gary.algate(at)sandvik.co Guest
Posted: Sun Aug 10, 2008 10:29 pm Post subject: Timing gear |
Interesting comments here re fretting of crank and timing gear for engines with the smaller flywheel bolts and no dowels. Sounds as though even the new recommended torque settings might be understated?
Gary
http://contrails.free.fr/engine_jab_bolts.php
Gary Algate
SMC, Exploration
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission. [quote][b]
Lynn Matteson
Posted: Mon Aug 11, 2008 6:22 am Post subject: Timing gear |
Yeah that was a real interesting period in the Jabiru history. There
was a lot of back and forth among the Yahoo Jabiru Engine group,
involving a spirited debate among several people, one of whom was
quite "vocal", and it turns out he didn't even own an engine. It all
revolved around how much to torque the bolts...how much it took
before they stretched, how much 620 Loctite to put on the threads,
where to put it, etc....and finally it died down and went away. I
followed the Service Bulletin as did Michel in Norway, he even going
so far as to post his pictures in his site, I believe. He can
probably fill us in better on his involvement...Michel?
Bottom line for me was that I had the larger bolts and the dowels
already in place, and only had to change the bolts, Loctite, and re-
torque to comply with the SB. That was in Dec. of 2006, back when I
had about...guessing....175 hours on the engine.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded, but determined to try." (Pink
Floyd..."Learning to Fly")
On Aug 11, 2008, at 2:27 AM, gary.algate(at)sandvik.com wrote:
Gary
Gary Algate
SMC, Exploration
arise as a result of the e-mail transmission. _-
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Mon Aug 11, 2008 11:32 am Post subject: Timing gear |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
He can probably fill us in better on his involvement...Michel?
Well, when the Service Bulletin came, I rang my Norwegian Jabiru dealer and asked him how to procede. I did exactly what he told me, then published it with photos in the purpose to make it easier for other owners.
But then someone meant that I should not have used the old bolts but buy new ones. Perhaps but the SB doesn't mention that and ... where to buy such bolts in a tiny country like Norway?
Anyway, the Yahoo Jabiru list had a few people who were out to do as many damage as possible and even one - as Lynn says - who didn't even own a Jabiru motor but ... he was quite good at writing and spreading doubt about the engine.
Unlike Lynn who gets high on the smell of engine oil, I don't know much about those things. But I can't understand why a company - any company - refuses customer support. It doesn't make sense and the world in not divided into the stupid bad people and the intelligent nice ones. Any engine manufacturer wish his customers to be pleased because hangar talk is the best marketing tool in sport aviation.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded for the moment
_________________ Kitfox 3 - Jabiru 2200 |
Posted: Mon Aug 11, 2008 4:02 pm Post subject: Timing gear |
Damn - I thought I might have been on to something!
I also spoke with Wayne Johns (Jabiru Service Tech) again and he asked if you were "gluing" the rotor buttons onto the spindles in the Distributor. Evidently it was found that if the rotor buttons aren't fitted with an epoxy or cicoflex they would wear slightly and then rattle on the spindles. This can result in a harmonic vibration thru the gear train that wears the drive gears. In a few cases the hard case was worn from two areas of the teeth resulting in failure.
1 last point - do you have the cast cam shaft or the machined cam shaft - on earlier engines the cast camshaft was found to be weaker and it was replaced with a fully machined component. When I was considering updating my engine S/No 340 he told me that i should upgrade to the machined cam shaft! - maybe something to consider.
By the time I looked at the cost of upgrading my engine it made more sense to go for a new (0) time replacement. Not that I had any problems with mine.
Like most experimental engines (including Rotax) these engines continue to evolve - I think this is why the more traditional Aero engines still look the same and basically operate the same as they did 40 yrs ago.
No change = no risk = no liability
Gary
Gary Algate
Classic4 jab2200
Lynn Matteson <lynnmatt(at)jps.net>
Sent by: owner-kitfox-list-server(at)matronics.com
12/08/2008 12:01 AM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: Timing gear
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Regards
> Gary
> Gary Algate
> SMC, Exploration
Lynn Matteson
Posted: Tue Aug 12, 2008 6:34 am Post subject: Timing gear |
I began gluing the rotors on after I got over being stubborn about
NOT doing it....I had a couple start flopping around, and finally
figured maybe Jabiru knew what they were talking about, even though
it sounds ridiculous.
