Altimeter Question
peteohms
PostPosted: Thu Sep 25, 2008 1:05 pm    Post subject: Altimeter Question Reply with quote
When I fly my Kitfox III with the vents open, I get about a 200' error in altitude reading compared to my GPS reading. I suppose this is common when the static pickup is inside the cabin. I set my altimeter to the GPS reading and forget it. Any problems with this solution?
Pete
Hell Paso, TX
III SN1000
912
Pete
Leander, TX
Kitfox III, 912ul, Grove
Michel
PostPosted: Thu Sep 25, 2008 1:34 pm    Post subject: Altimeter Question Reply with quote
From: Pete Christensen [apeterchristensen(at)sbcglobal.net]
Oops! First, yes Pete, the pressure inside the cockpit varies a lot. A static port going aft of the fuselage is best. Secondly, the GPS altitude reading is seldom accurate to 200 ft. If you think of the geometry of the GPS satellites; the angle between them and then their relatively low altitude (angle) in relation to you, you understand that the Y axis (altitude) is less accurate than the X,Z (latitude, longitude) axis. I contribute to PocketFMS, a GPS based moving map and flight planner software and e.g. an ILS function is out of question: a glide slope to some accuracy can't be assessed.
Incidentally, when I installed a Jabiru, instead of the old 582 on my model 3, I saw such a lower pressure in the cockpit that I was forced to install a static port. I am not sure why but it looks like the vacuum chamber I created under the cowling was affecting the cockpit too.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as a PAX
pwmac(at)sisna.com
PostPosted: Thu Sep 25, 2008 2:12 pm    Post subject: Altimeter Question Reply with quote
Not really. The best air speed would result from a properly designed
piton- static device. The only disadvantage is one has to run two
lines to the panel. Anybody who still had the wings uncovered should
give this method strong consideration. Error on a pitot static is the
lowest of any compared to any other method.
Not as sensitive to yaw or pitch within reason.
Paul
error in altitude
Michel Verheughe
Norway
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronics.com/Navigator?Kitfox-List</a>
href="http://forums.matronics.com">http://forums.matronics.com</a>
href="http://www.matronics.com/contribution">http://www.matronics.com/contribution</a>
</b></font></pre>
Tom Jones
PostPosted: Thu Sep 25, 2008 3:03 pm    Post subject: Re: Altimeter Question Reply with quote
[quote="peteohms"]When I fly my Kitfox III with the vents open, I get about a 200' error in altitude reading compared to my GPS reading. I suppose this is common when the static pickup is inside the cabin. I set my altimeter to the GPS reading and forget it. Any problems with this solution?
Pete
Hell Paso, TX
III SN1000
912
[quote][b][/quote
Tom Jones
Classic IV
Ellensburg, WA
peteohms
PostPosted: Thu Sep 25, 2008 4:59 pm    Post subject: Altimeter Question Reply with quote
Tom,
It'll soon be winter and I can keep the vents closed and have an accurate
altimeter. Never let it be said that I fly in violation of Sec. 91.121 -
Altimeter settings out in the middle of the desert SW.
Pete
Pete
Leander, TX
mikeperkins
PostPosted: Fri Sep 26, 2008 10:33 am    Post subject: Altimeter Question Reply with quote
Ditto on the inaccuracy of GPS altitude. Ditto on the addition of a static port. My port is about 24” behind the passenger door and about even with the height of the seat cushion. I chose that location because it doesn’t get beat by the prop wash as much as the other side.
Test flights at 50 feet above a runway indicated that this location produced no more than 20 feet of altitude difference between Vway-slow and Vway-fast in my Model I at varying throttle settings.
Mike Perkins
Float Flyr
PostPosted: Mon Sep 29, 2008 4:54 am    Post subject: Altimeter Question Reply with quote
I live at sea level + 20 ft. My GPS will show an altitude here of anywhere from -2 to +20 meters. Check the barometric pressure at your closest airport or believe it or not high school and use the to set your altimeter. I say high school because they often have true mercury barometers in the physics lab.
If you are in the area of a GPS correction service and subscribe to it then you can depend on the altitude reading.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Pete Christensen
Sent: Thursday, September 25, 2008 6:34 PM
Subject: Altimeter Question
Pete
Hell Paso, TX
III SN1000
912
 Filesize:  7.29 KB
 Viewed:  3086 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
