BnC Continuous Duty Contactor 12 v
jskiba(at)icosa.net
PostPosted: Sun Jul 27, 2008 1:52 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
Does anyone know how much current the Continuous Duty Contactor 12 v listed
at the B n c Website can handle ?
I tried looking for some kind of data sheet but could not find one...
Does it handle better than 130 amps ?
May 90 ?
Help anyone please.
The specs they do list are:
This contactor is suited for most applications in amateur built airplanes
calling for continuous duty operation including (1) battery master contactor
(2) ground power contactor (3)alternator b-lead overvoltage protection (4)
dual alternator system crossfeed contactor [order S701-2] and (4)
extend/retract control in hydraulic landing gear systems. Supplied with
spike suppression diode and battery terminal jumper already installed. Coil
resistance is 15 ohms. Contactor Weight is 13 ounces
This contactor terminals will use a .31 and #10 ring terminals.
rshannon
PostPosted: Sun Jul 27, 2008 4:35 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
Jeffrey,
I don't know the max. continuous rating, but I'm sure it's well in excess of 100A, way more than you would ever need in any usual homebuilt airplane. Of course, intermittently, it will handle a lot more than that, including full starter motor loads. Why not just give B&C a call tomorrow and ask them.
Ron
On Sun, Jul 27, 2008 at 2:46 PM, Jeffrey W. Skiba <jskiba(at)icosa.net (jskiba(at)icosa.net)> wrote:
[quote] --> AeroElectric-List message posted by: "Jeffrey W. Skiba" <jskiba(at)icosa.net (jskiba(at)icosa.net)>
View user's profile Send private message AIM Address Yahoo Messenger
nuckolls.bob(at)cox.net
PostPosted: Sun Jul 27, 2008 6:29 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
May 90 ?
See:
http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_70-Series.pdf
The S701-1 contactor is a Stancor 70-902. It's rated for
80 amps continuous. But like all switches, relays and
contactors, the ratings assume that you're going to SWITCH
those loads. In the case of a battery conactor, loads seldom
exceed tens of amps when the battery master is turned on.
By the time the starter is engaged, the battery contactor
is closed and stable. An alrady closed switch will carry
several times its rated current for short periods of time
(like cranking an engine) without serious degradation of
service life.
How are you using it that its ratings are a concern?
( -Thomas Paine 1776- )
jskiba(at)icosa.net
PostPosted: Mon Jul 28, 2008 4:39 am    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
See:
Series.pdf
service life.
I am using it as a battery contactor but with a Very High out alternator,
200amps ..... So I am thinking I need to find a bigger contactor ? or my
other thought - guess was maybe to run TWO Stancor 70-902 contactors in
parallel ? with the extra wires also... but concern here is that something I
haven't thought of will smoke something if both are not closed ?
Maybe I am overlooking a simple cheaper solution....
Eric M. Jones
PostPosted: Mon Jul 28, 2008 6:33 am    Post subject: Re: BnC Continuous Duty Contactor 12 v Reply with quote
I have railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines.
Problems--
1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part.
2) Not sealed. Not dust proof, or fuel proof.
3) Low interrupt capacity.
4) High hold current---16 ohm coil. Almost one amp.
5) Low hold force. The specifications call for specific orientation. 2G rating?
6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts.
7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications)
See: www.stancor.com
There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred.
Can you use them? Sure. Should you use them?....not on my bird, Bubela.
Better yet, avoid all contactors and use manual switches if you can.
"Facts do not cease to exist because they are ignored."
---Aldous Huxley
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
Michael Wynn
PostPosted: Mon Jul 28, 2008 3:37 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
The below is entirely new to me. Could someone with more experience and knowledge than me (that would be almost anyone, but especially Mr. Nuckolls) comment on it?
Michael Wynn
RV 8 FWF
San Ramon, CA
In a message dated 7/28/2008 7:39:15 A.M. Pacific Daylight Time, emjones(at)charter.net writes:
Problems--
---Aldous Huxley
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
Michael Wynn
RV 8
San Ramon, CA
jskiba(at)icosa.net
PostPosted: Mon Jul 28, 2008 7:43 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
I looked at some of those below and found this in the process:
http://www.trombetta.com/cm/pdfs/defender-family.pdf
Anybody use one of these?
Looks like they can be had for fairly cheap and have some type of TVS
(Transient Volt Suppression) built in!
Looks like it's a little heavier than some of the more expensive ones, so I
guess that's the trade off for cost.
Thoughts?
Jeff.
<emjones(at)charter.net>
lines.
Problems--
rating?
preferred.
klehman(at)albedo.net
PostPosted: Tue Jul 29, 2008 4:00 am    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
The Trombetta mentioned below looks like a type 70 in an expensive
package to me.