I gotta say that Jabiru can point to every drop of flys**t that lands
on the engine and claim that that's what caused the problem! For
example, they say that my problem might have been caused by the
extra clearance on the drive pins on a Sensenich propellor. Yet
Sensenich claims that the prop is not driven by the drive pins/lugs,
but by the torque of the bolts which creates a friction between the
drive flange and the back of the prop. Jabiru has you check the
torque every 100hrs, while Sensenich wants it done every 50 hrs. If
Jabiru was so concerned about this prop issue being a problem, why
don't they warn you to check torque more often? Nuff said about that
for now.
I have the fully machined cam....no signs of it being a casting in
any way, as compared to all the cams I've seen in my life. It is the
only other cam I've seen that WAS fully machined besides a roller
tappet cam that I once had in a Hemi.
Gary, if you would, please ask Wayne why doesn't Jabiru make the
timing gear on the crankshaft fit with a slip fit over the end of the
crankshaft, instead of it being squeezed between the end of crank and
the flywheel? That way the nose of the crank would absorb the load
behind the crank gear, instead of it being just hanging there in
space so to speak. Also, ask him if the addition of Loctite 620 or
some other suitable product would be recommended to use to fill the
space between the nose of the crankshaft and the inside of the
crankshaft gear, right behind the gear teeth. I'm concerned about
this seeming space back there, and having another gear failure.
Perhaps the gear does bear up against the crankshaft at that point
but I can't tell because my gear doesn't show contact there...at
least as far as I can tell looking at the broken pieces.
I'm also pondering the feasibility of going with a reconditioned
engine, but I'd rather put this one back together and let it prove
itself.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 11, 2008, at 8:01 PM, gary.algate(at)sandvik.com wrote:
in failure.
problems with mine.
did 40 yrs ago.
Gary
Gary Algate
Classic4 jab2200
12/08/2008 12:01 AM
Please respond to
To
cc
Subject
Re: Timing gear
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
understated?
> Regards
> Gary
> Gary Algate
> SMC, Exploration
N369LM |
Michel
Posted: Tue Aug 12, 2008 10:12 am Post subject: Timing gear |
Lynn, they can't do anything else but that. If they admit that the engine has a weak point, they risk a liability suit from each and every owner and it would mean bankrupcy and closing of the plant. On the other hand, when they know that there is a weakness with the engine, they have to publish a service bulletin but trying to make you think that it is not their fault. That's the way business works.
If the tobacco industry had to admit that their product has killed thousand of people, they may as well close the factories before going to trial. They know that, the judges know that and that's why no one is winning a case against the tobacco industry.
This being said, I understand very well how you feel and how you wish Jabiru should fix your problem. But look at the bright side; if it will cost you some money, you are still a good mechanic and you will put back your engine together in no time. If the same had happened to me ... I would have to ask you to come to Norway in order to fix my engine because I don't know anything about it. Of course, it would be wonderful to meet you but ... it would be a long way for me to go before I am back in the air ... if I ever will.
Michel
patreilly43(at)hotmail.co Guest
Posted: Tue Aug 12, 2008 12:37 pm Post subject: Timing gear |
Lynn C Just get a 582 with less moving parts to worry about that out climbs that 912 with 15 less HP and costs 1/2 as much.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | Date: Tue C 12 Aug 2008 20:11:42 +0200
Subject: RE: Timing gear
Lynn C they can't do anything else but that. If they admit that the engine has a weak point C they risk a liability suit from each and every owner and it would mean bankrupcy and closing of the plant. On the other hand C when they know that there is a weakness with the engine C they have to publish a service bulletin but trying to make you think that it is not their fault. That's the way business works.
If the tobacco industry had to admit that their product has killed thousand of people C they may as well close the factories before going to trial. They know that C the judges know that and that's why no one is winning a case against the tobacco industry.
This being said C I understand very well how you feel and how you wish Jabiru should fix your problem. But look at the bright side; if it will cost you some money C you are still a good mechanic and you will put back your engine together in no time. If the same had happened to me ... I would have to ask you to come to Norway in order to fix my engine because I don't know anything about it. Of course C it would be wonderful to meet you but ... it would be a long way for me to go before I am back in the air ... if I ever will.
