Wanted Drilling/Bolting layout for the NEW type 6B6-4
craig(at)craigandjean.com
PostPosted: Thu Jul 24, 2008 3:04 pm    Post subject: Wanted Drilling/Bolting layout for the NEW type 6B6-4 Reply with quote
I've attached the revised 6B6 dated 8/07 PDF that Caleb sent me.
-- Craig
6-B-6.pdf
 Filename:  6-B-6.pdf
 Filesize:  103.19 KB
 Downloaded:  840 Time(s)
Thruster87
PostPosted: Thu Jul 24, 2008 10:53 pm    Post subject: Re: Wanted Drilling/Bolting layout for the NEW type 6B6-4 Reply with quote
The numbers don't add up too well 14mm is OK then 56mm is OK but then the 40mm [total so far 110mm] lines up with the canopy tang which is 100mm from the end so a no no there,56mm instead of 40mm would work and then 40 or 56mm would be OK. What did you make yours ?Cheers T87
PostPosted: Thu Jul 24, 2008 11:50 pm    Post subject: Wanted Drilling/Bolting layout for the NEW type 6B6-4 Reply with quote
I ignored the plans of course Smile
I had existing holes in the extruded L's that form the upper longerons from
the old-style motor mount brackets. My QBK came with old-style brackets and
the holes for the motor mount bolts through the firewall didn't line up with
the holes in the actual firewall. When Zenith sent me replacement brackets
they sent the new "BRS" style.
More important to me was to not have the rivets through the fuselage side
skins and the L's interfere with getting a washer and nut on the bolts
through the motor mount brackets and the L's. Basically the horizontal
rivets have to be staggered relative to the vertical AN3 bolts.
-- Craig
