Perhaps the first or many wiring related questions
kearney(at)shaw.ca
PostPosted: Fri Sep 19, 2008 11:51 am    Post subject: Perhaps the first or many wiring related questions Reply with quote
Hi
As I work on wiring, I am a bit unsure of how to secure wing wiring. I have two small, light pitot tubes related to the AFS AOA system. They are running through a 3/8” bushing along with a COAX cable. The bushing is larger than required so I am wonder if it is necessary to secure the tubes & coax so that they do not move. If so, what is the recommended procedure?
Inquiring m minds need to know.
Cheers
Les Kearney
#40643 – some assembly required.
ricksked(at)embarqmail.co
PostPosted: Fri Sep 19, 2008 12:01 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
Les,
I put a few dabs of silicone on the the areas where the wire/tubes ran through the bushings at the beginning and end of the runs.
Rick Sked
40185
kearney(at)shaw.ca
PostPosted: Fri Sep 19, 2008 12:16 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
Thanks Rick
That sounds like a plan.
Cheers
Les
On 19-Sep-08, at 2:01 PM, Rick Sked <ricksked(at)embarqmail.com (ricksked(at)embarqmail.com)> wrote:
Les,
Rick Sked
40185
dlm46007(at)cox.net
PostPosted: Fri Sep 19, 2008 12:28 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
I used adel clamps at the inspection panels to firmly attach the wiring; I would be careful of potting them in with silicon or anything else as those holes may need to carry another wire at a later date. it's difficult to insert another wire in a hole potted with silicone within a wing.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Friday, September 19, 2008 1:01 PM
Subject: Re: Perhaps the first or many wiring related questions
Les,
Rick Sked
40185
MauleDriver(at)nc.rr.com
PostPosted: Fri Sep 19, 2008 1:34 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
I don't have the same situation since my pitot tube is running separately from any coax. But where I have coax and lighting wires, I am tying them together in the middle of each rib bay between the bushings. I did this before the bottom skin went on. I used the waxed string stuff. Seems better than letting them remain separate for the 12"+ between ribs.
Les Kearney wrote: [quote]
Hi
Cheers
Les Kearney
kearney(at)shaw.ca
PostPosted: Fri Sep 19, 2008 2:39 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
I just received a spool of wire lacing from Stein today along with a package of other goodies. I was going to tie the COAX and tubes using a running set of knots. My only concern was the small tubes “bouncing” in the bushings. This may be a non-issue though.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver
Sent: September-19-08 3:34 PM
Les Kearney wrote:
Hi
Cheers
Les Kearney
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
5
partner14
PostPosted: Fri Sep 19, 2008 4:35 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
Les, did you get your brackets yet? I didn't know I was supposed to fill out a cnkjdahaerfgf custom form... so let me know. In my wing I used a length of that thin wall drip sprinkler system pipe. Really cheap, really light, and no chaffing. Don
--- On Fri, 9/19/08, Les Kearney <kearney(at)shaw.ca> wrote:
Subject: Perhaps the first or many wiring related questions
Date: Friday, September 19, 2008, 12:50 PM
Hi
Cheers
Les Kearney
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Don A. McDonald
40636
kearney(at)shaw.ca
PostPosted: Fri Sep 19, 2008 6:39 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
Hi Don
No brackets yet but I am sure they will appear in a few days. Crossing the boarder always adds a bit to transit. Sorry about the &^*%*% customs forms. Unfortunately we get all the government we pay for. Damn!
Cheers
Les
PS: I will look for some of the sprinkler tubing and see if it will do. I am reluctant to tie the AOA tubes too tightly as they are so very soft. It wouldn’t help to accidently pinch a tube deep in the wing.
Cheers
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: September-19-08 6:36 PM
Hi
Cheers
Les Kearney
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List=nofollow>http://forums.matronics.comblank rel=nofollow>http://www.matronics.com/contribution
5
partner14
PostPosted: Fri Sep 19, 2008 9:39 pm    Post subject: Perhaps the first or many wiring related questions Reply with quote
That tubing is great..I used it along both sides of the fuselage also.... adding wires later, either in the wings or fuselage, a piece of cake. I used cut off connectors to secure them on one side of each bulkhead. Don
Subject: RE: Perhaps the first or many wiring related questions
Date: Friday, September 19, 2008, 7:37 PM
Hi Don
Cheers
Les
Cheers
Hi
Cheers
Les Kearney
 Filesize:  146.45 KB
 Viewed:  352 Time(s)
 Filesize:  262.9 KB
 Viewed:  368 Time(s)
Don A. McDonald
40636
johngoodman
PostPosted: Sat Sep 20, 2008 6:23 am    Post subject: Re: Perhaps the first or many wiring related questions Reply with quote
Les,
I pulled my AoA tubing through individual snap bushings (SB375-4 I think) where Van has his pitot tubing. Really not that hard to put in a new set of holes and bushings and the tubes stay rigid by themselves. The snap bushings give just enough resistance to keep everything in place.
For electrical conduit I drilled out Van's snap bushing run to take his corrugated nylon tubing. You need the right size uni-bit and a nifty 12" drill bit extension that fits the uni-bit shank from Home Depot. It's made by Ridgid and the "chuck" is 3/4". It will follow a 3/4" uni-bit through a hole without a problem.
Van's conduit is corrugated so you need to use a vacuum to pull a string through to get started. I replaced the string with a length of weed-eater line for future use.
In the fuselage I used more of Van's tubing but also - as suggested by others on this thread - thin wall irrigation tubing. The irrigation tubing has the advantage of smooth insides so you can push a wire through. It's heavier but not by much.
