tc1917(at)bellsouth.net Guest
Posted: Sat Sep 06, 2008 3:08 am Post subject: LSA |
I may be wrong here, correct me please, but I was under the impression that
an AP-1 rating was a lesser rating than AP-2. In other words, if you had an
AP-2, you were qualified in tail dragger AND nose wheel. You were stepping
up a notch. Same as if you are rated for over 87 knots, you were
automatically qualified for the lesser of the ratings. Any other way of
interpreting it would be ridiculous. That would be like saying a truck
driver could not drive a car!!!! OR if you had an IFR rating, you could not
fly VFR. (been wrong before) Ted Cowan, Alabama, Slingshot, AP-2. See you
at the homecoming.
By the way, I will be offering a $50 reward (cash money) to anyone who can
solve my resonance problem on my 912. It doenst change RPM just makes this
horrible rumm rumm rumm which changes in volumn at higher RPM but not
frequency. Not in the carbs. See ya. Ted
Posted: Sat Sep 06, 2008 4:15 am Post subject: LSA |
can
| Quote: | solve my resonance problem on my 912. It doenst change RPM just makes
this horrible rumm rumm rumm which changes in volumn at higher RPM but not
Morning Ted:
I need $50.00.
Does it do it when tied down, doing a static runup?
Did you close the rear windows?
Is the fabric tight on top of the wings, inboard near the engine?
Did you check gear box to see if it was shimmed correctly?
Has anyone else had this problem with a SS and 912?
Has anyone else had this problem with SS and other engine combinations?
Has anyone else had this problem with other aircraft and engine
combinations?
Dan Horton's 3/4 scale Jenny with 3 cyl Suzuki engine did this. Never did
figure out why it did it.
Ronnie Collins SS did it. Fabric had been rib stitched by builder.
Stitches were failing on top of wings inboard near the engine. Caused by
drumming from prop.
I have heard some belt drive systems do this. Dan used a belt and Ronnie
was flying with a 582.
Still working on my first cup of coffee, and my mind is not working yet.
See ya at the Homecoming.
_________________ John Hauck
Titus, Alabama |
JetPilot
Posted: Sat Sep 06, 2008 8:36 am Post subject: Re: LSA |
[quote="John Hauck
mkIII[/quote]
It sounds like you are getting pretty close to that 50 bucks already !!! This brings a question to mind John, did you pick up much speed when you put the rear fairing on the fuselage in flat vertical area in front of the prop ? I am still trying to figure out how you cruise so fast.
Kolb MK-III Xtra, 912-S |
Posted: Sat Sep 06, 2008 9:03 am Post subject: LSA |
Mike B:
Thought I cruised fast until John W put the 912S on his Kolbra. Then he
blew me away.
I don't know if that rear fairing helped or not. Looks better if nothing
else.
Titus, Alabama |
gaman(at)att.net Guest
Posted: Sat Sep 06, 2008 4:04 pm Post subject: LSA |
On my MK-3,I loaded up the center section facing the inner steel wing rib with contact foam insulation cut to match the airfoil shape of the wing..Also the inside of the center section ends.Then both sides of the spar carry through and the top inner surface of the overhead plexiglass. All with 1/2 " denso foam sound absorbing foam.I think the noise comes from the wing skins and resonates thru the center section..I bought a half acre of that foam and stuck it everywhere I think it might even have helped some..
George Alexander
Posted: Sun Sep 07, 2008 5:20 am Post subject: Re: LSA |
| tc1917(at)bellsouth.net wrote: | I may be wrong here, correct me please, but I was under the impression that
interpreting it would be ridiculous. |
Ted:
For Sport Pilot, no "ranking" of LSA sets. The practical test for Sport Pilot gets you a set endorsement for the aircraft used. Have to do additional work for the others you want/need. Differences in handling characteristics is the reason given for the additional requirement(s).
From the FARs.......
Sec. 61.323
How do I obtain privileges to operate a make and model of light-sport aircraft in the same category and class within a different set of aircraft?
If you hold a sport pilot certificate and seek to operate a make and model of light-sport aircraft in the same category and class but within a different set of aircraft as the make and model of aircraft for which you have received an endorsement, you must-
(a) Receive and log ground and flight training from an authorized instructor in a make and model of light-sport aircraft that is within the same set of aircraft as the make and model of aircraft you intend to operate;
(b) Receive a logbook endorsement from the authorized instructor who provided you with the aircraft specific training specified in paragraph (a) of this section certifying you are proficient to operate the specific make and model of light-sport aircraft.
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
tkrolfe(at)toast.net Guest
Posted: Mon Sep 08, 2008 8:10 am Post subject: LSA |
George Alexander wrote:
Ted:
Sec. 61.323
George Alexander
FS II R503 N709FS
http://gtalexander.home.att.
