kearney(at)shaw.ca Guest
Posted: Thu Aug 28, 2008 9:35 am Post subject: Annuciator Lights |
Hi
As I layout my panel I am wondering about what is the best choice for annuciator lights. I see Stein has some nice LEDS (http://www.steinair.com/lights.htm) that will do the job.
Has anyone found a similar light that will display red/yellow/green on the same light? My Gretz heated pitot has a small board with three LEDS that I would like to combine into a single light.
Inquiring minds need to know
Les Kearney
#40643 – Some assembly required
coop85(at)cableone.net Guest
Posted: Wed Sep 10, 2008 3:52 pm Post subject: Annuciator Lights |
Les,
I’m not sure if you got any responses so here’s my .02. I have the same pitot and recommend you keep the lights as is. One is for power, one for low temp, and one for heat on. I don’t think you would want just one light and it would take some creative electronic wizardry to employ a light with 3 colors available. I just drilled 3 holes in the panel next to the pitot heat switch and glued the lights in place, it works great.
I haven’t used any annunciator lights other that what came with the GRT EFIS so can’t help you there.
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Thursday, August 28, 2008 12:34 PM
Subject: Annuciator Lights
Hi
Les Kearney
#40643 – Some assembly required | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Wed Sep 10, 2008 4:21 pm Post subject: Annuciator Lights |
Hi Marcus
I might do as you suggest. Do you have a pix of your lights? I still have time to decide.
Cheers
Les
On 10-Sep-08, at 5:52 PM, Marcus Cooper <coop85(at)cableone.net (coop85(at)cableone.net)> wrote:
Les,
Marcus
40286
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Les Kearney
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
Hi
Les Kearney
#40643 – Some assembly required 0123456789
Posted: Sat Sep 13, 2008 7:33 pm Post subject: Annuciator Lights |
Les,
I looked but don’t have a picture yet. I’ll get one the next time I get to the hangar, unfortunately it may be awhile.
I put my switches on the fixed bar below the panel. To the right of the pitot heat switch I drilled 3 holes vertically to match the lights as they are mounted on the circuit board. The lights just push though the panel from behind. That’s about it, but I’ll try to get a picture anyway.
Marcus
Sent: Wednesday, September 10, 2008 7:20 PM
To: RV10
Subject: Re: Annuciator Lights
Hi Marcus
Cheers
Les
Les,
Marcus
40286
Hi
Les Kearney
#40643 – Some assembly required | Quote: | | http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 0
| 123456789 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 5 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 6 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 7 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 8 | Quote: | | http://www.matronics.com/Navigator?RV10-List | 9 | Quote: | | http://forums.matronics.com | 0