In a nutshell my thoughts on the type 70 criticism are:
some of it is true, most of it is irrelevant.
Type 70 contactors are widely available, affordable, and no real risk
with aeroelectric architecture except perhaps for a B lead overvoltage
interupter with an IR alternator. Sure I might have to replace one of
mine in my lifetime. I think I have a spare $14. unit in stock from the
local hardware store but I'd also expect to find one at most any airport
if needed.
However if Eric or anyone wanted to suggest a particular "cheap" or
value priced Omron part number or series, I would check it out for cost
effectiveness and reasonable availability and interchangeability.
Lots of discussion in the archives Michael but I would not hesitate to
use the type 70's in a new design for the time being. Better stuff is
available at a price but I haven't seen anything that has a cost and
availability of interest to me yet.
Ken
Thoughts?
Jeff.
lines.
Problems--
rating?
preferred.
PostPosted: Tue Jul 29, 2008 4:38 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
No paralleling . . . it's not practical. Yes . . . you
need a contactor rated for the task. In the el-cheeso
line of contactors, the Stancore 586-902 is rated for
this service and should be a good value. See:
http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_586-Series.pdf
You can get these for about $50 from Allied Electronics at:
http://tinyurl.com/5bxtnm
If you're interested in "stepping up", these are equally
suited to the task:
Cutler-Hammer 6041H105
http://aeroelectric.com/Mfgr_Data/Contactors/Eaton_CH/6041SeriesPowerRelays.pdf
or Tyco Killvac EV200
http://aeroelectric.com/Mfgr_Data/Contactors/Tyco_Kilovac/ev200.pdf
Be advised that some builder's have reported noise from
the "power saver" feature on the EV-200 that required
filtering. Easy to do should it become necessary.
PostPosted: Tue Jul 29, 2008 5:08 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
their lines.
Problems--
Neither are most of the switches, contactors, even
alternators that have been used with great success
for decades.
But they're never asked to interrupt anything but normal
pre-parking currents in aircraft . . . maybe 10A? For a
time, the TC aircraft industry attempted to use the
intermittent duty versions of these contactors for starter
control service and found them unsatisfactory.
However, they have proven a good value (I didn't say lasts
forever) in light aircraft battery contactor service.
In other words, the 8x more expensive 6041H series mil
spec contactors did not last even 4x as long. Given the
exceedingly light duty cycles expected from these devices
the way we use them (in failure tolerant systems) they
are of good value.
Which is not an issue as long as the alternator
is running . . . you have power to burn. When the
alternator is not running, this device is turned
off for endurance mode operations.
2G rating?
I've tested these at over 12g. Where do you find any recommendations
with respect to g-loading. I can tell you that the vertical orientation
is to reduce potential for moisture ingress due to coindensation and/or
splash . . . as you've noted, they are not sealed. As a battery contactor,
they are closed in all phases of flight and exceedingly difficult to
force open with g-loads.
I've also demonstrated that this is not true.
True . . . and not recommended to routinely SWITCH such
loads but will be just fine as suggested on the third page
of:
http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
where we will routinely switch the alternator ON and OFF at will
without exceeding the contactors rated operating conditions.
preferred.
Preference is another matter entirely . . . and when
it comes to preferences, I'll concede to anyone's desires.
I've even cited alternatives that include the Kilovac
EV200. But let us not resort to generating climates of fear
on the part of the neophyte airplane builders. The track
record on this part for return on investment has been exemplary.
By all means sir . . .
This IS a stretch Eric. It's true that contactors are the
most highly stressed devices on an airplane after generators
and followed by alternators. It's also true that they are
a significant maintenance item on EVERY airplane from the
C-150 through the Hawkers. But so are tires, batteries,
generators, etc. The artfully crafted system tolerates
these service life limitations without placing the aircraft
or occupants at risk. Can we really recommend that anyone
resort to manually operated high current switches (bring
high current conductors within reach of pilot) just to avoid
a service-life issue on a 100-our a year airplane?
---Aldous Huxley
Absolutely! Please separate deeply held beliefs from demonstrable
fact. I have outlined the facts . . . which of these do you
find to be in error?
PostPosted: Tue Jul 29, 2008 5:11 pm    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
These should be entirely suitable for use as
battery contactors in the OBAM aircraft.
Eric M. Jones
PostPosted: Wed Jul 30, 2008 6:00 am    Post subject: Re: BnC Continuous Duty Contactor 12 v Reply with quote
Bob,
I would use a Type 70 for a puddle jumper of no particular consequence. I agree that they have been used for decades. They are not competitive anymore. I aim for designs where "carrying a spare" is not a requirement for a part, where "better" can be had for not much money. "Better" in my world is defined as "greater capability, wider specs, longer life, higher reliability...etc." Maybe even "similar specs, lighter weight...." Not all builders care about this.
