robin1(at)mrmoisture.com Guest
Posted: Thu Sep 18, 2008 8:31 pm Post subject: Nose Gear Intersecting Fairing |
Has anyone designed / built an intersecting nose gear fairing that
transitions from the lower cowl to the nose gear? This seems like an
important place to manage the airflow (directly behind the prop) where
sharp angles intersect. All the other Vans A models have a fearing in
this location.
Robin
Albert Gardner
Posted: Thu Sep 18, 2008 9:59 pm Post subject: Nose Gear Intersecting Fairing |
I've been playing with this area but it's complicated by the fact that only
the '10 has a hinged nose gear. It almost seems like a fairing doesn't buy
much after allowance is made for the gear leg movement. So far I have just
covered up as much of the slot forward of the leg as possible-that slot is
pretty large to allow for cowl removal-to help with engine cooling. I have a
real issue with cooling and I'm adding a second oil cooler. Just too hot
here for 1 cooler. I have to keep the engine in my refrigerator until I'm
ready to fly as it is! Actually, my worst flight was out of IPL Imperial
one evening, OAT was about 95 and we were stuck on the ground for a few
minutes, oil temp was 230 on takeoff, it hit 245 before I landed. Changed
the oil but I don't want too see that again. Too many times with OAT's
approaching 100 on takeoff I have to reduce power, keep mix full rich and
flatten climb to keep temps down. Once OAT drops below 80 or so I'm fine. We
frequently have a 10 degree inversion here with OAT on the ground above 100.
Albert Gardner
Yuma, AZ
PS: after seeing the small ice chests sold at Oshkosh and elsewhere to
provide some cooling in the cabin I found a tent cooler at Cabellas that is
much cheaper. Fits between the rear seats, blows cool air forward, runs on
rechargeable batteries or a 12v plugin. Only $80 and far cheaper than the
ones sold for airplanes.
RV-10 N991RV |
Posted: Thu Sep 18, 2008 10:43 pm Post subject: Nose Gear Intersecting Fairing |
Albert,
Thanks for the note. We have discovered the drawback of the
standard oil cooler (high temps) and will be playing with the Airflow
2008 X oil cooler designed for aircraft up to 390 Hp. We hope to be able
to control oil temps with this mod instead of adding side or lower cowl
louvers. We should know more in a week. Unfortunately the larger oil
cooler does not resolve an apparent differential pressure issue in the
SJ cowl & plenum preventing max flow of air over the cooler fins.
I have a concept in mind that would place a shroud over the
outlet side of the oil cooler and terminates on the bottom of the cowl.
In flight the venturi effect should draw the air through the cooling
fins at pretty high velocity helping to cool the oil. I am sure there
are unintended consequences to this design that I can't yet comprehend.
Additionally it falls well outside of the KISS principle.
I would love to see photos of your dual oil cooler if at all
handy.
BTW I asked the question "off line" why one would not place a
NACA vent on the lower cowl to drive air through the oil cooler. The
response we received is that NACA vents are extremely efficient when no
back pressure is present but when there is enough back pressure the NACA
vent "plugs up" with the resisting air which results in basically no
airflow through the scat tubing and thus no air through the cooling
fins. Exactly the opposite of the desired effect. Whoops.
On a lighter note. I was on my regular commute in the 6A
climbing through 7,000' when I heard a BANG behind me. An unusual sound
like that gets your attention, and quick. Because my plan was to level
off at 7,500'that is when I am pulling back power, prop and refining
mixture, engaging the altitude hold, checking temperatures, looking for
traffic, talking to Santa Barbara Approach... Heck, I don't have time to
look for anything that may be falling off the plane. In those moments
the mind races, going over anything and everything that could account
for that noise. Did I mention it was a BANG? The plane felt fine, all
seemed in order, nothing unusual. Unable to account for the source of
the sound I continued with my flight plan staying vigilant as to
anything unusual. Once on the ground I gave the plane a once over and
found the cause of the noise. I was transporting a large bag of wheat
free crackers for my Mother-in-law "special" diet. The altitude change
burst the Mylar style container in my baggage compartment. The good news
is I was able to sample the crackers on my drive home. Turns out I
prefer the regular crackers.
Robin
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Fri Sep 19, 2008 7:18 am Post subject: Nose Gear Intersecting Fairing |
Albert, I have been anticipating the same kind of problem, and hopefully the vents I added on the sides will help. I have a couple of extra vents if your interested.
