Deems Davis
Posted: Mon Mar 13, 2006 12:05 pm Post subject: Engine choice - I made my mine |
After getting a lot of input from the Matronics board, and talking off
line to several people. I made my engine choice and today I placed my
order with Allen Barrett of BPA Engines http://www.bpaengines.com/ . The
timing of my decision was based on the price increase for the overhaul
kits from Lycoming in 1 or 2 days. I already saw one price increase and
want to avoid another. BPA is a respected engine builder they use the
kit from Lycoming, similar to Aero Sport and Mattituck, only they do
some extras eg. porting and flow matching, custom paint, dynamically
balancing the rotating parts to a much stricter tolerance than others.
(Others will do this but for extra fees).Then they do something unique,
they run your engine on their dyno for 1 1/2 hours with a minute by
minute printout that you get. Their attitude is that they believe this
is the only way to build an engine and they won't build it otherwise.
they'd rather let business go to other shops than build to a lower
standard. I think that speaks tons to the mindset and attitude/culture
that governs the way they operate. They also do Kirby Chamblis, and
Patty Wagstaff's engines as well. Allen Barrett made a personal call to
me to answer all of my questions and was extremely professional. As one
person said "picking an engine is a painful experience" and each
individual decision is governed by what is most important to that
person. In this case BPA met my criteria and I'm happy with the
decision. Thanks again to all who contributed knowledge and information
to this process
Deems Davis # 406
Fuse
http://deemsrv10.com/
rvbuilder(at)sausen.net Guest
Posted: Mon Mar 13, 2006 12:46 pm Post subject: Engine choice - I made my mine |
I too am in the process of finalizing my engine purchase with BPA. Allen is a great guy and very knowledgeable when it comes to these engines. I have no doubt he will build me a top notch engine that he can stand behind.
I know Aerosport is popular ,and plenty of people love their Aerosport engine, but I can't see sending my money out of the country when I can send it 300 or so miles away and support a local business that isn't any more expensive. Not to mention the possible import duties and dealing internationally if there is a dispute.
Michael Sausen
RV-10 #352 Working on Fuselage
n2faith2(at)cs.com Guest
Posted: Mon Mar 13, 2006 5:02 pm Post subject: Engine choice - I made my mine |
I've been helped by a number of posts on this list and have yet to contribute. Here's my 2 cents..........I ordered my engine from BPA and, Rhonda tells me, it will be dyno'd this Fri or next Mon. When making my decision I was particularly impressed with Allens' response to my questions and, what I perceived as, his personal attention and interest. He helped me make decisions re ignition, injection and desired hp. I'm impressed with the way I was guided through the process and anxiously await delivery.
Bill Stegemann
#40423 fuse
johnwcox(at)pacificnw.com Guest
Posted: Mon Mar 13, 2006 7:48 pm Post subject: Engine choice - I made my mine |
Wise Choice, great people, exceptional support. Hearing of your prop
decision will be another milestone.
John - KUAO
bsponcil(at)belinblank.or Guest
Posted: Tue Mar 14, 2006 9:35 am Post subject: Engine choice - I made my mine |
So which one did you order? The "heavy hitter" or the "lightweight"? Also,
does their cold air induction require you to modify the cowl? Just
curious....
-Brian
#40497
N211BD
Iowa City, IA
Rhonda(at)bpaengines.com Guest
Posted: Tue Mar 14, 2006 9:59 am Post subject: Engine choice - I made my mine |
Brian:
If it's okay, I'd like to address the differences in the IO-540s we have
listed on our website and note that our site is in the process of some
serious changes, so more detail will be on our site soon.
The "heavy hitter" IO-540 is an angle head engine which is used in the
Extra series aircraft and some Glassair models. The lightweight IO-540
is the parallel head version of the engine which is used in the RV-10.
Our cold air induction does require a cowl modification for the RV-10,
which is being developed and should be available sometime in the 2nd
quarter. We have been told that the pricing for the new cowl will be
competitive with the cowl sold by Van's. Our cold air has been used on
some Rockets with some cowling modifications as well.
Hope this helps clarify.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N> Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
LarryRosen
Posted: Tue Mar 14, 2006 10:10 am Post subject: Engine choice - I made my mine |
I also going the group and placed an order for my engine from BPE. I got the light weight which is the IO-540X parallel valve engine. I did not get the cold air induction. I did get 9:1 compression and the chrome options. I will decide later on my ignition option.
It sure would be nice if the emag / pmag for a 540 was announced at sun-n-fun.
Larry Rosen
-------------- Original message ----------------------
curious....
-Brian
#40497
N211BD
Iowa City, IA
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Rhonda may chime in on this but the cold air induction will require a different cowl. Will James is currently making a cowl that will fit this configuration in addition to his regular RV-10 cowl. I was planning on using a James Aircraft cowl either way so if I go with the CAI it's not a big deal. I haven't decided on that option yet and will wait until they are about ready to build it to decide.
