Kelly McMullen
Posted: Thu Sep 11, 2008 6:42 pm Post subject: Weld-on 10 & crazin |
I've used a lot of 90% isopropyl alcohol on plexi, to cleanup excess
PRC used to seal windows on my Mooney, per factory recommendations.
Plexi held by screws&nuts squeezing clamps. No problems at all 5 years
and counting. But I don't think the PRC generates much heat as it
cures.
On Thu, Sep 11, 2008 at 7:27 PM, Vernon Smith <planesmith(at)hotmail.com> wrote:
| Quote: | I knew acetone was out and now nix the rubbing alcohol. Though rubbing
alcohol was OK because it is recommended by Lancair. But they don't use
Weld-On.
At least 4 out of the 5 windows turned out. Oh well it's only time and
money.
Rene, Tim, Dave and Michael thanks for the feedback.
Vern
> Date: Thu, 11 Sep 2008 15:29:06 -0500
> From: Tim(at)MyRV10.com
> To: rv10-list(at)matronics.com
> Subject: Re: Weld-on 10 & crazing
> Ahhhhhh!!!! You used rubbing alcohol!!! That's a definite no-no!
> There aren't that many things you can clean it with. Kerosene
> is one.
See how Windows Mobile brings your life together—at home, work, or on the
go. See Now
A&P/IA, EAA Tech Counselor
KCHD |