Cheers C
Michel
<pre><b><font size=2 color="#000000" face="courier new Ccourier">
ist">http://www.matronics.com/Navigator?Kitfox-List</a>
&ntribution">http://www.matronics.com/contribution</a>
</b></font></pre></body></html>
Lynn Matteson
Posted: Tue Aug 12, 2008 12:49 pm Post subject: Timing gear |
You're right of course, Michel, and because it's a rarity for that
gear to break, that makes it even more "my fault." But I'm going
ahead with the parts cleanup, making an inventory of what I need to
order, and getting on with it. I'm not crying in my beer, just
letting off a little steam. Who knows, maybe if Jabiru sales fall off
for the next few weeks, they'll send me free/cheap parts as a symbol
of truce, hoping I'll call off the dogs. (Yeah, right, as if what I
could do here could possibly hurt them....HAH!)
When this is all said and done, I doubt you'll be reading a lot of my
posts encouraging folks to buy any particular engine...I love the
little s**t, but love can carry you only so far.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 12, 2008, at 2:11 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
Michel
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
</b></font></pre>
N369LM |
Lynn Matteson
Posted: Tue Aug 12, 2008 1:07 pm Post subject: Timing gear |
2-stroke? I'll pass, Pat...thanks. My ears like the semi-low steady
drone of a 4-stroke at low rpm, sucking minimal fuel. Climb is not
that important to me, as I like to get away from the pattern and go
places. And when this airplane bug crawled up my backside, it carried
a sign saying "Do something different...don't follow the crowd", so
I'm stickin' to that anthem, for better or worse....besides, don't
the mighty 582's also fail from time to time? Even when I was flying
model airplanes, I went for a 4-stroke as soon as I could find
one...I like the sound, for whatever that's worth...and it's worth a
lot to me. Just for what it's worth, I never got on the Chevvie V8
bandwagon either, choosing to beat them with my Oldsmobile, and later
Chrysler Hemi engines (yeah I know, I climbed on THAT bandwagon) : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 12, 2008, at 4:36 PM, patrick reilly wrote:
| Quote: | Lynn, Just get a 582 with less moving parts to worry about that out
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Tue, 12 Aug 2008 20:11:42 +0200
> From: michel(at)online.no
> To: kitfox-list(at)matronics.com
lands
business works.
> Cheers,
> Michel
> <pre><b><font size color="#000000" face="courier new,courier">
> </b></font></pre>
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
N369LM |
Posted: Tue Aug 12, 2008 3:17 pm Post subject: Timing gear |
I'll call Wayne today and get this email to him and get him to respond.
regards
Gary
Gary Algate
SMC, Exploration
13/08/2008 12:13 AM
Please respond to
Subject
Re: Timing gear
for now.
itself.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> in failure.
> problems with mine.
> did 40 yrs ago.
> Regards
> Gary
> Gary Algate
> Classic4 jab2200
> 12/08/2008 12:01 AM
> Please respond to
> To
> cc
> Subject
> Re: Timing gear
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> understated?
> > Regards
> > Gary
> > Gary Algate
> > SMC, Exploration
Posted: Tue Aug 12, 2008 3:31 pm Post subject: Timing gear |
Lynn - interesting what you said about Model airplanes - that's how I got started in this hobby. Like you I also went from 2 stroke to 4 stroke engines the last few planes I built were 1/3 scale and I has a Seidel 9 cylinder / Seidel 7 Cylinder a Pegasus 4 cylinder and a couple of 120's. That little lot would more than pay for a brand new Jab 2200 or a 912!
Sweet sound though and bloody reliable
Gary
Gary Algate
Classic 4 Jab2200
13/08/2008 06:47 AM
Please respond to
Subject
Re: RE: Timing gear
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Do not archive
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
> lands
> business works.
> > Cheers,
> > Michel
> > </b></font></pre>
> contribution_-
Posted: Tue Aug 12, 2008 3:53 pm Post subject: Timing gear |
Lynn C Yeah C I like the 4 stroke sound too. I still prefer two stroke dirt bikes though. I don't think I mentioned it C but I bought a Wittman tailwind W10 4 or 5 months ago with a Lyc 0-290. It needs a little tlc but after I get the Kitfox up I will get the W10 going for extended trips and the fox will be outfitted as a bush plane.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: RE: Timing gear
Date: Tue C 12 Aug 2008 17:07:29 -0400
2-stroke? I'll pass C Pat...thanks. My ears like the semi-low steady
drone of a 4-stroke at low rpm C sucking minimal fuel. Climb is not
that important to me C as I like to get away from the pattern and go
places. And when this airplane bug crawled up my backside C it carried
a sign saying "Do something different...don't follow the crowd" C so
I'm stickin' to that anthem C for better or worse....besides C don't
model airplanes C I went for a 4-stroke as soon as I could find
one...I like the sound C for whatever that's worth...and it's worth a
lot to me. Just for what it's worth C I never got on the Chevvie V8
bandwagon either C choosing to beat them with my Oldsmobile C and later
Chrysler Hemi engines (yeah I know C I climbed on THAT bandwagon) : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: "Condition grounded C but determined to try." (Pink
> Do not archive
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
> lands
> business works.
