AirMike
Posted: Wed Aug 06, 2008 10:14 pm Post subject: Firewall insulation |
Looking for suggestions for a firewall blanket to put on the engine side of the firewall.
I heard a comment at OSH that it would be good (Cooler in Summer) to insulate both the inside and outside of the firewall
_________________ See you OSH '18
Q/B - sold. |
vhmum(at)bigpond.com Guest
Posted: Wed Aug 06, 2008 11:35 pm Post subject: Firewall insulation |
I used coolmat on the firewall side only due to thinking about tunnel heat
problems however the tunnel does not even get warm so maybe it was not
needed . It is winter out here though. I also got rid of those huge heat
muffs that are on the exhausts and just put standard rap around muf saving
at least a couple of Kilos up the front and some perfomance improvement
maybe. Again thinking of tunnel heat which may or may not be a problem to
sum.
rgards chris
VH-ICY 20 hours
Posted: Thu Aug 07, 2008 3:58 am Post subject: Firewall insulation |
I use an insulation sold at www.summitracing.com for about $128/sheet,
I think. Just remember that if you insulate the inside and the
outside, inspection of the firewall itself will be very difficult down
the road. Contact me off-list and I will try to look it up from my
past order(s).
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Aug 7, 2008, at 2:14 AM, AirMike wrote:
OSH '08 or Bust (busted) be there in "09
Q/B Kit - exited cabin top/door purgatory
http://forums.matronics.com/viewtopic.php?p=197071#197071
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
We have installed Kool Mat from Aircraft Spruce. Not flying yet, so
can't report on it. It is pretty heavy stuff, but that is probably a
good thing in our case since we have the air conditioner behind the
baggage compartment.
[IMG]
http://img504.imageshack.us/img504/1665/img1405vk3.th.jpg[/IMG]
David Maib
40559
endless finishing
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
dmaib@me.com
Posted: Thu Aug 07, 2008 4:10 am Post subject: Re: Firewall insulation |
Sorry that photo link did not work. Hopefully this will.
1.2 MB |
588 Time(s) |
RV-10 #40559
brian-douglas(at)uiowa.ed Guest
Posted: Thu Aug 07, 2008 7:35 am Post subject: Firewall insulation |
Pegasus Aeromarine has a firewall blanket as well. I don't know how his
compares to koolmat or others except to say it's sort of expensive.
http://www.pegasusaeromarine.com/aircraftSystems/rv10/index.html
-Brian
Iowa City, IA
#40497
[quote] --
pascal(at)rv10builder.net Guest
Posted: Thu Aug 07, 2008 8:33 am Post subject: Firewall insulation |
Also from summit racing, I am following Chris Johnson in the use of
Lizardskin spray on insulation. I'll be putting it on both sides of the
firewall. Takes care of the corrosion issues so no need for priming. Pretty
inexpensive when compared to mats.
http://www.lizardskin.com/pages/testimonials2.php
Pascal
Sent: Thursday, August 07, 2008 4:57 AM
Subject: Re: Firewall insulation
I use an insulation sold at www.summitracing.com for about $128/sheet, I
think. Just remember that if you insulate the inside and the outside,
inspection of the firewall itself will be very difficult down the road.
Contact me off-list and I will try to look it up from my past order(s).
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> of the firewall.
wcurtis(at)nerv10.com Guest
Posted: Thu Aug 07, 2008 8:39 am Post subject: Firewall insulation |
Wow, I thought the Soundex Products stuff for the RV10 was expensive. These guys must think they are selling to the Lancair crowd. The picture on the web page kind of also reinforces that.
http://www.soundexproducts.com/order.html
William
http://nerv10.com/wcurtis/