Michael Sausen
-10 #352 Fuselage
BPA(at)bpaengines.com Guest
Posted: Tue Mar 14, 2006 10:19 am Post subject: Engine choice - I made my mine |
I’ll chirp a little. Yes, the CAS will require a different cowl than the stock Van’s cowl. However, the cowl according to Will James will be very much in line with the cost of the Van’s cowl. The advantage to the CAS is ram air recovery ie increased MP.
Allen Barrett
Posted: Tue Mar 14, 2006 10:43 am Post subject: Engine choice - I made my mine |
This is almost the exact same configuration I'm going with except also added are dual LSE III Ignitions and a Airflow Performance FM-200. For those interested in the details here is the whole description:
IO-540-X engine built from New Lycoming Kit No. 05J23544 with high pressure fuel pump. 9.0:1 compression pistons, AFP FM200 fuel system, new Champion spark plugs, Dual LSE III, new lightweight Skytec starter, all engine fittings and silicone rocker box cover gaskets. All components will be dimensionally inspected to ensure that they meet New Parts Limits, the cylinders will be ported and flow matched including a three angle cut on the seat to ensure proper valve-to-seat geometry. The engine will be painted your choice of color (you can let me know your color choice later). The rotating assembly will be dynamically balanced. After assembly, the engine will be run in our in house dynamometer for 1.5 hours (a copy of which will be provided to you) and foam crated for secure shipment.
Just a note on the 9:1 pistons, Allen says they will not affect TBO but the 9.5:1 will. Anyway, off to right the check. Yikes!
Michael Sausen
jjessen(at)rcn.com Guest
Posted: Tue Mar 14, 2006 11:27 am Post subject: Engine choice - I made my mine |
Let's see. My son's senior year at college vs. engine......... I'm thinking; I'm thinking.
John Jessen
~328 (overwhelmed with the thought of others already having 200 hours on their RV-10. Arrgh)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, March 14, 2006 1:41 PM
Subject: RE: Engine choice - I made my mine
Michael Sausen
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of LarryRosen(at)comcast.net
Sent: Tuesday, March 14, 2006 12:09 PM
Subject: Re: Engine choice - I made my mine
--> RV10-List message posted by: LarryRosen(at)comcast.net
Larry Rosen
| Quote: | --> RV10-List message posted by: "Brian Sponcil"
--> <bsponcil(at)belinblank.org>
Also, does their cold air induction require you to modify the cowl?
Just curious....
-Brian
#40497
N211BD
Iowa City, IA
----- Original Message -----
Sent: Monday, March 13, 2006 2:02 PM
Subject: Engine choice - I made my mine
> --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
> off line to several people. I made my engine choice and today I
> placed my order with Allen Barrett of BPA Engines
> http://www.bpaengines.com/ . The timing of my decision was based on
> the price increase for the overhaul kits from Lycoming in 1 or 2
> days. I already saw one price increase and want to avoid another.
> BPA is a respected engine builder they use the kit from Lycoming,
> similar to Aero Sport and Mattituck, only they do some extras eg.
> porting and flow matching, custom paint, dynamically balancing the
> rotating parts to a much stricter tolerance than others. (Others
> will do this but for extra fees).Then they do something unique, they
> this is the only way to build an engine and they won't build it
> otherwise. they'd rather let business go to other shops than build to a lower standard. I think that speaks tons to the mindset and attitude/culture that governs the way they operate.
> They also do Kirby Chamblis, and Patty Wagstaff's engines as well.
> Allen Barrett made a personal call to me to answer all of my
> questions and was extremely professional. As one person said
> "picking an engine is a painful experience" and each individual
> decision is governed by what is most important to that person. In
> this case BPA met my criteria and I'm happy with the decision.
> Thanks again to all who contributed knowledge and information to
> this process
> Deems Davis # 406
> Fuse
> http://www.matronics.com/Navigator?RV10-List
RV10-List Email Forum -
more:
bsp;
HREF="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
bsp; - List Contribution Web Site -
bsp; -Matt Dralle, List Admin.
HREF="http://www.matronics.com/contribution">http://www.matronics.com/contribution
Deems Davis
Posted: Tue Mar 14, 2006 11:47 am Post subject: Engine choice - I made my mine |
Allen, is it too late for me to change and to go w the 9.1 : 1
pistons/cylinders?
Deems
BPA wrote:
[quote] I’ll chirp a little. Yes, the CAS will require a different cowl than
Allen Barrett
www.barrettprecisionengines.com <http://www.barrettprecisionengines.com/>
Posted: Tue Mar 14, 2006 11:51 am Post subject: Engine choice - I made my mine |
Absolutely.......NOT! Be glad to do it.
