corbob13
Posted: Mon Sep 29, 2008 4:42 pm Post subject: Gearbox wear |
Guys (especially Dave),
My plane's in for annual and my A&P is hesitating to sing the book because of an issue with the gearbox. When he drained the lube he noticed a lot of very fine metal particles in it. He's also worried about the amount of backlash in the gears. I thought the backlash was a little much but since I've only got a few hours on my engine from an overhaul I've ignored it. He compared the amount of backlash to other planes on the field with similar setups and found the others to have little to no backlash in the gear sets.
I spoke to LEAF, who did the overhaul, and they said it was normal, both the metal and the backlash. I asked at what level the backlash should be a concern, but they said there was no limit.
What kind of experiences have other had with their gearboxes? Do you see any amount of metal particles in the gear oil? How about backlash? I have a 582 model 90 with a "B" box.
_________________ Cory
N903DB
Kitfox Model II, Rotax 582 |
paul(at)eucleides.com Guest
Posted: Mon Sep 29, 2008 7:04 pm Post subject: Gearbox wear |
On Mon, September 29, 2008 5:42 pm, corbob13 wrote:
there was no limit.
Visible metal would sure concern me. Here's a suggestion. Phone
Green Sky Adventures, Inc. of North Central Florida
Toll free 888 887-5625 Cell 352 318-5625 or Email gsastaff(at)orwell.net
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Guy Buchanan
Posted: Mon Sep 29, 2008 10:11 pm Post subject: Gearbox wear |
At 05:42 PM 9/29/2008, you wrote:
| Quote: | What kind of experiences have other had with their gearboxes? Do
Cory,
Backlash and metal in the oil go together. That's a bad
sign. You may be chewing your gears. I'd pull it apart since it's
almost trivial to do so. I notice, however, that the B has a spring
actuated dog system between the drive gear and prop hub, so I can
understand LEAFs telling you that metal particulate was normal. It
may be that it's the dog that's worn and causing the backlash, and
not the gear, or the spring has failed or is otherwise not providing
sufficient pressure.
How many hours total on the gearbox? I doubt LEAF did
anything at all to the gearbox during the rebuild, so you're probably
operating on the original time.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
msm_9949(at)yahoo.com Guest
Posted: Tue Sep 30, 2008 6:27 am Post subject: Gearbox wear |
Hi Cory.
I have the 3:1 C-Box. Only issue I've had was "slippage" which produced a really scary over-rev condition. Fortunately, this was on the ground while doing a break-in run-up. Turns out there was a service bulletin on that so the box came off and went to LEAF for repair/upgrade. No problems since, either with backlash or making metal.
Marco Menezes N99KX
Kitfox 2 582-90 C-Box 3:1
--- On Mon, 9/29/08, corbob13 <corbob13(at)netnet.net> wrote:
| Quote: | From: corbob13 <corbob13(at)netnet.net>
Subject: Gearbox wear
Date: Monday, September 29, 2008, 8:42 PM
| Quote: | --> Kitfox-List message posted by: "corbob13"
sets.
Cory
N903DB
http://forums.matronics.com/viewtopic.php?p 6841#206841
