HD main gear fearing
chris Sinfield
PostPosted: Thu Sep 11, 2008 2:21 am    Post subject: HD main gear fearing Reply with quote
Guys and girls
I have had a Q from someone with a 601HD and I guess its the same with the HDS , the box gear fairing, is that a part that you have to make or can you buy it somewhere? Zenith? or Larry from Macsmachine it looks like a fiberglass cowl that covers the MLG root area.
if its from zenith does it have a part number?
Chris
as the guy is not on Email
tjs22t(at)verizon.net
PostPosted: Thu Sep 11, 2008 6:58 am    Post subject: HD main gear fearing Reply with quote
Chris,
Front is simple L-angle and some .025. Rear portion is a fiberglass part from the taildragger option for the HD/HDS series. Have him call ZAC and see if they have any in stock - Roger will know. I don't know part # or whether they might carry the stock.
tailwinds jeff
 Filesize:  128.36 KB
 Viewed:  316 Time(s)
 Filesize:  146.03 KB
 Viewed:  321 Time(s)
 Filesize:  326.93 KB
 Viewed:  337 Time(s)
