bhumphreys(at)stonetek.co Guest
Posted: Fri Aug 15, 2008 5:57 pm Post subject: Vstab Forward Spar |
Quick question, as I can’t find where it says to do it in the plans.
The vertical stabilizer forward spar (VS-1002) does not explicitly say that the flange should be dimpled, but I assume it should be as the skins are dimpled. Just checking myself.
Brent Humphreys
Stone Technologies
O: 417-255-0422
M: 314-477-3400
3.38 KB |
3080 Time(s) |
jcumins(at)jcis.net Guest
Posted: Fri Aug 15, 2008 6:22 pm Post subject: Vstab Forward Spar |
Brent
In the manual it will in one of the steps. I am in the same process that you are and the steps will guide you properly
Contact me off list if you like I will look it up and see if I can find it
It is after you final drill the skin.
John G. Cumins
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brent P. Humphreys
Sent: Friday, August 15, 2008 6:57 PM
Subject: Vstab Forward Spar
Brent Humphreys
Stone Technologies
O: 417-255-0422
M: 314-477-3400
3.38 KB |
3081 Time(s) |
Posted: Fri Aug 15, 2008 6:30 pm Post subject: Vstab Forward Spar |
Sec 6 pg 5
Log Entry:
Step 7 Dimple front spar and nose ribs
Step 8 CS VS 1003 rear spar which are common to VS 1001
Step 9 Disamble rear spar debur all holes
Step 10 Finish dimple VS 1003
Step 11 Final drill rudder attach holes as per plans
Hope this helps Brent
John G. Cumins
Brent Humphreys
Stone Technologies
O: 417-255-0422
M: 314-477-3400
3.38 KB |
3081 Time(s) |
brenthumphreys
Posted: Sun Aug 17, 2008 10:45 am Post subject: Re: Vstab Forward Spar |
Thanks.
I was scanning looking for the part number, and didn't find it.