>Problems--
>1) Low Temperature rating. Only 122F max. You could land at Furnace >Creek in Death Valley in May and take off in October. Maybe. This is >primarily due to the Nylon innards. This is a drop-dead reason to avoid >the part.
for decades.
Bob, that's partially true, but Kilovacs and Gigavacs can shut off your battery whilst saturated in fuel. They can also shut off a runaway alternator. They will last forever. They cost more. They have lower hold currents. They use bidirectional Zeners for coil suppression. Nice, huh?
You are referring to a specific application. I referring to general applications.
are of good value.
I don't disagree. They are a good value. But Omron contactors (50A) http://tiny.cc/sXDp3 are a 3X better value and are tiny in comparison. The Type 70 is long in the tooth. As you recall this latest brushfire was sparked by troublemaker Jeff Skiba poking around to get information on higher current performance. He started this....
An ampere here, and ampere there...pretty soon you have real power waste. Our philosophies differ. I remember in 1960 when you could buy surplus aircraft and they'd come with full fuel tanks. Not anymore.
>2G rating?
I've tested these at over 12g. Where do you find any recommendations with respect to g-loading. I can tell you that the vertical orientation is to reduce potential for moisture ingress due to condensation and/or splash . . . as you've noted, they are not sealed. As a battery contactor, they are closed in all phases of flight and exceedingly difficult to
You could be right on this. Type 70 specs are impossible to get on this, (and believe me I've tried). I interpret the orientation spec to be a g-load concern. But Kilovac and Gigavac and others always spec g-load. Usually 10g's.
As I said Bob, you are wonderfully on-the-mark about thousands of things, and only wildly wrong about only a few.
One Hundred Dollars U.S. to your favorite charity and a jar of jalapenos to you if an agreed upon third party will test the type-70 contactor using 1N5401 Diodes vs. 18V SnapJacks for coil suppression in an agreed upon test. My winning requires you to never again espouse this bonehead notion.
of:
> (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. >Expensive but preferred.
Bob, Stretching is a good, but not necessary thing. I recommend to my builder-friends using a Flaming River racecar battery switch to satisfy the FAA for the one-hand battery disconnect. That's what's going into my Glastar. No contactor needed. Most other contactors can go bye-bye too.
"Everything you've learned in school as 'obvious' becomes less and less obvious as you begin to study the universe. For example, there are no solids in the universe. There's not even a suggestion of a solid. There are no absolute continuums. There are no surfaces. There are no straight lines."
-R. Buckminster Fuller
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
PostPosted: Wed Jul 30, 2008 8:37 am    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
At 07:00 AM 7/30/2008 -0700, you wrote:
Bob,
Don't now how to quantify "competitive". Hundreds
of thousands of airplanes have flown with this contactor
and I doubt that few if any owners felt compelled to
"carry a spare". Yes, I CAN select from a variety of
products with "better" specs . . . but in the final
analysis, how does this affect John Q Pilot's utility
realized from his airplane? I'm aware of NO contactors
suited for battery service that are smaller, noise free,
and deliver better life for the dollars spent. You've
stirred a lot of un-quantified superlatives into this
stew.
> for decades.
Sure . . . but how many battery contactors have ever been
asked to open the battery while fuel-soaked? The hold current
electronics duty cycle switches the coil circuit and proved
to be a noise issue in at least one instance. I was hoping
to get one into the lab to look at DO-160 conducted and
see how much filter was needed to quiet the puppy down.
If I were searching for stretched convictions, I might
offer that the electronics in the EV200 were vulnerable
to lightning strike.
applications.
The man was asking about a battery contactor. I was
addressing that question. I added a note that
the manner in which a b-lead contactor would be used
in a proposed alternator controller, the type 70
would be suited for that task too. The ONLY places where
the venerable type 70 has been recommended for
consideration in a Z-figure are situations where
it is not required to SWITCH a heavy load, only
CARRY them. Starter contactors are another application
that demands special consideration.
> are of good value.
That's not a contactor but a fat relay. It IS rated for
switching the same loads as a type 70 Stancor but would
certainly not be suited for battery contactor service
where starter currents are also impressed on the contacts.
Philosophies differ? I'm not real sure what philosophy you're
embracing. I think I've been quite clear as to my own.
>2G rating?
g-load concern.