> course C it would be wonderful to meet you but .. it would be a
> > Cheers C
> > Michel
> > </b></font></pre>
> ========== _-
> contribution_-
Michel
Posted: Wed Aug 13, 2008 3:34 am Post subject: Timing gear |
I understand you perfectly, Lynn. I must say that your engine failure and John Miller's failure - two airmen I respect highly - put a shade on my opinion of the Jabiru. But ... do we hear of those who are happily flying? I need some statistics to make my mind.
Yesterday I did the mistake to read the side effects of the drugs I take now after my heart attack. That can really scare the hell out of an innocent man! There isn't an ailment that is not on the list of possible side effects! Did you know that a side effect of beta-blockers is ... heart attack? What the ****! I take those to avoid a new heart attack and ... they can provoke it!
Sometimes in life it is better to stop reading!
Michel Verheughe
Norway
Lynn Matteson
Posted: Wed Aug 13, 2008 5:07 am Post subject: Timing gear |
Man, you WERE into the big buck engines! I had a few of the O.S.
4's....a 70, a 52, a 91, but my favorite engine is the YS 120 AC,
that is in my P-40.
Before I got the Kitfox bug, I was working on a Stinson Reliant, and
debated putting the O.S. 4-cylinder engine in it...then I got
sidetracked by the Kifox....
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 12, 2008, at 7:31 PM, gary.algate(at)sandvik.com wrote:
Gary
Gary Algate
Classic 4 Jab2200
13/08/2008 06:47 AM
Please respond to
To
cc
Subject
Re: RE: Timing gear
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> Do not archive
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
> lands
> business works.
will.
> > Cheers,
> > Michel
> > </b></font></pre>
> contribution_-
N369LM |
Lynn Matteson
Posted: Wed Aug 13, 2008 5:13 am Post subject: Timing gear |
I'm thinking that the 2-stroke bike makes a good dirt bike, but I'd
want a 4-stroke for the long hauls...similar to how I feel about the
airplane engines. I know I'll get arguments against that thinking,
but that's me.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 12, 2008, at 7:53 PM, patrick reilly wrote:
| Quote: | Lynn, Yeah, I like the 4 stroke sound too. I still prefer two
stroke dirt bikes though. I don't think I mentioned it, but I
bush plane.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Tue, 12 Aug 2008 17:07:29 -0400
carried
later
> Lynn Matteson
> Kitfox IV Speedster
> Jabiru 2200
> do not archive
out
> > Do not archive
> > Pat Reilly
> > Mod 3 582 Rebuild
> > Rockford, IL
that
> > lands
trying
> > business works.
will.
> > > Cheers,
> > > Michel
> > > </b></font></pre>
> > ========== _-
> > contribution_-
contribution_-
N369LM |
Lynn Matteson
Posted: Wed Aug 13, 2008 5:39 am Post subject: Timing gear |
They say that the only people on the groups/lists are the ones having
problems, the others are out flying. I seem to have a lemon of an
engine. First a distributor shaft seal wore a groove into one of the
shafts, causing an oil leak that saturated one of the caps, then the
rocker arm bushings went to hell, now the timing gear breaks, causing
me major engine work.
In every case, I got the "rare and unusual" answer back from Jabiru.
So now I just rebuild and fly and hope others don't have the same
problems.
