GPS Antenna template
rv10(at)sinkrate.com
PostPosted: Sat Sep 13, 2008 2:25 pm    Post subject: GPS Antenna template Reply with quote
I haven’t purchased my IFR GPS yet but would like to fashion a doubler plate for the antenna. Does anyone have a detailed drawing of the antenna that comes with the GNS430W unit?
I have the antenna that comes with the Apollo GX-65 GPS/COM. Are the mounting holes the same? If I use that to drill my holes will the WAAS antenna bolt up ok?
-Ben Westfall
orchidman
PostPosted: Sat Sep 13, 2008 3:14 pm    Post subject: Re: GPS Antenna template Reply with quote
-Ben Westfall
The GPS antenna I received with my 430W was a GA35.
I have attached a copy of the installation sheet that came with the antenna. Hope this helps.
 Filesize:  25.58 KB
 Viewed:  264 Time(s)
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
