
601XL Under Construction
steerr(at)bellsouth.net
PostPosted: Thu Sep 25, 2008 9:04 am    Post subject: Fuses or Cuircut Breakers.... Which are you using. Reply with quote
I installed a modified version of Aeroelectric Connection Figure Z-1,
which uses a two-buss design with fuses. My plane is single battery and
a Stratus Subaru engine, so it has an external alternator. No magnetos,
so I obviously removed those from the figure. I also included an
overvoltage crowbar available from B&C. I can send you the ExpressSCH
file if it would help.
DaveG601XL
PostPosted: Thu Sep 25, 2008 10:20 am    Post subject: Re: Fuses or Cuircut Breakers.... Which are you using. Reply with quote
Gig,
As you probably know by now, you will find as many opinions as people on this often debated topic. The Aeroelectric list on this same Matronics forum has had a lot of discussions on this.
Everything on my 601XL is fuses except for the alternator, flaps, trim and starter (i.e. things with windings) My fuse box hinges under the instrument panel so it is out of the way, yet accessible. Attached is a pic of me accessing the fuse panel.
I used a hybrid of Nucholls's Z-16and Z-20 schematics for an overall design. It has working out well for 32.0 hours of flight so far.
Good luck,
 Filesize:  226.15 KB
 Viewed:  248 Time(s)
David Gallagher
Cincinnati, OH area
annken100
PostPosted: Thu Sep 25, 2008 6:38 pm    Post subject: Re: Fuses or Cuircut Breakers.... Which are you using. Reply with quote
Gig,
I used Klixon circuit breakers for everything. Like Dave mentions above, you will find all sorts of opinions and justifications for fuses and breakers. Both work and I think it comes down to how much you want to spend, 17.00 per circuit breaker or 0.50 a fuse.
Ken
601 XL / Corvair