George,
If I understand you correctly, if I were to get certified as a Sport
Pilot in an Aeronca then I would only be allowed to fly that type of
plane? What does that do to those that have transitioned from a GA
licenses to Sport Pilot. Are they then restricted to only flying their
current aircraft type? I know of two individuals that have transitioned
to Sport Pilot and was wondering how it would affect them.
I'm having second thoughts about Sport Pilot certification if that is
the restriction.
Terry - FireFly #95
Posted: Mon Sep 08, 2008 8:37 am Post subject: LSA |
Terry
I have my PPL and have been flying for under Sport Pilot for three years
since I let my medical lapse. Because of my higher rating I can fly any LSA
airplane even the faster LSA airplanes. I would get training if I were to
fly something different but I'm not required to.
Rick Neilsen
Redrive VW powered MKIIIC
George Alexander
Posted: Mon Sep 08, 2008 9:37 am Post subject: Re: LSA |
[quote="tkrolfe(at)toast.net"]George Alexander wrote:
<<<<SNIP>>>>
the restriction.
Terry - FireFly #95 |
Terry:
My understanding is what Rick Neilsen said....
Said another way.... a person who has a PPL/GA Ticket can fly LSA equivalent of that he was signed off for as a private. They do NOT become a Sport Pilot. They continue to hold the GA Ticket and if their medical lapsed they can fly aircraft in LSA as long as they have a valid driver license.
If they hold a private with a tail wheel endorsement, they can fly a Savage (>87 KTS Vh TW); a CT (> 87 KTS Vh tri-gear); a Firefly (<87 KTS Vh TW) or a QS (<87KTS Vh tri-gear).
Oh, do we miss John W.
FS II R503
E-LSA N709FS
Dana
Posted: Mon Sep 08, 2008 1:29 pm Post subject: LSA |
At 07:08 AM 9/6/2008, Ted Cowan wrote:
| Quote: | ...It doenst change RPM just makes this horrible rumm rumm rumm which
changes in volumn at higher RPM but not frequency. Not in the carbs...
Does it sound like a twin engine plane whose throttles aren't quite
synchronized? I get that in my Ultrastar, too, around cruise rpm. My
theory is that it's caused by the exhaust pulse impinging or reflecting off
a prop blade, depending on where the blade is at the moment of the exhaust
pulse. If the redrive is an exact ratio with no slip (mine is 2:1, but
effectively slightly more since all belt drives slip a little) then there
wouldn't any variation in the noise since the blade would always be in the
same place.
-Dana
Politicians and diapers have one thing in common. They should both be
changed regularly, and for the same reason.
Posted: Tue Sep 09, 2008 6:32 am Post subject: LSA |
> the restriction.
> Terry - FireFly #95
Terry:
George Alexander
FS II R503 N709FS
http://gtalexander.home.att.ne
George, Rick,
Thanks for the clarification!
Terry - FireFly #95
cedavis
Posted: Tue Sep 09, 2008 3:41 pm Post subject: LSA |
I think I'm one of the 2 individuals Terry mentions...
The key section from the relevant CFR George quoted is:
Here's an FAA link to the "Sets" http://www.faa.gov/licenses_certificates/airmen_certification/sport_pilot/media/aircraft_sets.pdf
So, I have an AP-5, ASEL tricycle gear over 87kts (earned in an Evektor Sportstar). However, this would not allow me to fly my Firefly, which is AP-2, ASEL Tailwheel under 87kts. However, with a tail wheel endorsement Aeronca Champ, I can legally fly the Firefly.
The problem I have is that the local FBO sold the Champ, and I'll need a bi-annual soon. Technically, you could take the flight test "ground observed" in a single place ELSA (I do not know of anyone who did). Does any one know if the flight portion of the bi-annual can be done in a single place?
Chuck Davis
Firefly N7057K
Time: 09:10:18 AM PST US
From: TK <tkrolfe(at)toast.net (tkrolfe(at)toast.net)>
Subject: Re: Re: LSA
> Ted:
> Sec. 61.323
> George Alexander
> FS II R503 N709FS
George,
the restriction.
Terry - FireFly #95
rlaird
Posted: Tue Sep 09, 2008 5:18 pm Post subject: LSA |
I can't quote verse and scripture, but I don't think it's allowed for the biannual.
On Tue, Sep 9, 2008 at 6:40 PM, Charles Davis <ceddavis(at)gmail.com (ceddavis(at)gmail.com)> wrote:
| Quote: | The problem I have is that the local FBO sold the Champ, and I'll need a bi-annual soon. Technically, you could take the flight test "ground observed" in a single place ELSA (I do not know of anyone who did). Does any one know if the flight portion of the bi-annual can be done in a single place?
