rene(at)felker.com Guest
Posted: Sun Sep 14, 2008 5:55 pm Post subject: Speed test today |
Got up today and ran a simple 4 course speed test. The GPS speed in the spreadsheet is GPS Ground Speed. Looks like 175.5 Knots….average.
Looks like my indicated air speed may be a little low……
Any inputs?
Rene'
N423CF Flying
801-721-6080
 Download |
| Filename: |
Speed_Test_14_Sep_08.xls |
18 KB |
| Downloaded: |
222 Time(s) |
Tim Olson
Posted: Sun Sep 14, 2008 6:27 pm Post subject: Speed test today |
Rene,
Awesome that you went out and did a couple of official runs!
I plugged the numbers into Kevin Horton's speed spreadsheet,
the 4-way version, here:
http://go.phpwebhosting.com/~khorton/rv8/phplinks/index.php?&PID=49
I get 175.6 for both runs.
That just means that you maybe have 3.5 kts of error and when you
report speed you will have to accommodate that. I am sure with a
little playing you could improve the accuracy a small amount...maybe
even try taking some aluminum tape and taping over your static
ports with a nice clean circle sticker with a hole in the center, and
by raising them you may get more accuracy....but at 3.5kts error
I don't know that I'd invest a ton of time in it.
Thanks also for adding all of the other data points in the
spreadsheet too...that's the way to do it...record it all. From
this I can look and get the idea of the conditions.
Of course, to get max speed out of it, you'd fly a little lower,
firewall the throttle and raise the RPM, and push that fuel flow
up there a ways. But, most people will realize that the numbers
you posted are just a good ROP higher-speed cruise number that
you may get going x/c somewhere when you're not looking for
max range.
Very nice to see someone investing the time to ensure they know
the accuracy of their systems. Good job!
Rene wrote:
| Quote: | Got up today and ran a simple 4 course speed test. The GPS speed in the
Any inputs?
Rene'
N423CF Flying
801-721-6080
