sam(at)fr8dog.net Guest
Posted: Thu Aug 07, 2008 4:02 pm Post subject: LSE Tach |
Ok guy's, I'm at the end of my rope here, I need help. I've tried
everything I can find to make my LSE tach work in conjunction with a
Bendix mag. The mag signal to my EIS6000 works just fine, but the
Lightspeed tach just won't work. I know some of you have it working,
how's it done?
Tim Olson
Posted: Thu Aug 07, 2008 5:40 pm Post subject: LSE Tach |
I just use the LSE only for tach....I skipped hooking the mag
in at all. You can hear by ear if it drops a lot of RPM,
and you can see it on the multi-bar bar-graphs if the temps
start to drop or rise. So there's no real worry to just
have one as long as you listen carefully.
Sam Marlow wrote:
how's it done?
Posted: Thu Aug 07, 2008 6:34 pm Post subject: LSE Tach |
Yes, but it's giving up a good diagnostic tool, and backup. I sure wish
there was a way to have two tach sources.
Tim Olson wrote:
> how's it done?
Dave(at)AirCraftersLLC.co Guest
Posted: Thu Aug 07, 2008 8:32 pm Post subject: LSE Tach |
Sam,
I'm not sure if this is what you're after, but here is a schematic to get
two tach signals into a single input so you can do a mag check and see the
actual indicated RPM.
If you need to convert the LSE signal to something the EIS can handle, I'm
sure either vendor can help you out there.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
Mag_Switch_for_electric_tach_REV_1.pdf |
12.8 KB |
523 Time(s) |
jim(at)CombsFive.Com Guest
Posted: Fri Aug 08, 2008 5:31 am Post subject: LSE Tach |
What about having a switch on the panel to let you select the source (LSE or MAG)?
I do as Tim does. LSE is the only input I use for the tach.
Jim C
N312F - Finishing
Date: 2008/08/07 Thu PM 10:33:29 EDT
Subject: Re: LSE Tach
Tim Olson wrote:
> how's it done?
bcondrey
Posted: Fri Aug 08, 2008 5:52 am Post subject: LSE Tach |
Sam,
You can install a tach generator (look on Van's website) and use that to
feed the EIS. This is a device that uses the mechanical tach drive and
produces an output usable by a variety of engine monitors. It would be
independent of the type of ignition system.
Bob
Tim Olson
Posted: Fri Aug 08, 2008 6:15 am Post subject: LSE Tach |
Yes, there are ways around the problem by adding
complexity, but... The EIS uses a setting of 1.5 Pulses
per revolution (a setting of "0" on the EIS's Tach P/R
field), and the lightspeed provides 3 pulses per rev,
and the EIS Tach P/R gets set to 3. So from the beginning,
you're set up with 2 varying pulse counts that you need
the system set for. So you either need to add circuitry
to modify one, or the other, so that they match. To me,
this is a waste of time and effort for something so
minor. I can see on the tach that when I run on the LSE
only, I get a mag drop of maybe 10-20 RPM. And as soon
as I switch to the mag it does drop a larger drop than
with the EIS only.
The thing is, misfiring or non-firing will be seen on
the EGT gauge too, so you DO have a diagnostic too. And,
the running smoothness of the engine is another diagnostic
tool. With the LSE ignition I haven't EVER had fouled
plugs that caused a rough running mag drop test. I used
to have fouled plugs every few flights on the Sundowner
I flew. It's just not the case with the IO-540 and a
LSE ignition. If I have a large mag drop, I'll know,
because I can hear it. If the mag is running rough, I'll
know...because I can hear it. And, if it's truly not
running good because of a fouled plug on the mag side,
then you'll see the EGT drop off if it isn't firing. I've
watched this on an piper with an avidyne system. In the
end, the actual RPM dropped is really not much help
in diagnosing anything, compared to the EGT graph, and
your calibrated ears. Sure, it's a small trade-off, but
it's one that I definitely don't feel like I'm missing
something with.
jim(at)CombsFive.Com wrote:
Jim C
N312F - Finishing
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> how's it done?
carl.froehlich(at)cox.net Guest
Posted: Fri Aug 08, 2008 6:29 am Post subject: LSE Tach |
Sam
I worked this problem in my 8A six years ago. After talking to Klaus at
LightSpeed and not getting anywhere, I called Grand Rapids. They figured
that the LightSpeed tach pulse was too narrow for the EIS to recognize.
Grand Rapids came up with a modification to the EIS so that it worked with
the LightSpeed signal. The modification was simple, just changing a
resistor on the EIS board that I did myself.
Give Grand Rapids a call.
The superior customer service from Grand Rapids is the main reason I'll be
using their EFIS in my RV-10.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
bcondrey
Posted: Fri Aug 08, 2008 7:05 am Post subject: LSE Tach |
Carl,
The issue isn't the EIS/LSE integration (current versions of the Plasma
III just drive the EIS direct with no mods to either). The issue is as
Tim describes below - the EIS can be configured to expect pulses as
conditioned by either the LSE or mag but not both at the same time.
There are solutions that add complexity - a circuit to change the pulse
counts from one of the devices or a tach generator off the engine's
mechanical tach connection, but in the end it really isn't a big deal to
just drive the tach off of one of the devices.
Besides, if you're unlucky enough to have one of the early MT governors
you get your ears tuned into hearing a 100 RPM engine change
Bob
N442PM (flying)
sam.marlow
Posted: Fri Aug 08, 2008 4:45 pm Post subject: LSE Tach |
The problem with the switch is EIS interitation, the Mag requires a different setting than the LSE.
Jim C
N312F - Finishing
Tim Olson wrote:
> how's it done?
sam.marlow
Posted: Fri Aug 08, 2008 4:46 pm Post subject: LSE Tach |
I'll look into that,thanks for the tip!
---- "Condrey wrote:
Sam,
Bob
sam.marlow
Posted: Fri Aug 08, 2008 4:54 pm Post subject: LSE Tach |
I did that already, didn't help.
---- Carl Froehlich <carl.froehlich(at)cox.net> wrote:
Sam
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
sam.marlow
Posted: Fri Aug 08, 2008 4:58 pm Post subject: LSE Tach |
Yes but without a second source for tach, I've already scrubed a flight, and postponed another for lack of RPM indication,when the "P" lead ground shield worked it's way loose on the mag.
Carl,
Bob
N442PM (flying)
sam.marlow
Posted: Fri Aug 08, 2008 5:04 pm Post subject: LSE Tach |
This is pretty much the way I wired it, but it only works on the mag side with this configuration.
LSE is no help,and I did the EIS mod, still dosen't work.
---- Dave Saylor <Dave(at)AirCraftersLLC.com> wrote:
Sam,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
coop85(at)cableone.net Guest
Posted: Sat Aug 09, 2008 5:32 am Post subject: LSE Tach |
I opted for the switch method and it works well, however the LSE sends 2 pulses for every 1 the mag sends. I set up the EIS to read the LSE info as primary so if I switch to the mag source I have to mentally double the indicated RPM. In all honesty I usually do Tim's method of audio verification of minimal drop in RPM, but I wanted the option if required.
Marcus
Tim Olson
Posted: Sat Aug 09, 2008 6:13 am Post subject: LSE Tach |
Marcus is right. I considered doing the same thing...just
leaving the 2 tach readings being different, and just
remembering that one would read a proportional number to
the other. It would be pretty easy to wire. I just decided
not to bother.....but I think the way he did it would be a
great compromise if someone were interested in both readings,
but didn't want the added cost and LESS reliability of a
mechanical tach sender.
Marcus Cooper wrote:
<coop85(at)cableone.net>
option if required.
Marcus