Allen
Posted: Tue Mar 14, 2006 12:03 pm Post subject: Engine choice - I made my mine |
Is your comment about 200 hrs a dissappointment because you are not flying
or is it because they already have 200hrs and only 1800 left before O.H.
There are two ways to look at the same thought.
John G. 409(stretching the backside of my knees for two days, after back
riveting from the inside of my tailsection turned upside down...and I am
only turning 40) Arrgh!!!!
[quote]From: "John Jessen" <jjessen(at)rcn.com>
Reply-To: rv10-list(at)matronics.com
Date: Tue, 14 Mar 2006 14:25:28 -0500
John Jessen
on
their RV-10. Arrgh)
_____
(Michael Sausen)
the
Michael Sausen
Posted: Tue Mar 14, 2006 3:32 pm Post subject: Engine choice - I made my mine |
Tell him part time jobs build character and will make him appreciate his education better.
Michael Sausen
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: Tuesday, March 14, 2006 1:25 PM
John Jessen
Michael Sausen
Larry Rosen
Just curious....
-Brian
#40497
N211BD
Iowa City, IA
> this process
> Deems Davis # 406
> Fuse
more:
bsp;
Hmm, I always had the understanding you can delete items from any kit for the cost of the item. This is what I plan on doing when I order the finish kit. Ya, the lightning strike/loss of electrics is a concern and it's really too bad there isn't a P-Mag for the 6 cylinders yet. Rolling the dice a little bit but the odds are probably low that I would loose everything at any given time. Besides, if I do I will be really up $hit creek anyway with a full electric panel.
Michael Sausen
From: John W. Cox [mailto:johnwcox(at)pacificnw.com]
Sent: Tuesday, March 14, 2006 2:45 PM
To: RV Builder (Michael Sausen)
Nicely done. I think the Cold Air is worth the extra work, however I take exception to Rhonda’s reference to price similarity. I don’t believe VAN is giving a credit so the cost is an incremental increase on the James cowl. The only risk is lightning incursion which could wipe out both LSE whereas a redundant Mag might have been a more conservative solution. IE – Tim Olson.
John
Sent: Tuesday, March 14, 2006 10:41 AM
Michael Sausen
Posted: Tue Mar 14, 2006 4:14 pm Post subject: Engine choice - I made my mine |
Try that with the Oregon Aero seats. I had Dick speak at an aviation dinner last Thursday and the question of the Harmon Rocket was brought up. He instantly got an increase in blood pressure, his neck swelled and he mentioned two fatal accidents that are working their way through the courts. At an earlier meeting he acknowledged that he has twice settled out of court even though his firm was not negligent as a means to mitigate bad PR. He is not receptive to repeating the task.
He mentioned that he is not receptive to credits for parts replaced by someone else. Only unused parts. It is only my opinion that the replacement of a cowl by an aftermarket opens the same Pandora’s Box to a Wide Angle Continental with twin turbos. He as adamant that the narrow Parallel Valve Engine is the only choice and that 260 hp is a hard number. He asked for an repeatedly got a Head nod of affirmation from Ken Krueger on each point. My money is on Good Luck.
My Generation II is going to cut a wide swath across this issue with just such a venture including speed fairings, relocated NACA air vents, a LoPresti style cowl which adapts a Barrett Cold Air ram induction front feed body. It is common knowledge that will make me Persona Non Grata when complete. Let me know when you test your understanding.
In case of a Lightning Hit, Plan on a Best Glide and as long as you have good bonding straps your controls should not be welded LOCKED. Fire is worse.
John
Sent: Tuesday, March 14, 2006 3:29 PM
Michael Sausen
John
Michael Sausen
Posted: Tue Mar 14, 2006 4:34 pm Post subject: Engine choice - I made my mine |
My apology to everyone on this list including Dick, this was thought to be a private post back to Mike Sausen. For those of you sooping up RV-10s (Vic and Noel) I did not mean to stir the pot.
Sincerest and deepest of apologies to all of the lurkers and friends of VANS alike. Oh the speed of electrons even with a tin can and string.
John
DO NOT ARCHIVE
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John W. Cox
Sent: Tuesday, March 14, 2006 4:12 PM
John
Michael Sausen
John
Michael Sausen
dav1111(at)cox.net Guest
Posted: Wed Mar 15, 2006 4:52 am Post subject: Engine choice - I made my mine |
Rhonda:
With the heavy hitter, which I assume is somthing like the K model IO-540 angle valve, does the cowl need modification? Also how much heavier is the heavy hitter?
Russ Daves
Date: 2006/03/14 Tue PM 12:59:02 EST
Brian:
Tulsa, OK 74115
(918) 835-1754 fax
