Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sun Mar 12, 2006 3:56 pm Post subject: SL70 transponder & Grand Rapids EFIS |
Listers,
I'm installing a UPSAT SL70 transponder with RS232 input from GRT EFIS. The
SL70 wants a two-wire shielded cable with shield attached to chassis of both.
One inner wire is "RxD serial input", while the other is "RS232 serial ground
out" The EFIS doesn't appear to have a pin for this, or should I just tie
into a common ground. This doesn't look right since the SL70 is grounded
anyway. I am puzzled....
Jerry Cochran
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun Mar 12, 2006 9:42 pm Post subject: SL70 transponder & Grand Rapids EFIS |
Jerry2DT(at)aol.com wrote:
Quote: | I'm installing a UPSAT SL70 transponder with RS232 input from GRT EFIS. The
Attach the shield at only one end. It is just a shield, not a ground or
return line.
Quote: | One inner wire is "RxD serial input", while the other is "RS232 serial ground
Tie the "RS-232 ground out" on the SL70 to ground on the EFIS. Connect
the RS-232 data terminal on the SL70 to the RS-232 out on the EFIS. It
may be that the RS-232 input on the SL70 has its own floating ground
(perhaps opto-isolated) in order to eliminate ground loops.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
