Nosewheel Breakout Force
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
twatkins(at)bendcable.com
PostPosted: Sat Sep 13, 2008 5:34 pm    Post subject: Nosewheel Breakout Force Reply with quote
Yes you want to crank the nut until you have the 22 lbs side force other
wise you can wind up with some wobble especially if your tire is not
perfectly in balance. No I had to drill mine but I have a castle nut and
cotter pin not safety wire.. so if your says to safety wire it maybe
something different then mine.. good luck.. N359HW
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