Don
--- On Thu, 9/18/08, Albert Gardner <ibspud(at)roadrunner.com> wrote:
Subject: RE: Nose Gear Intersecting Fairing
Date: Thursday, September 18, 2008, 10:58 PM
only
buy
We
_________________ Don A. McDonald
40636 |
partner14
Posted: Fri Sep 19, 2008 7:22 am Post subject: Nose Gear Intersecting Fairing |
Great story Robin. Glad it turned out the way it did. Don
--- On Thu, 9/18/08, Robin Marks <robin1(at)mrmoisture.com> wrote:
[quote]From: Robin Marks <robin1(at)mrmoisture.com>
Date: Thursday, September 18, 2008, 11:43 PM
[quote]--> RV10-List message posted by: "Robin Marks" <robin1(at)mrmoisture.com> Albert, Thanks for the note. We have discovered the drawback of the standard oil cooler (high temps) and will be playing with the Airflow 2008 X oil cooler designed for aircraft up to 390 Hp. We hope to be able to control oil temps with this mod instead of adding side or lower cowl louvers. We should know more in a week. Unfortunately the larger oil cooler does not resolve an apparent differential pressure issue in the SJ cowl & plenum preventing max flow of air over the cooler fins. I have a concept in mind that would place a shroud over the outlet side of the oil cooler and terminates on the bottom of the cowl. In flight the venturi effect should draw the air through the cooling fins at pretty high velocity helping to cool the oil. I am sure there are unintended consequences to this design that I can't yet comprehend. Additionally it falls well outside of the KISS principle. I would love to see photos of your dual oil cooler if at all handy. BTW I asked the question "off line" why one would not place a NACA vent on the lower cowl to drive air through the oil cooler. The response we received is that NACA vents are extremely efficient when no back pressure is present but when there is enough back pressure the NACA vent "plugs up" with the resisting air which results in basically no airflow through the scat tubing and thus no air through the cooling fins. Exactly the opposite of the desired effect. Whoops. On a lighter note. I was on my regular commute in the 6A climbing through 7,000' when I heard a BANG behind me. An unusual sound like that gets your attention, and quick. Because my plan was to level off at 7,500'that is when I am pulling back power, prop and refining mixture, engaging the altitude hold, checking temperatures, looking for traffic, talking to Santa Barbara Approach... Heck, I don't have time to look for anything that may be falling off the plane. In those moments the mind races, going over anything and everything that could account for that noise. Did I mention it was a BANG? The plane felt fine, all seemed in order, nothing unusual. Unable to account for the source of the sound I continued with my flight plan staying vigilant as to anything unusual. Once on the ground I gave the plane a once over and found the cause of the noise. I was transporting a large bag of wheat free crackers for my Mother-in-law "special" diet. The altitude change burst the Mylar style container in my baggage compartment. The good news is I was able to sample the crackers on my drive home. Turns out I prefer the regular crackers. Robin --
40636 |
ricksked(at)embarqmail.co Guest
Posted: Fri Sep 19, 2008 7:57 am Post subject: Nose Gear Intersecting Fairing |
Don,
You need to quit showing that you have access to machine press and tumbler making all those nifty parts..
Rick Sked
40185
Posted: Fri Sep 19, 2008 8:07 am Post subject: Nose Gear Intersecting Fairing |
One mod I saw at OSH was a metal shield that was curved and attached to the top of the oil cooler. The shield directed the air coming through the cooler down and back towards the cowl exit instead of forward and down in the cowl...I'm putting the side vents on as well and really considering a airflow cooler after we see what happens on the first flight: http://www.aviationtechproducts.com/html/engine__parts.html
Rick Sked
40185
Posted: Fri Sep 19, 2008 8:26 am Post subject: Nose Gear Intersecting Fairing |
Rick, the difference is we are going to install the 2008 X not the 2006 X. The 2006 X is for engines up to 280 Hp while the 2008 X is for engines up to 390 Hp. Also keep in mind we have the James cowl & plenum which definitely has a different pressure situation under the cowl.
Our plan is to change on thing at a time and test the differences. Our last resort will be to add the gills.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Friday, September 19, 2008 9:06 AM
Subject: Re: RV10-List: Nose Gear Intersecting Fairing
Rick Sked
40185
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Mon Sep 22, 2008 8:28 am Post subject: Nose Gear Intersecting Fairing |
Al can confirm this but I think the big difference in the Cabellas vs. the one you see at OSH is that the Cabellas simply blows air over the ice. This will cause a lot of humidity and burn through the ice much faster. The one you see in OSH is actually a closed loop system that uses a heat exchanger and pumps the cold water through that rather than just blowing air over ice. IIRC
Michael
Albert Gardner
Posted: Mon Sep 22, 2008 1:39 pm Post subject: Nose Gear Intersecting Fairing |
This is the area that an intersection fairing would have to cover and allow
for gear movement. For what it's worth, in order to get my lower cowl off
with a 3 blade prop I find it easiest to pull the tail down letting the nose
gear drop and providing additional clearance for the cowl.
Albert Gardner
Yuma, AZ
34.04 KB |
452 Time(s) |
RV-10 N991RV |