My ownership of this engine got off on the wrong foot when one engine
out of a shipment of 7 was impaled on a fork lift. That engine was
sent back to Aussieland for repair, and I was sent a different
engine, so maybe that started the whole "jinx" thing. : )
John's engine suffered bad valve guides, and he had them replaced,
but they used the old valves, then a valve head broke off, so I'm
going to have my guides replaced and go with new valves.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Michel Verheughe
Norway
</b></font></pre>
N369LM |
dave
Posted: Wed Aug 13, 2008 6:08 am Post subject: Re: Timing gear |
Pat, Not true on equivalent weight Kitfoxes. 582 wil last 300 to 500 hours pretty easy though and yes alot less moving parts. 912 will out climb a 582 if it is light weight and cruise will be able to go faster
Climb performance suffers most from heavy Kitfoxes. This is why the new Kitfox Supersport is more of a cruiser than a STOL Kitfox. I think the model IV was the best Kitfox ever built so far as long as they do not wiigh 700 lbs ++ . But no noemaking now that is advertizing them <snicker>
For example my IV with a 582 on Amphib flaots will leave grass solo in about 400 feet and that wights about 700 lbs empty and still climb 700 fpm + on a 80 to 100F day .
| Quote: | Lynn C Just get a 582 with less moving parts to worry about that out climbs that 912 with 15 less HP and costs 1/2 as much.
?? Do not archive
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Michel
Posted: Wed Aug 13, 2008 10:35 pm Post subject: Timing gear |
Lynn, I am not sure the general Kitfox audience is interested in this but ... here I go:
I have a slight leak on my starboard distributor shaft seal. I got a new seal but ... since I recently epoxy a new rotor in place, I don't feel in a hurry to remove it in order to change the seal. But I am not sure I understand how it can wear a groove on the shaft; it is a plastic seal, right?
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... grounded.
dave
Posted: Thu Aug 14, 2008 3:14 am Post subject: Re: Timing gear |
Michel, Always interested in all aspects of Kitfoxes.
Any seal can wear a steel shaft from continual use. If you are showing signs of seepage now it will only get worse. Shafts can wear from contaminants in the oil as well as dirt,dust from the area of the seal. Crankcase pressure could force oil out as well.
Dave
| Quote: | | I have a slight leak on my starboard distributor shaft seal. I got a new seal but ... since I recently epoxy a new rotor in place, I don't feel in a hurry to remove it in order to change the seal. But I am not sure I understand how it can wear a groove on the shaft; it is a plastic seal, right? |
Lynn Matteson
Posted: Thu Aug 14, 2008 5:39 am Post subject: Timing gear |
It is a flexible seal, made of...I dunno, neoprene or something like
that, and it definitely wore a groove in my shaft. Pictured is the
shaft, with the 2 grooves worn in by the seal, which you can see in
the distributor bottom plate...this is the part that the cap attaches
to. To change the seal, you need to remove the two socket-head cap
screws (also known as Allen bolts over here, after a company that
made them), then remove this plate and drive out the old seal and
press/drive in the new seal, and you're done...well, except for
putting it back together.
But...if you have a worn/grooved shaft like I did, I had to use a
product called Speedi-Sleeve (pictured), which is slid over the
shaft, becoming the new surface upon which the new seal rides. The
sleeve is only .011" thick, so it only increases the diameter of the
shaft by .022" or about half of a mm. This increase in diameter not
only provides a new seal surface, but it increases the tension of the
new seal so it seals better. Mine worked right up to when I took them
off when I dismantled my engine, and I'm thinking of putting them
back on. Now as to why these seals leak, and I'm afraid yours are
going to show worn shafts too, Michel, I'm thinking they don't have a
hard enough shaft to begin with. When/if you pull your bottom plate
(s), don't be alarmed about the sloppiness of the distributor shaft
if you pull the distributor shaft support tower (I call it that)...it
won't get out of time, because the gears will still be in mesh, just
loose until the tower/support goes back on. You can't screw anything
up by taking this area apart and changing the seals, or by installing
the speedi-sleeves. You cannot get the engine out of time. But if you
decide to change the distributor shafts themselves, you will have to
remove the gear case cover, and THAT'S where you can get into trouble
with ignition timing. I can get you through this if you get that far
into it, or so can your Jab dealer friend over there.
It's surprising to me how the soft seal can wear a groove into the
shaft, but here's living proof that it did. My left (port) one is
pictured. The right side leaked worse, but the shaft was unharmed by
the seal...go figure that one out!
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Aug 14, 2008, at 2:34 AM, Michel Verheughe wrote:
| Quote: | Lynn, I am not sure the general Kitfox audience is interested in
Michel Verheughe
Norway
421.17 KB |
536 Time(s) |
N369LM |
