Recently completed Fuel Gauge Question
Goto page 1, 2  Next
vvkidd(at)mindspring.com
PostPosted: Wed Sep 10, 2008 3:53 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
This is my first visit to the site.
Recently completed my 601. During the fuel gauge calibration, using Blue Mtn EFIS Lite G4, I encountered a problem. After adding 9 gals to each tank the gauge reads full. I suspect that the float is topped out against the top of the tank. I checked all resistances both empty and full and noted the change in resistance as the float moves up and down, all appears OK there. Contacted Zenith and they said no one else had reported a problem like this. I have the long range 15 gal tanks. I bent the float 'Z' shape that Zenith described in there literature.
Anyone else having this problem?
Victor Kidd
Charleston, WV
N922VK
psm(at)att.net
PostPosted: Wed Sep 10, 2008 4:17 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Hi Victor,
Resistance fuel senders are notoriously inaccurate.
You should adjust your float so it is reasonably accurate when
showing the tank is empty. A full indication with this adjustment
(and the wing dihedral) should not be taken seriously. It is
standard practice to visually check your fuel level in your preflight
inspection. This, along with fuel burn planning should be used for
every flight.
If you want a more accurate fuel gauge you should consider installing
capacitance senders. These are inherently more accurate. However,
still your flight planning should include planning for fuel burn and
visual inspection of fuel levels before flight.
Paul
XL nearly done
floyd wilkes
PostPosted: Wed Sep 10, 2008 4:35 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Victor,
I had the same problem. I have the Dynon system. After adding 10.8 gal,
the float hits the top of the tank.
The problem is the 15 gal tanks are longer then the standard tanks and with
the angle of the wing the float hits the top before the tank is full.. I
believe the Z bend probably works for the standard tank.
I made a dip stick to check the tanks. Any gas visible through the filler
port is about 6 gallons in the tank.
Floyd Wilkes
601XL O-200
Phase 1 complete!!
Floyd Wilkes
Trainnut01(at)aol.com
PostPosted: Wed Sep 10, 2008 4:48 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Victor
That's just the nature of the beast. Because of the length of the tank and the dihedral of the wing you cannot prevent the float from topping out. It does not matter where in the tank you place the float it will not be able to monitor the full range of fuel levels. The FAA only requires that the float shows empty correctly.
Carroll Jernigan
Lenoir City TN
601XL Working on cockpit and Corvair.
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
Gig Giacona
PostPosted: Wed Sep 10, 2008 5:56 am    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
This is why I'm considering pulling the VDO senders and replacing them with capacitance senders before I mount the wings.
While proper planning, preflight and fuel management is still required it seems kinda cheesy that we can't make the fuel gauge read something close to right especially when we are using something like a Dynon or Blue Mountain.
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Wed Sep 10, 2008 6:16 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
To be accurate a capacitance sender for 601XL would have to be long enough to extend diagonally from the outbord top to the inboard bottom of the tank. That's close to five feet on a 15 gallon tank. I think I'll buy a flow meter.
Carroll
jmaynard
PostPosted: Wed Sep 10, 2008 6:32 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Do that anyway. It's more useful than I thought to know just how much fuel
you're burning in any given flight regime.
FWIW, I don't know which senders AMD uses, but I do know the gauge is quite
accurate from 9 down to 1 gallon. Above that, as others have noted, the
shape and angle of the tank gets in the way. I haven't found that not being
as accurate aobve 9 gallons has been any real issue.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
ideaz1(at)sbcglobal.net
PostPosted: Wed Sep 10, 2008 6:55 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
You could also put in 2 senders (with switches) one at each end of the tank, but I too think the full indication is not nearly as important as the E, so I just wouldn't bother.
Dirk
Mitch Hodges
PostPosted: Wed Sep 10, 2008 6:58 am    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
jmaynard wrote:
... but I do know the gauge is quite
Maybe I'm missing something (or the vehicles I drive/fly/float with are of the too cheap to be accurate class) but I don't recall ever having a vehicle of any sort that was very accurate at the "full" end of the tank. I guess I've always assumed that was normal due to the sender/float drawbacks.
As far as the FAA/FAR regulations, I also think there must be some requirement other than "accurate at Empty" otherwise, wouldn't just a placard that says "Fuel = Empty" be sufficient! (Sorry, couldn't resist).
Mitch Hodges
N601MH (Zenith 601HDS)
Builder Log at http://www.hodges.aero
Wings Under Perpetual Construction
z601(at)anemicaardvark.co
PostPosted: Wed Sep 10, 2008 7:18 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
No, that was even one of the questions on the A&P written - "when must a fuel
measuring system be accurate?" Ans: When it shows empty.
I find this less than satisifying, although I conceed it is likely to be more
important to know when the tank is empty than when it is full. A lot of stuff
in certification requirements dates back to when the earth was cooling, and
instrumentation was not always that accurate.
Despite the physical limitations of installation in the Zenith, of the
solutions that come to mind, I find the capacitive probe the most likely to
give me results I could rely upon at all fuel levels. But I'd like (expense
and weight ignored) to have a fuel flow meter also, so I could see just how
much my actions were influencing fuel burn.