Can't imagine how you get this. Mounting top down adds gravity
to the spring tension and probably increases spreading
velocity by some factor. It also reduces a pooling opportunity
for ingested moisture. But to infer that this orientation
has something to do with consideration of g-loading in
aircraft is a real stretch. 99.9% of all such contactors
manufactured did not go into airplanes. It's a reasonable
extrapolation that their recommendations grew out of
consideration for the mass market applications as opposed
to aircraft.
Those are not g-loading specs but shock and vibration
qualifications.
They do not address resistance to contact motion
while energized/de-energized under linear acceleration.
Folks have often latched onto those g-numbers and
translated them into potential for malfunction during
aerobatic maneuvers. They are unrelated.
If you're going to use spec sheets as a hammer, you
need to interpret them correctly lest the nail you
hit is the one on your thumb.
Make my day . . . show me where I went wrong.
Do your own tests. I've outlined exactly what I did, how
I made and interpreted the measurements. Where do you
find fault with the experiment? I explained in detail how
the authors of the oft quoted article correctly observed
an increase in drop-out delay cased by plain vanilla diodes
and then erroneously extrapolated this fact into a commensurate
reduction in contact spreading velocity (i.e. extended arcing
equals more wear).
It's a simple bench setup . . .
<snip>
Good for you! And yes, the type 70 is a legacy product but
so are all the hammers and screwdrivers in my toolboxes. There
are a host devices that will function as battery contactors.
The Omron relay you cited is not one of them. If we're going
to give advice I'll suggest that it is specific to the
question and includes a suite of choices . . . and refrain
from unsubstantiated fear mongering especially in light
of repeatable experiments that demonstrate otherwise.
Show me where the interpretation of data in the diode vs. spreading
velocity experiment was wrong. Keep in mind too that contact
wear in switches and contactors is more tightly linked
to behaviors in CLOSING the contacts. Here the contacts
bounce . . . close, open and re-close up to a dozen times
in an ever decreasing gap where ARCING happens with each
opening. The coil suppression technology has nothing to do
with contact closing behaviors.
The GX11 Gigavac is an interesting product. I've seen their
RF vacuum relays for years but this was the first time I
was aware of a high current contactor. They don't sell through
distribution but I find that an old friend to mine is their
local rep. I left a voice mail message for him asking about
getting my hands on a GX11BAA. See:
http://aeroelectric.com/Mfgr_Data/Contactors/Gigavac/gx11.pdf
Note that this data sheet speaks to vibration and shock
ratings . . . NOT linear acceleration. Note further that
they do not offer a duty-cycle switched, low holding
current feature. I'll get one on order and look it over.
PostPosted: Sat Aug 09, 2008 7:19 am    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
[quote]Jeff wrote:"I am using it as a battery contactor but with a Very High out alternator, 200amps ..... So I am thinking I need to find a bigger contactor ? or my other thought - guess was maybe to run TWO Stancor 70-902 contactors in parallel ? with the extra wires also... but concern here is that something I haven't thought of will smoke something if both are not closed ? Maybe I am overlooking a simple cheaper solution...."<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> Jeff,The size of the alternator has nothing to do with the current rating of the battery contactor. The ampacity of the battery contactor should be determined by the engine starting current and by the battery charging current. These two currents are the only significant currents normally flowing through the battery contactor. Even if you have a very large load such as an electric cockpit heater, that current would flow directly from the alternator to the heater without going through the battery contactor. Just because the alternator is rated at 200 amps does not mean that it will be supplying that much. The alternator will only be putting out that current which is needed to operate the loads that are turned on, most likely only a fraction of the alternator's ampacity. I would use the same battery contactor regardless of the alternator size.Joe Gores[b]
Joe Gores
PostPosted: Sat Aug 09, 2008 8:25 am    Post subject: BnC Continuous Duty Contactor 12 v Reply with quote
Interesting! Help us understand a bit more about
your proposed system. Under what conditions would
you expect your 200A alternator to deliver this
kind of power. In other words, what design goals
for the vehicle drove the selection of this size
machine?
Jeff,
Joe Gores
Joe is quite correct. The battery contactor must CARRY, not
SWITCH starting currents that include some bodacious inrush
currents. Then it must CARRY, not SWITCH the battery recharge
currents and/or expected battery discharge currents during
alternator-out operations. The 80-amp, lowly 70 series devices
have given good service. But let's be sure that we're not
giving you marginal advice. Do you also plan a big battery?
If the battery is "up-sized" in concert with a larger alternator,
then it follows that your system MIGHT be capable of extra-
ordinary stress on the battery contactor . . . like recharging
a big battery with you 200A energy source.
There are some up-sized contactors not the least of which
are the 586 series devices from Stancor.
. . . but we don't have enough information about your
design goals to make confident recommendations.
