Fuel Bracket Orientation of Holes
nukeflyboy
PostPosted: Thu Jul 10, 2008 5:03 pm    Post subject: Fuel Bracket Orientation of Holes Reply with quote
Here is something wierd. I have a QB fuselage and am installing fuel lines. The plans show the Van's fuel valve oriented about 45 degrees to the left (looking forward) relative to the mounting holes on the valve. Two of the ports then angle aft, left and right, for connecting to the wing tanks.
However, the mouning holes on the F-1048C valve mounting bracket are about 90 degrees different than the plans. They must have been factory pre-drilled that way. Instead of being on the left side of the bracket (again looking forward) they are on the right side. The part is asymetrical so it is not installed wrong.
With this orientation I can still get 2 ports oriented aft, but on the other side of the valve. It should work OK that way, but it just seems too wierd.
Have any of you seen this?
Dave Moore
RV-6 built and sold
RV-10 built and flying
coop85(at)cableone.net
PostPosted: Thu Jul 10, 2008 5:53 pm    Post subject: Fuel Bracket Orientation of Holes Reply with quote
Dave,
I just had a look at a picture of my fuel valve. You're right, your
mount appears to have been drilled 180 out. I have the mount holes forward
and left, yours was probably accidently drilled upside down. You might be
able to just accept it as you said, but if it makes more sense to position
the valve as planned (the biggest concern would be having the output port
facing forward) then I'd drill new holes.
Another option would be to opt for the Andair valve now if you think you
might be so inclined at some point. I just upgraded my system and it would
have been a lot easier at your stage rather than after it's flying.
Marcus
daveleikam(at)wi.rr.com
PostPosted: Thu Jul 10, 2008 8:01 pm    Post subject: Fuel Bracket Orientation of Holes Reply with quote
Yes. I just installed the valve by looking at the ports and mounting so the
valve supplies fuel from the correct tank when the valve selector is in the
corresponding position. I purchased a red anodized selector replacement
from Van's and the indicator disc. The valve mounts fine, but I also noted
the discrepancy with the plans.
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
MauleDriver(at)nc.rr.com
PostPosted: Fri Jul 11, 2008 8:49 am    Post subject: Fuel Bracket Orientation of Holes Reply with quote
If a new fuel valve would help, I'd be glad to ship mine since I used
the Andair. Just contact me directly.
Bill Watson
Marcus Cooper wrote:
Dave,
Marcus
ninepapa(at)bendbroadband
PostPosted: Fri Jul 11, 2008 11:26 am    Post subject: Fuel Bracket Orientation of Holes Reply with quote
Dave
Here is a picture of Randy DeBauw's fuel vavle installed, it looks just
like the plans.
One question, if you were to remove and reinstal it upside down, would the
hole orientation be correct?
John
 Filesize:  307.49 KB
 Viewed:  496 Time(s)
PostPosted: Fri Jul 11, 2008 8:41 pm    Post subject: Fuel Bracket Orientation of Holes Reply with quote
If you think about the position of the ports, it works either way. You
just plug a different port depending on the mount. Don't know why Van
changed the mount from the plans, you just have to scratch your head for a
minute.
Dave Leikam
Muskego, WI
nukeflyboy
PostPosted: Sat Jul 12, 2008 3:41 am    Post subject: Re: Fuel Bracket Orientation of Holes Reply with quote
Thanks for the replys.
Dave - I think you are right. After looking at the photo and the plans carefully, it seems that it doesn't matter. It will work in either orientation. The plug just needs to be on the other side (to block the unused port).
Flipping it upside down will get the correct orientation, but the bracket will sit about an inch lower, so that is ruled out. The Andair valve is really nice, but I am too cheap.
Bottom line - it will work as found. The only loss is a little more hair from head scratching.
Dave Moore
RV-6 built and sold
