MichaelGibbs(at)cox.net Guest
Posted: Wed Aug 20, 2008 8:41 am Post subject: "Heavy" wing on Series 7 |
| Quote: | I have about 10 hours on my 7 now and I am loving it but I have a
"heavy' left wing...I would think that turning the left front rod
bearing out a few turn to raise the LE of the left wing a touch or
do just the opposite to the right side would help but I wanted to
get an opinion from the group.
That's what I had to do, Darin. I turned them about 1/2 turn each
time and would go fly to see how it did. It took several iterations
to get her to fly straight and level hands off, but it worked. Make
sure that you don't loosen any of them past the hole on the side.
Mike G.
N728KF, Kitfox IV-1200 Speedster
Phoenix, AZ
lcfitt(at)sbcglobal.net Guest
Posted: Wed Aug 20, 2008 9:03 am Post subject: "Heavy" wing on Series 7 |
I have a question as well. How is the rudder trim. I found that once I put
the tab on the rudder, the wing lost weight.
Lowell
Posted: Wed Aug 20, 2008 9:12 am Post subject: "Heavy" wing on Series 7 |
once I put the tab on the rudder, the wing lost weight.
That's an excellent point, Lowell. Before adjusting your lift
struts, make sure that the slip/skid ball is centered when evaluating
the problem. I had to add a rudder tab as well as adjust the struts
before I was happy with it.
Mike G.
Phoenix, AZ
jdmcbean(at)kitfoxaircraf Guest
Posted: Wed Aug 20, 2008 9:16 am Post subject: "Heavy" wing on Series 7 |
Darin,
Determine if it is indeed a wing heavy or a yaw condition.
Give me a shout when you get a chance.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
kerrjohna(at)comcast.net Guest
Posted: Wed Aug 20, 2008 10:32 am Post subject: "Heavy" wing on Series 7 |
rear struts affect dihedral and incidence. if the dihedral is where it should be adjust only the front struts, possibly 1/2 in and out on each.
I love using a digital level when working with rigging adjustments. a complete trial rig of the Hatz biplane took about an hour with a digital level to zero in on the values.
John
[quote] --> Kitfox-List message posted by: "darinh"
I have about 10 hours on my 7 now and I am loving it but I have a "heavy' left
wing. I have adjusted the flaperons a bit to try to fix the problem but I don't
really want to move them much more. I know this condition can be fixed by
adjusting the struts but am unsure which end bearing to adjust and which way.
basically, while in cruise configuration my airplane tends to bank ever so
slightly to the left if I don't maintain some right stick pressure. It would be
awesome if these airplanes had a manual flaperon trim. Anyway, I would think
that turning the left front rod bearing out a few turn to raise the LE of the
left wing a to uch or BR>> [quote][b]
peteohms
Posted: Wed Aug 20, 2008 10:53 am Post subject: "Heavy" wing on Series 7 |
I have the same problem in my Kitfox III. I was told by a friend to be sure
I had the ball centered. My ball is on the right side of my panel so
parallax was screwing up my view of the ball. I plan to put a trim tab on
the rudder to help.
Pete
Hell Paso, TX
Kitfox III Sn. 1000, 912, Grove
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
darinh
Posted: Wed Aug 20, 2008 11:31 am Post subject: Re: |
Thanks guys for the advice...the ball is centered and still tends to bank. The bank is very slight, in fact, it is so slight that I think it may be simply from my weight on the left side without a passenger. I don't think I will need a rudder trim tab and will try turning the struts out or in 1/2 turn at a time.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
rjdaugh
Posted: Wed Aug 20, 2008 11:50 am Post subject: "Heavy" wing on Series 7 |
I have been flying my 5/7 for four years now and have still not adjusted
anything. The reason is that I can not decide what to adjust. Sometimes it
is the left wing that is low and sometimes it is the right wing. Nothing is
too bad.
I know that it partly depends upon if I am climbing hard, or have the engine
pulled to idle in a descent, but (in cruise) I think it also depends upon
whether I have a passenger or not. I suggest that you wait until you do
some test flights with some concrete bags in the right seat.
Lowell's point has given me more ammunition for procrastination.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Michel
Posted: Wed Aug 20, 2008 12:07 pm Post subject: "Heavy" wing on Series 7 |
The right wing of my model 3 was also 'heavy.' I was thinking to adjust the struts but then I first measured the angle of each wing at the root and the tip. I don't remember exactly but I think it was 11 and 13.5 degrees (taildragger!). Also, 2.5 degrees washout. And it was exactly the same for both wing. So I thought it wouldn't be wise to change the struts. I also considered the rudder but this 'leaning to the right' happens with the ball in the center.
I then went for this solution: A small piece of aluminium bended downward near the root of the left flaperon. It did the trick. Unfortunately it was only provisory fixed with double-side tape and I lost it. I must make a new one and fix it better. But ... first I need my pilot license back!
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded.
KITFOXZ(at)aol.com Guest
Posted: Wed Aug 20, 2008 12:25 pm Post subject: "Heavy" wing on Series 7 |
As a former modeler, I always say get a balanced and true aircraft first by looking at adjusting CG, dihedral, wing wash out, rudder trim, etc. for hands off trim with power off. That way when you are dead stick you don't have your hands full trimming and looking for a spot to land at the same time. Once set up perfectly for glide, the only complication with power on should be to adjust side thrust and/or down thrust as needed to get a tame aircraft with minimal trim change.
My 2 cents. Now I'm going back to eternal lurking.........
John Z.
