Speed test today
rene(at)felker.com
PostPosted: Sun Sep 14, 2008 5:55 pm    Post subject: Speed test today Reply with quote
Got up today and ran a simple 4 course speed test. The GPS speed in the spreadsheet is GPS Ground Speed. Looks like 175.5 Knots….average.
Looks like my indicated air speed may be a little low……
Any inputs?
Rene'
N423CF Flying
801-721-6080
Speed_Test_14_Sep_08.xls
 Filename:  Speed_Test_14_Sep_08.xls
 Filesize:  18 KB
 Downloaded:  252 Time(s)
Tim Olson
PostPosted: Sun Sep 14, 2008 6:27 pm    Post subject: Speed test today Reply with quote
Rene,
Awesome that you went out and did a couple of official runs!
I plugged the numbers into Kevin Horton's speed spreadsheet,
the 4-way version, here:
http://go.phpwebhosting.com/~khorton/rv8/phplinks/index.php?&PID=49
I get 175.6 for both runs.
That just means that you maybe have 3.5 kts of error and when you
report speed you will have to accommodate that. I am sure with a
little playing you could improve the accuracy a small amount...maybe
even try taking some aluminum tape and taping over your static
ports with a nice clean circle sticker with a hole in the center, and
by raising them you may get more accuracy....but at 3.5kts error
I don't know that I'd invest a ton of time in it.
Thanks also for adding all of the other data points in the
spreadsheet too...that's the way to do it...record it all. From
this I can look and get the idea of the conditions.
Of course, to get max speed out of it, you'd fly a little lower,
firewall the throttle and raise the RPM, and push that fuel flow
up there a ways. But, most people will realize that the numbers
you posted are just a good ROP higher-speed cruise number that
you may get going x/c somewhere when you're not looking for
max range.
Very nice to see someone investing the time to ensure they know
the accuracy of their systems. Good job!
Any inputs?
Rene'
N423CF Flying
801-721-6080
