Rotax 912s water pump outlet
Shai.Brenner(at)stryker.c
PostPosted: Fri Sep 19, 2008 9:20 pm    Post subject: Rotax 912s water pump outlet Reply with quote
Sent: Saturday, September 20, 2008 7:47 AM
To: 'zenith601-list(at)matronics.com'
Subject: Rotax 912s water pump outlet
I have installed the engine to the engine mount and the cylinder cooling hose is interfering with the
Mount is it possible to modify the rigid water out let in
Rotax 912s water pump outlet or at the cylinder?
Any other solution?
Shai Brenner
CH601 HDS Rotax 912S
craig(at)craigandjean.com
PostPosted: Fri Sep 19, 2008 10:32 pm    Post subject: Rotax 912s water pump outlet Reply with quote
I believe the water pump outlet can be “clocked” to a number of different positions. See the last few pages in the 701/Rotax-ring-mount guide (section 2) and the first few pages of section 3 (which also cites the Rotax Heavy Maintenance Manual II, section 13.3.10 page 59 for water pump reinstallation):
http://www.zenithair.com/stolch701/data/r912s-ring-2.pdf
http://www.zenithair.com/stolch701/data/r912s-ring-3.pdf
This is for a ring mount on a 701 but the rotation of the water pump outlet should be the same.
-- Craig
macleod(at)eagle.ca
PostPosted: Sat Sep 20, 2008 1:20 pm    Post subject: Rotax 912s water pump outlet Reply with quote
Shai:
I believe you can modify both if required. From memory the water pump
outlet can be adjusted through about 40 degrees (could be more, my plane
is at the airport) and the cylinder inlets can be adjusted to any angle.
Be careful, these connections are very easy to damage.
Mike
601XL - Rotax 912S
is it possible to modify the rigid water out let in Rotax 912s water pump
