naumuk(at)alltel.net Guest
Posted: Mon Jul 21, 2008 4:19 pm Post subject: Altimeters |
All-
What's the difference between a "Sensitive" and a "Non-sensitive" altimeter? Going Dynon for primary, researching backup steam gauges.
Bill Naumuk
Townville, Pa.
HDS Systems/Corvair 95%
Posted: Mon Jul 21, 2008 4:53 pm Post subject: Altimeters |
“Modern aircraft use a "sensitive altimeter" which has a primary needle that makes multiple revolutions, and one or more secondary needles that show the number of revolutions, similar to a clock face. In other words, each needle points to a different digit of the current altitude measurement.”
http://en.wikipedia.org/wiki/Altimeter
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Monday, July 21, 2008 6:16 PM
To: zenith list
Subject: Altimeters
All-
Bill Naumuk
Townville, Pa.
| Quote: | | http://www.matronics.com/Navigator?Zenith-List | 0123456789
jaybannist(at)cs.com Guest
Posted: Mon Jul 21, 2008 4:59 pm Post subject: Altimeters |
Bill,
I have always heard the term "sensitive" applied to altimeters that have the ability to correct for barometric pressure (the Kollsman window) ; and "non-sensitive" to those that didn't have that ability.
Jay in Dallas
bryanmmartin
Posted: Mon Jul 21, 2008 5:06 pm Post subject: Altimeters |
A non sensitive altimeter generally has only one needle to indicate the altitude. It goes from zero to the instrument's maximum reading in one sweep of the needle. A sensitive altimeter has two or more needles to indicate altitude, usually one for hundreds of feet, one for thousands of feet and possibly one for tens of thousands of feet. The sensitive altimeter allows a more precise readout of altitude but costs more than a non sensitive type.
If you do much flying around controlled airspace, the sensitive altimeter makes it easier to avoid accidently violating the altitude limits of that airspace.
On Jul 21, 2008, at 8:15 PM, Bill Naumuk wrote:
| Quote: | All-
Bill Naumuk
Townville, Pa.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
raymondj(at)frontiernet.n Guest
n801bh(at)netzero.com Guest
Posted: Tue Jul 22, 2008 4:52 am Post subject: Altimeters |
Ben Haas
N801BH
www.haaspowerair.com
The "non sensitive" one can stand being yelled at when you are not at the proper altitude..
The "Sensitive" one will pack its bags and move home to her mother.....
jmcburney(at)pobox.com Guest
Posted: Tue Jul 22, 2008 6:11 am Post subject: Altimeters |
Hi, Bill,
All said before re: sensitive vs nonsensitive altimeters is right, but the
Kollsman window post is the critical one. ATC wants you to maintain
altitude ref MSL, which you CANNOT do in the air unless you can set your
altimeter to local barometric pressure. So if you go X/C or the barometer
changes while you're aloft, you have no reference. It also helps to know
your height above ground when you approach to land! Get a sensitive
altimeter -- the others are for J-3 restorations.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Tue Jul 22, 2008 6:34 am Post subject: Altimeters |
Hello,
What about this one?
http://www.aircraftspruce.com/catalog/inpages/tlaltimeter.php
Altimeter TL-3524 is an altimeter with encoder in one. With the Altimeter, not only you can save weight by having two instruments in one but in addition it is also one of the first encoders that transmit the code immediately after the turn-on. In your Altimeter, you can easily set the height that is to be kept - the instrument will then inform you whether you are above or bellow this set height, the MDA, approach.
The instrument also informs you on reaching the transition altitude, the height with lack of oxygen etc. Using a PC and the program that is a part of the delivery, the Altimeter also enables you any time to go through the history of measured values.Size: 2-1/4" Not FAA approved. For homebuilt/experimental only.
Alberto Martin
www.iberplanes.es
Zodiac 601 XL Builder
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
goodings(at)yorku.ca Guest
Posted: Tue Jul 22, 2008 7:48 am Post subject: Altimeters |
The sensitive altimeter is the one with 2 or 3 hands (10', 100', 1000') as
has already been said. BUT, an important difference is that an
insensitive altimeter (typically 1 hand, 1 rotation, 100' increments) can
use internal cabin pressure for static pressure. But a sensitive
altimeter requires a GOOD static pressure port. This can be hard to
achieve - the side of the front fuselage (a la Cessna) is a bit hit and
miss, in my opinion. (I know people who have installed 3 before they got
something that read correctly.) We used a combined pitot tube/static
pressure port from a crashed Piper mounted 2/3 of the way out from the
fuselage under the wing. From the beginning, it gave correct airspeed and
altimeter readings. Maybe we were lucky! (The altimeter, of course, uses
just the static pressure reading.)
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto.
Posted: Tue Jul 22, 2008 3:54 pm Post subject: Altimeters |
Bryan-
This is probably the best description of the difference posted. I assume (And this is a big assumption) that the readings within the sweep of the one hand are as accurate as those of the "Sensitive" alts.
If my assumption is correct, since this is intended to be a backup instrument to the D-100 I'll be OK. I'm a relative flat-lander and have only busted 6-7K feet in a rental in Colorado.
Everyone, do your best to dissuade me- open season.
Doesn't matter, I have to work on the house anyway. Check this out:
Contracted a guy to put siding on the front of the house. Gave him an idea of what needed to be done and a rough estimate of the time it would take. He left, then half hour later came back and said he couldn't work under a homeowner's time estimate and no quoted. This is after the materials had already been ordered.
I estimated the worst portion of the job would take 2 hrs. After he no-quoted I was so pissed I went out and did it myself in 22 minutes.
And people wonder why it's taken me so long to complete my project!!!!
Bill
Gig Giacona
Posted: Wed Jul 23, 2008 5:29 am Post subject: Re: Altimeters |
The only thing I'll try to talk you out if is buying a Falcon anything. In the long run, heck even the short run, it will cost you more money than a good used altimeter (sensitive or not).
To figure the correct price on any Falcon instrument take the cost and add the cost of the one you will end up replacing it with. You save money by just skipping the first step.
| naumuk(at)alltel.net wrote: | Bryan-
601XL Under Construction
Posted: Thu Jul 24, 2008 6:35 am Post subject: Altimeters |
My Falcon sensitive altimeter has behaved perfectly from the beginning.
It has now been in operation for more than 3 years.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Ottawa.
Gig Giacona
Posted: Thu Jul 24, 2008 7:23 am Post subject: Re: Altimeters |
You are truly blessed. I know of 9 different Falcon instruments installed in 5 different planes and all but 1 instrument failed in less than a year.
| goodings(at)yorku.ca wrote: | My Falcon sensitive altimeter has behaved perfectly from the beginning.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Ottawa. |
steerr(at)bellsouth.net Guest
Posted: Thu Jul 24, 2008 9:08 am Post subject: Altimeters |
Mine's not even off the ground yet, but I've to reset the Kollsman window
twice on it. Sometimes it jumps thousands of feet in equivalent altitude
for a given barometic setting.
Bill
Iberplanes
Posted: Thu Jul 24, 2008 12:00 pm Post subject: Altimeters |
What about RC Allen? Is it considered a reliable brand?
2008/7/24 John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)>:
| Quote: | --> Zenith-List message posted by: John Goodings <goodings(at)yorku.ca (goodings(at)yorku.ca)>
My Falcon sensitive altimeter has behaved perfectly from the beginning. It has now been in operation for more than 3 years.
Alberto Martin
www.iberplanes.es
Serial: 6-7011
Tail Kit: Finished
Wings: Not Started
Fuselage: Ordered
Engine: Jabiru 3300
