naumuk(at)alltel.net Guest
Posted: Thu Aug 14, 2008 4:12 pm Post subject: Mid top pucker final |
All-
OK, here's how I did it. This is assuming you already have the hoop holes and the formers drilled:
1. Cleco everything you've got holes for. Leave the last foot or so foreward of the mid top undrilled.
2. Install the cockpit side.
3.Work the "Bubble" out of the mid top aft to front. Drill and Cleco the center of existing holes afterwards. Pitch 20 or 30 by the time you're done doubling. Zero gap at the hoop a necessity.
Bill Naumuk
Townville, Pa.
HDS 601MG/Corvair 95%
118.91 KB |
397 Time(s) |
117.45 KB |
377 Time(s) |
Posted: Thu Aug 14, 2008 5:58 pm Post subject: Mid top pucker final |
Excellent Bill!
You finally beat it into submission. Congratulations.
Looks really good!
Bill Naumuk wrote:
| Quote: | All-
Bill Naumuk
Townville, Pa.
Afterfxllc(at)aol.com Guest
Posted: Thu Aug 14, 2008 6:07 pm Post subject: Mid top pucker final |
Are you guys using .016 or .025? I had zenith replace my .016 and like the way .025 comes out much better. I built the first one using .032 and it turned out really nice but the draw back was I kept the rear skin .016 and it dents really easy so on the ones I build now I use .025 on the rear and .025 on the front also.
I am going to split the canopy like the new style on this 601 and might cut back some of the turtle deck and will also install the new latching system.
Jeff
Looking for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
Posted: Fri Aug 15, 2008 2:14 pm Post subject: Mid top pucker final |
Jeff-
.020. I figured it would be too hard to make a nice looking bend at the front of the hoop with .025.
This is actually my third mid top. My original kit material was too corroded to leave on, but I used it to make a pattern, then transferred it to another piece of .016. Didn't like the way the .016 dimpled when riveted around the hoops and formers so I tore everything down and went with the .020.
Bill
Posted: Fri Aug 15, 2008 2:30 pm Post subject: Mid top pucker final |
Larry-
Third time's charm! This weekend is it. If I can finish the mid top
successfully, the sheet metal work is essentially done. And to think I did
it in only 5-1/2 years!
Bill
