LSA OR EXPERIMENTAL
GLJSOJ1
PostPosted: Mon Sep 15, 2008 4:25 pm    Post subject: LSA OR EXPERIMENTAL Reply with quote
Hi all
Getting ready to send off for the airworthy cert and I am planning to list it as EXPERIMENTAL-AIRPLANE-AMATEUR BUILT rather than going the light sport. The way I see it as long as my specification match the light sport regulations I am good to go. Email me off line if you want
Thanks all
gljno10(at)hotmail.com
601XL N676L FLYING PHASE I
CHESAPEAKE VA
Gig Giacona
PostPosted: Tue Sep 16, 2008 5:18 am    Post subject: Re: LSA OR EXPERIMENTAL Reply with quote
EXPERIMENTAL-AIRPLANE-AMATEUR BUILT is not only the best way to register a 601XL that you build it is the ONLY way since the deadline for the non-conforming "fat ultralights" passed earlier this year.
GLJSOJ1 wrote:
Hi all
Thanks all
W.R. "Gig" Giacona
601XL Under Construction
ideaz1(at)sbcglobal.net
PostPosted: Tue Sep 16, 2008 6:02 am    Post subject: LSA OR EXPERIMENTAL Reply with quote
I'm not an expert but I believe you can register as ELSA since the 601XL is
being built as a SLSA by the factory. The down side I heard was that you
cannot deviate from the plans. If you register as ELSA the supposed up side
is that if you sell the buyer can take the weekend class and do his or her
own annuals. If you go EAB you can deviate from plans and apply for the
inspection rating at the same time (no class required). Yes an EAB can be
flown by sport pilots as long as it was registered with the specs meeting
the sport plane requirements, i.e. speeds, weight limit, fixed pitch(or
ground adj.) etc. The so called fat ultralight rule was just to get 2 place
ultralights to comply with new regs, even though they could still be
registered as EAB.
Dirk
GLJSOJ1 wrote:
> Hi all
> Thanks all
jmaynard
PostPosted: Tue Sep 16, 2008 6:27 am    Post subject: LSA OR EXPERIMENTAL Reply with quote
No. An ELSA must be built from a kit *by the same manufacturer* as the SLSA.
AMD is the SLSA manufacturer; Zenith Aircraft Company is the kit supplier.
AMD would have to sell the kits in order for them to be eligible for E-LSA.
One other difference between E-LSA and E-AB: an E-LSA is not subject to the
51% rule.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
bryanmmartin
PostPosted: Tue Sep 16, 2008 7:04 am    Post subject: LSA OR EXPERIMENTAL Reply with quote
In addition, the kit supplier has to certify that the kit and assembly instructions comply with the consensus standards. In other words the kit has to be sold as an ELSA compliant kit right from the start.
§21.191 Experimental certificates.
(i) Operating light-sport aircraft. Operating a light-sport aircraft
that–
(2) Has been assembled—
(i) From an aircraft kit for which the applicant can provide the
information required by §21.193 (e); and
(ii) In accordance with manufacturer’s assembly instructions
that meet an applicable consensus standard; or
§21.193 Experimental certificates: general.
(e) In the case of a light-sport aircraft assembled from a kit to
be certificated in accordance with §21.191 (i)(2), an applicant must
provide the following:
(1) Evidence that an aircraft of the same make and model was
manufactured and assembled by the aircraft kit manufacturer and issued
a special airworthiness certificate in the light-sport category.
(2) The aircraft’s operating instructions.
(3) The aircraft’s maintenance and inspection procedures.
(4) The manufacturer’s statement of compliance for the aircraft
kit used in the aircraft assembly that meets §21.190 (c), except that
instead of meeting §21.190 (c)(7), the statement must identify assembly
instructions for the aircraft that meet an applicable consensus standard.
(5) The aircraft’s flight training supplement.
On Sep 16, 2008, at 10:25 AM, Jay Maynard wrote:
[quote] [quote][b]
Bryan Martin
do not archive.
z601(at)anemicaardvark.co
PostPosted: Wed Sep 17, 2008 11:32 am    Post subject: LSA OR EXPERIMENTAL Reply with quote
> is being built as a SLSA by the factory.
SLSA. AMD is the SLSA manufacturer; Zenith Aircraft Company is the kit
supplier. AMD would have to sell the kits in order for them to be eligible
for E-LSA.
As more and more of the participants on this forum provide information, what I
suspect (but don't know) is that the players have created two companies for
liability purposes. If AMD is legally disconnected from the kits, then they
probably cannot be sued if someone builds a kit and does considerable damage
to themselves or someone else with it. But an attorney would need to give the
final word on that conjecture.
Up to this point, I had believed (incorrectly) that AMD and Zenith were the
same company. That evidently is not the case.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
GLJSOJ1
PostPosted: Thu Sep 18, 2008 7:58 am    Post subject: Re: LSA OR EXPERIMENTAL Reply with quote
Thanks for all the replies. With information received I will go with Experimental-amateur built airplane. I really see no reason to do otherwise. It will go in the mail tomorrow.
CHESAPEAKE VA