Chuck Davis
Firefly N7057K
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
George Alexander
Posted: Tue Sep 09, 2008 5:29 pm Post subject: Re: LSA |
| cedavis wrote: |
<<<<SNIP>>>>
Chuck Davis
Firefly N7057K
<<<<SNIP>>>>
Chuck:
Don't think the flight instruction portion of the review is allowed in a single place. Beyond the single place issue, don't think it matters what a/c you use. As long as the instructor is willing..... Not even sure it has to be LSA.
FS II R503
E-LSA N709FS
Arty Trost
Joined: 25 May 2006 Posts: 206 Location: Sandy, Oregon
Posted: Tue Sep 09, 2008 8:53 pm Post subject: LSA |
Chuck Davis wrote:
| Quote: | Technically, you could take the flight
test "ground
done in a single
place?
I took my practical flight test in my single seat ELSA Maxair Drifter, with the examiner observing from the ground. Now that my bi-annual is coming up, I have checked with EAA and the FAA and have been told that the bi-annual MUST be taken in a two-seater with the examiner...because the bi-annual is meant to be for instruction, not a test. If John W. were still with us, he could quote the regs.
Arty Trost
Maxair Drifter
Sandy, Oregon
Posted: Wed Sep 10, 2008 4:43 am Post subject: LSA |
Arty T:
And you could get your BFR in his Kolbra,in the SE corner of Oregon.
Another week until time for Kolb Homecoming. Hope the huricanes leave us
alone long enough to fly up and back in peace...
Titus, Alabama |
Ed in JXN
Posted: Wed Sep 10, 2008 9:13 am Post subject: LSA |
Hi All,
I believe the term you're searching for is biennial (every other
year). Biannual is twice a year. (Looked it up in the Funk & Wagnall's just
to be sure).
Ed in JXN
MkII/503
Do not archive.
> single place?
> Chuck Davis
> Firefly N7057K
Thom Riddle
Posted: Wed Sep 10, 2008 9:43 am Post subject: Re: LSA |
A key to understanding which airplanes/sets and in which airspace a Sport Pilot can legally fly in, is the required endorsements list, which is in the FAA Advisory Circular AC 61.65e which is found on-line in .pdf format at http://tinyurl.com/6ha28m .
After downloading this file, go to the 25th page in this document where Appendix 1. begins. The second section (12-21) of this appendix lists the Endorsements a Student Pilot Seeking Sport Pilot Certificate must have for various privileges. The third section (22-29) lists the Endorsements a Sport Pilot must have to gain legal flying access to aircraft with Vh faster than 87knots, operations to/from towered controlled airports and in controlled airspace, etc. Notice that this appendix listing also references the specific FARs.
This AC 61-65e plus the LSA SETS referenced before in this thread pretty much spells out the requirements, though there a few things that are still open to interpretation. For example: If a Sport Pilot is trained in and passes his check ride in an LSA with faster than 87knots Vh (i.e. gets the >87kts endorsement), can s/he fly a slower than 87knot aircraft of the same type? My interpretation, which agrees with the interpretation of the Designated Pilot Examiner (DPE) who gave me my CFI-SP check ride, is that the faster than 87knot endorsement qualifies a Sport Pilot to fly the slower ones of the same type but not vice versa.
I hope this helps a bit.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
George Alexander
Posted: Wed Sep 10, 2008 4:12 pm Post subject: Re: LSA |
| Thom Riddle wrote: |
<<<<SNIP>>>>
Thom:
Can't say with absolute certainty, but I believe I remember right that this interpretation differs from what I was given by the DPE who gave me my SP check ride.
Sec 61.323 (and 61.319) seem pretty clear that you need an endorsement for any set that you want to operate in, no matter what other(s) you may have.
Could be wrong..... wouldn't be the first time.
My $.02
FS II R503
E-LSA N709FS
Thom Riddle
Posted: Thu Sep 11, 2008 4:06 am Post subject: LSA |
George,
I agree with your reading of the quoted FARs... it is pretty clear.
Perhaps what I should have said is that the way it will probably(my
opinion) be enforced (if it can be policed at all) is the way that I
described. In General Aviation (before Rec Pilot and now Sport Pilot)
there has been a de facto "ranking", and that is the basis for my
belief that this SP rule may be enforced (again, if it is possible to
do so) with this ranking legacy and mentality.
When I learned to fly a tail wheel airplane (PA-11), there was no such
thing as a "tail wheel" endorsement. When I learned to fly a Mooney,
there was no such thing as a "complex" endorsement, neither was their
a "high performance" endorsement. These came about later and resulted
in a de facto ranking system. Although the 61.300 series FARS that
deal with Sport Pilots seems to eliminate that for this Airman
Certificate, there is a move underway to "normalize" the Sport Pilot
regs to be more like the pre-Sport Pilot airman regs. Time will tell
if the regs actually change to reflect this.
Thom in Buffalo
Buffalo, NY (9G0)
- Anonymous |