I don't personally find a fuel flow gauge the sole answer. While it gives you
a feeling about how much fuel you are burning, and a totalizer can give you a
pretty good idea when the tank is empty, there is nothing in the tank itself
measuring the present value. In other words, if the thing breaks, you may not
know it until you run out of fuel.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Mitch Hodges
PostPosted: Wed Sep 10, 2008 7:42 am    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
I was being a bit tongue-in-cheek with my comment, but your point is well taken. I do understand that this is the only requirement for accuracy. I also understand there is a requirement that it actually be attempting to make a measurement leading up to empty.
I'll just be happy to get to the point that my Volkswagen senders have an opportunity to measure something!
Mitch Hodges
Gig Giacona
PostPosted: Wed Sep 10, 2008 8:29 am    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
Let's keep one thing in mind. The regulation 91.205(b)9 reads...
"(9) Fuel gauge indicating the quantity
of fuel in each tank."
The must read empty correctly comes from 23.1337
(1) Each fuel quantity indicator must
be calibrated to read ‘‘zero’’ during
level flight when the quantity of fuel
remaining in the tank is equal to the
unusable fuel supply determined under
§ 23.959(a);
Please note that the word "ONLY" doesn't appear in that paragraph. It is an FAA interpretation and subject to re-interpretation at the whim of the administrator who, at best, is going to change every 8 years or so.
I won't get into the issue about if Part 23 even applies to us...
§ 23.1 Applicability.
(a) This part prescribes airworthiness
standards for the issue of type certificates,
and changes to those certificates,
for airplanes in the normal, utility,
acrobatic, and commuter categories.
W.R. "Gig" Giacona
ggower_99(at)yahoo.com
PostPosted: Wed Sep 10, 2008 10:42 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Hello Jim,
The normal way to do the fuel management in a airplane. is the Flight Plan.
There, with the fuel rate of the engine, the amount of gasoline in the tank(s) before take off (fisical messure), the distance to fly in the chart (remember before GPS), the wind direction and speed, we have to estimate (less reserve) the distance to fly and/or time in the air.
In case there is something wrong on our estimate or find any headwind, etc. then we need an accurate "empty gauge" to see if we can get to the alternate landing strip we previosly chosed in our flight plan..
Is better to be conservative and fly less diatance/time before refuels than wait until the air conditioning of the plane (propeller) stops and we beguin to sweat... Smile
Saludos
Gary Gower
Flying from Chapala, Mexico.
"Old pilots I had the honor to know, planned more than 45 minutes reserve in all their flights"
--- On Wed, 9/10/08, Jim Belcher <z601(at)anemicaardvark.com> wrote:
Subject: Re: Re: Recently completed Fuel Gauge Question
Date: Wednesday, September 10, 2008, 11:22 AM
--> Zenith601-List message posted by: Jim Belcher
wouldn't just a
couldn't resist).
a fuel
you
Jim B. Belcher
A&P/IA
DaveG601XL
PostPosted: Thu Sep 11, 2008 4:32 am    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
Victor,
I have the 12 gallon tanks with the Zenith fuel senders and I too read full at anything 9 gallons and above.
David Gallagher
Cincinnati, OH area
PostPosted: Sun Sep 14, 2008 12:49 pm    Post subject: Recently completed Fuel Gauge Question Reply with quote
I couldn't agree more. The best insurance against running out of fuel is to
plan the amount of fuel required for the flight in advance. That would
include planning how much fuel should remain at each checkpoint (on longer
flights).
The fuel gauges should give some indication as to whether the plan is being
met or not, and whether or not it's necessary to land for fuel earlier than
planned.
But the fuel gauges on everything I've ever flown have left a lot to be
desired in terms of accuracy, and really were only fully accurate when they
said the tank was empty.
On Wednesday 10 September 2008 13:42, Gary Gower wrote:
Hello Jim,
Plan.
Saludos
Gary Gower
wouldn't just a
couldn't resist).
a fuel
more important to know when the tank is empty than when it is full. A lot
of stuff in certification requirements dates back to when the earth was
cooling, and instrumentation was not always that accurate.
you
a pretty good idea when the tank is empty, there is nothing in the tank
itself measuring the present value. In other words, if the thing breaks,
you may not know it until you run out of fuel.
Jim B. Belcher
A&P/IA
Jim B. Belcher
A&P/IA
PostPosted: Sun Sep 14, 2008 1:17 pm    Post subject: Recently completed Fuel Gauge Question Reply with quote
I've spent several days researching these issues. I've been involved in
aircraft certification in the past, and it is not a simple issue. I once got
stuck with trying to explain certification issues to the upper management of
an aerospace company, an experience I do not recommend to the faint of heart.
It is simply not possible to tie FAR23.959(a) to 91.205(b)9 for all aircraft.
It applies ONLY to those aircraft certified under FAR23, and there aren't
that many. Most of the light aircraft flying today are designs originally
certified under CAR3, and must meet a different set of requirements.
