nuckolls.bob(at)cox.net Guest
Posted: Fri Sep 19, 2008 8:14 am Post subject: Vern's crimp tool performance . . . |
Vern,
I was able to run a resistance measurement on your newly
installed terminals and got readings on the order of 200
micro-ohms . . . right in step with the values I get from
a PIDG terminal installed with an AMP T-head tool.
I was unable to measure the crimps on the terminals off the
failed switch . . . not enough lead-length to get a grip
on. But I did cross section the crimp and got the following
photomicrograph . . .
http://aeroelectric.com/Pictures/Misc/VL_Crimp_Tool_1.jpg
The terminal from the failed switch exhibits no voids in
the wire grip. Of course, you used this tool on other terminals
NOT attached to switches and you've not seen a failure there
so the results of my little look-see were predictable.
( -Thomas Paine 1776- )
rv-9a-online(at)telus.net Guest
Posted: Fri Sep 19, 2008 9:05 am Post subject: Vern's crimp tool performance . . . |
Thanks, Bob. I think you've safely eliminated bad crimps as a contributing
factor. Much apprectiated.
Vern
[quote] --
