Installing V530 prop
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
ScottA
PostPosted: Mon Mar 13, 2006 6:58 pm    Post subject: Installing V530 prop Reply with quote
About to install the V530.  When I take the lifting shackle off the engine will it be obvious that the prop goes on the flange in a certain position?  If not, any particular position you are installing them?
Thanks again,
Scott
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
rkent(at)wlacrussianeng.c
PostPosted: Tue Mar 14, 2006 12:41 am    Post subject: Installing V530 prop Reply with quote
Scott,
It will be obvious, the prop will only fit in one position due to a locator pin on the back of the prop between two of the studs.
Rob Kent
Stores Manager
WLAC - Russian Engineering
www.wlacrussianeng.co.uk
Tel: +44 1628 829 165
Fax: +44 1628 828 961
dsavarese(at)elmore.rr.co
PostPosted: Tue Mar 14, 2006 4:55 am    Post subject: Installing V530 prop Reply with quote
Yes, it can only be placed on the flange in one direction.
Dennis
ScottA
PostPosted: Tue Mar 14, 2006 5:43 am    Post subject: Installing V530 prop Reply with quote
Thanks for the info guys.
Scott
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: Tuesday, March 14, 2006 5:55 AM
To: m14pengines-list(at)matronics.com
Subject: Re: M14PEngines-List: Installing V530 prop
Dennis
jim1511(at)on.aibn.com
PostPosted: Wed Mar 22, 2006 5:14 pm    Post subject: Installing V530 prop Reply with quote
Date: 2006/03/13 Mon PM 06:58:28 PST
To: <m14pengines-list(at)matronics.com>
Subject: Installing V530 prop
Thanks again,
Scott
There is a dowel pin on the prop hub so it can only be installed in one position. Jim
PostPosted: Wed Mar 22, 2006 5:28 pm    Post subject: Installing V530 prop Reply with quote
Yes, it will be obvious. There is a pin on the hub flange. It can only go
on one way.
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