FAR23 is the certification basis for new design, type-certificated light
aircraft, like the Cirrus. Most of our general aviation fleet, such as The
Piper Cherokee, the Cessna 172, and the Cessna 150, were all certified under
CAR3. Things like their fuel gauge accuracy meet the CAR3 standard, not the
FAR23 standard.
As I understand it, there are three possible ways to establish the
airworthiness of a design like the 601/650, which was designed with the
intent of being a light sport aircraft. The first, for factory manufactured
aircraft, is to meet the concensus standards.
The second, the E-LSA, according to FAR21.193, is
"(e) In the case of a light-sport aircraft assembled from a kit to be
certificated in accordance with para 21.191(i)(2), an applicant must provide
the following:
(1) Evidence that an aircraft of the same make and model was manufactured and
assembled by the aircraft kit manufacturer and issued a special airworthiness
certificate in the light-sport category.
(2) The aircraft's operating instructions.
(3) The aircraft's maintenance and inspection procedures.
(4) The manufacturer's statement of compliance for the aircraft kit used in
the aircraft assembly that meets para 21.190(c), except that instead of
meeting para 21.190(c)(7), the statement must identify assembly instructions
for the aircraft that meet an applicable consensus standard......"
In other words, the 601/650 has been demonstrated to meet the concensus
standards. The fuel gauge accuracy requirements for a 601/650 are still
whatever are specified in the concensus standards, provided it was built from
a kit. How far one may deviate from the kit and still have E-LSA
certification is a question whose answer I'd love to know, but I am reluctant
to ask the FAA, because I might not like the answer I would get.
If one does not build from a kit, or partly uses a kit, and fabricates a
significant part of the aircraft from scratch, then one is building an
experimental aircraft, which will be treated like any other experimental
aircraft. There is no standard for fuel gauge accuracy on experimental
aircraft, of which I am aware.
As Gig Giacona pointed out, FAR 91, which is an operating FAR applicable to
all light aircraft, will require that the experimental aircraft have fuel
gauges. But it doesn't, and can't, state the accuracy requirements, because
there are at least four other specifications which give different accuracies
for different categories of aircraft.
§ 23.959(a);
W.R. &quot;Gig&quot; Giacona
http://forums.matronics.com/viewtopic.php?p 3624#203624
Jim B. Belcher
A&P/IA
Gig Giacona
PostPosted: Sun Sep 14, 2008 4:24 pm    Post subject: Re: Recently completed Fuel Gauge Question Reply with quote
Unless something has changed there are no E-LSA 601/650 at this time except the ones that received AW prior to the deadline for certifying non-conforming "Fat Ultralights."
The reason for this is the mfg of the kit must also be the mfg of the conforming factory built S-LSA.
For there to be a an E-LSA of the Zenith line then AMD is going to have to offer a kit or ZAC is going to have to offer a complete airplane.
That said the builder of a conforming E-LSA has almost no leeway. They must follow the instruction pretty much to the letter.
W.R. "Gig" Giacona
PostPosted: Mon Sep 15, 2008 6:27 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
That is pretty much what I would have expected, but I wasn't sure about the
status of the 601/650 as far as ELSA is concerned. The business relationship
of AMD/Zenith is a bit fuzzy to me. Thanks for that clarification.
It means that the 601/650 being built are experimental, and there is
considerable leeway in how fuel measurement is done.
Someone mentioned the problems on gauging the amount of fuel in the 15 gallon
tanks. I note that the AMD version has 15 gallon tanks. I wonder how they did
the measurement, and how accurate their indication of fuel level is?
Jim B. Belcher
A&P/IA
fderfler(at)gmail.com
PostPosted: Tue Sep 16, 2008 5:21 am    Post subject: Recently completed Fuel Gauge Question Reply with quote
Jim Belcher wrote: "Someone mentioned the problems on gauging the amount of fuel in the 15 gallon
the measurement, and how accurate their indication of fuel level is?"
Jim.. It's exactly as described.. in AMD's version of the 601 the emphasis is on knowing about the bottom of the tank, not the top. Once the tank is down to about half full, the level indications are quite accurate. When I first got the plane I got all ambitious and made a dip stick calibrated separately for each tank. I never use it anymore.
I have a fuel flow device installed that feeds information to the Dynon. THAT is valuable! After 200 hours I have a sort of "leaning table" built into my head. At about 5500', for example, 5.7 gph is about leaned out about right. (Yes, there is a leaning computer in the Dynon too.. and it's dandy if you use it at least once a week so you remember how the heck to use it! .. otherwise it's just another darn thing to play with)
I always take off with full tanks. How long you going to sit in that airplane anyway?
Frank Derfler
Islamorada, FL (The Florida Keys)
Twitter! Follow me at http://Twitter.com/Fderfler
See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com.
See my discussion of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at http://mostlyflying.com
Anybody who READS (anybody out there?) See www.greatguybooks.com
Frank Derfler
Goto page 1, 2  Next
Page 1 of 2
