keithmckinley
Posted: Thu Sep 04, 2008 5:19 pm Post subject: New FSDO and special airworthiness cert |
Hello,
I'm a new CJ owner. This aircraft came from an airport under the Sacramento FSDO which signed off on the current ops limits and Airworthiness cert. I am now in the Windsor Locks area. Sent the FSDO my program letter and asked them to re-issue the ops limits. Almost a month later and no operating limitations and they want to inspect the A/C and re-issue my airworthiness cert.
Is re-issuing the Airworthiness Cert a normal procedure? I thought these went with the aircraft?
Do I need to just play nice?
Keith
NebraskaYak
Posted: Thu Sep 04, 2008 6:11 pm Post subject: Re: New FSDO and special airworthiness cert |
I had the same issue with my Yak. I played nice and it all went away in a month. What I did learn is there is not one FAA but many, each FSDO does its own little thing.
keithmckinley
Posted: Thu Sep 04, 2008 7:33 pm Post subject: Re: New FSDO and special airworthiness cert |
fortunately I have some very minor gripes to work off on the airplane and I get to wash it, BUT, man this is killin' me!
~K
Posted: Fri Sep 05, 2008 3:48 am Post subject: New FSDO and special airworthiness cert |
Keith,
If the aircraft were registered in the Standard Category like a Cessna,
Piper or Beechcraft, yes the airworthiness certificate would stay with the
aircraft. With our aircraft, FAA Order 8130.2F Chg 3 governs the process.
Whenever the aircraft is moved from one homebase airport to another, it
requires the reissuance of the Operating Limitations AND the Special
Airworthiness Certificate. The two documents are effectively "married"
together. And that includes a relocation to another home base airport, even
if it is only 5 miles away.
Although you can't stop the inspector or FSDO from ever inspecting the
airplane anytime, it should not be necessary if the airplane has a current
annual condition inspection signed off in the aircraft's log books, and it
already has the Special Airworthiness Certificate (which obviously it has).
Usually, the only time a FSDO inspector typically gets involved with
inspecting one of our aircraft is for the very first issuance of the
airworthiness certificate and operating limitations.
Once the airplane has been issued its first set of OL's and Special
Airworthiness Certificate, usually the FSDO only asks for copies of your log
books showing the current condition inspection along with the OL's and
Airworthiness Certificate and most importantly, the actual hard copy current
registration which must show your present address, and he/she will issue the
new OL's and Special Airworthiness Certificate.
You could ask a legitimate question like, "Since the airplane presently has
an annual condition inspection as documented in the airplane's log books and
it was already issued OL's and a Special Airworthiness Certificate from it's
previous location, why is it necessary to reinspect the airplane? Not that
it matters, but I'm just curious why?" Many of these airplanes are
relocated each year and the people who own them have had the OL's and
Special Airworthiness Certificate reissued as required by FAA Order 8130.2F
Chg 3. But there was no mandatory requirement to reinspect an airplane that
already has a current annual condition inspection signed off by an A&P, who
is an FAA authorized inspector.
Many FSDO inspectors do not understand what is required for Experimental
Exhibition category airplanes. Sometimes they are all over the map and make
your experience with them very frustrating. Try to work with them by being
knowledgeable (like you are trying to do now) and suggest that you can point
them to other FSDO inspectors who have done many of these types of aircraft,
thus shortening the paperwork processing cycle. But as I said, if they want
to inspect, let them. They have the right to do it.
As I previously mentioned, be sure the aircraft's registration is current.
If not, they can not issue the OL's and Special Airworthiness Certificate.
Also make sure the new OL's that will be issued do not have the 300 NM
proficiency area anywhere in them. That was rescinded on September 11, 2007
by Memorandum, see attached.
Dennis
FAA_Memorandum-removal_of_proficiency_area.pdf |
92.23 KB |
322 Time(s) |
keith(at)mckinley.us Guest
Posted: Fri Sep 05, 2008 5:11 am Post subject: New FSDO and special airworthiness cert |
Great post Dennis!
Thanks!
Keith
On Sep 5, 2008, at 7:47 AM, A. Dennis Savarese wrote:
[quote] Keith,
Cessna, Piper or Beechcraft, yes the airworthiness certificate
would stay with the aircraft. With our aircraft, FAA Order 8130.2F
Chg 3 governs the process. Whenever the aircraft is moved from one
homebase airport to another, it requires the reissuance of the
Operating Limitations AND the Special Airworthiness Certificate.
The two documents are effectively "married" together. And that
includes a relocation to another home base airport, even if it is
only 5 miles away.
the airplane anytime, it should not be necessary if the airplane
has a current annual condition inspection signed off in the
aircraft's log books, and it already has the Special Airworthiness
Certificate (which obviously it has). Usually, the only time a FSDO
inspector typically gets involved with inspecting one of our
aircraft is for the very first issuance of the airworthiness
your log books showing the current condition inspection along with
the OL's and Airworthiness Certificate and most importantly, the
actual hard copy current registration which must show your present
address, and he/she will issue the new OL's and Special
presently has an annual condition inspection as documented in the
airplane's log books and it was already issued OL's and a Special
Airworthiness Certificate from it's previous location, why is it
necessary to reinspect the airplane? Not that it matters, but I'm
just curious why?" Many of these airplanes are relocated each
year and the people who own them have had the OL's and Special
airplane that already has a current annual condition inspection
signed off by an A&P, who is an FAA authorized inspector.
Experimental Exhibition category airplanes. Sometimes they are all
over the map and make your experience with them very frustrating.
Try to work with them by being knowledgeable (like you are trying
to do now) and suggest that you can point them to other FSDO
inspectors who have done many of these types of aircraft, thus
want to inspect, let them. They have the right to do it.
current. If not, they can not issue the OL's and Special
Airworthiness Certificate. Also make sure the new OL's that will be
issued do not have the 300 NM proficiency area anywhere in them.
That was rescinded on September 11, 2007 by Memorandum, see attached.
Dennis