In a message dated 8/20/2008 3:32:53 P.M. Eastern Daylight Time, gerns25(at)netscape.net writes:
| Quote: | --> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
Darin Hawkes
Series 7 (Phase 1 - Flight Testing)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=199683#199683
It's only a deal if it's where you want to go. Find your travel deal here.
matronics(at)bob.brennan. Guest
Posted: Wed Aug 20, 2008 2:41 pm Post subject: "Heavy" wing on Series 7 |
Darin - my model 2 tends to bank slightly to the left also, when it's just
me and no fuel in the reserve tank. With a passenger in the right seat or
fuel in the (right, I only have 1) reserve fuel tank it loses the bank, with
a passenger and reserve fuel it will bank right. So I figure it's set up
just right!
I would suggest you try all loading configurations before making changes.
BTW my rudder has a right-deflecting permanent trim tab, to minimise the
effect I think.
Bob Brennan - N717GB
1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
dwight purdy
Posted: Wed Aug 20, 2008 2:52 pm Post subject: "Heavy" wing on Series 7 |
It just so happens I took my feet off of the rudder peddles last week and
after about 700 hours I found the plane turns 90 deg per minute to the
right. The ball is centered and the wings are level. I could hardly believe
it. I know you have to fly the rudder on the early models but I can not
believe I never noticed it before. The vertical fin does not look to have
any offset to counter torque. Have not looked at the builders manual to see
what was recommended. The only recent change to airframe is the King Fox
tires. Maybe misalignment of wheels multiplied by the huge tires? I doubt
that as it is too close to the yaw axis(is that the vertical axis? been too
long since ground school). My hand out of the door was nil. I hate to put a
trim on the rudder but would relieve tension in my left foot .
Dwight Purdy
model ll
At 10:11 AM 8/20/2008 -0700, you wrote:
That's an excellent point, Lowell. Before adjusting your lift struts,
make sure that the slip/skid ball is centered when evaluating the
problem. I had to add a rudder tab as well as adjust the struts before I
was happy with it.
Mike G.
Phoenix, AZ
270.6.5/1620 - Release Date: 8/19/2008 6:04 AM
_________________ dwight
model II |
thesupe(at)hotmail.com Guest
Posted: Wed Aug 20, 2008 3:50 pm Post subject: "Heavy" wing on Series 7 |
Not to long ago C there was a post on either this or the Avid list about someone that had rigged up a lazer level on the wings that would shoot a dot onto the hangar wall that was compared to a level line on the wall and the wings were adjusted to being the same that way. They said it really worked great and was much more acurate than just a level C and everyone on the field wanted him to do it to their plane. I have yet to try it C but I intend to do it one of these days. Jim Chuk
Kitfox 4 building C Avid MK IV flying C Avid B just sold. MN
| Quote: | Date: Wed C 20 Aug 2008 09:40:42 -0700
Subject: Re: "Heavy" wing on Series 7
--> Kitfox-List message posted by: Michael Gibbs <MichaelGibbs(at)cox.net>
That's what I had to do C Darin. I turned them about 1/2 turn each
to get her to fly straight and level hands off C but it worked. Make
Mike G.
N728KF C Kitfox IV-1200 Speedster
Phoenix C AZ
Get thousands of games on your PC C your mobile phone C anddirect/01/' target='_new'>Game with Windows [quote][b]
Michel
Posted: Thu Aug 21, 2008 12:34 am Post subject: "Heavy" wing on Series 7 |
| Quote: | From: darinh [gerns25(at)netscape.net]
You are right, the flaperons will simply find neutral...
Of course they will, Darin. But there is still the possibility that e.g. there is a slight warping in one of the flaperons. That would affect the banking attitude because, as I wrote, using a small trim tab on my left flaperon helped.
Cheers,
Michel Verheughe
Norway
Posted: Thu Aug 21, 2008 7:47 am Post subject: "Heavy" wing on Series 7 |
any bias between left and right adjustment should be toward increasing washout rather than washin.
John
====== >> [b]
rjdaugh
Posted: Thu Aug 21, 2008 9:23 am Post subject: "Heavy" wing on Series 7 |
Good point John!
Randy
Do not archive.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of kerrjohna(at)comcast.net
Sent: Thursday, August 21, 2008 9:46 AM
Subject: Re: Re: "Heavy" wing on Series 7
John
====== >> 0123456789
Kitfox 5/7 912S
57_kid
Posted: Thu Aug 21, 2008 1:22 pm Post subject: "Heavy" wing on Series 7 |
I think that just about everyone has done that me included sounds like it
would work but alas no good just moves the stick over a bit
Steve
darinh
Posted: Fri Aug 22, 2008 9:39 am Post subject: Re: |
Did some more testing this morning and it is definitely a heavy wing. I think a turn or so in on the right front strut will to the trick. As John stated, it is better to increase wash-out than wash-in. Thanks for all the input.
Series 7
914 Turbo
Kaysville, Utah |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sat Aug 23, 2008 5:18 am Post subject: Re: |
| darinh wrote: | | I think a turn or so in on the right front strut will to the trick. As John stated, it is better to increase wash-out than wash-in. Thanks for all the input. |
Darin,
Unless my mind is a little twisted this morning, "turning in" the right front will decrease the wash out in the right wing. Shortening or "turning in" the left rear will increase the wash out on the left wing and create more lift on that side.
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
propellerdesign(at)tele2. Guest
Posted: Sat Aug 23, 2008 6:59 am Post subject: "Heavy" wing on Series 7 |
Twisted Yes,
Jan
