icubob(at)newnorth.net Guest
Posted: Sun Jul 06, 2008 4:15 am Post subject: power to handheld gps. |
hi all,
seems that my inquiry was misleading. simply i am looking for the smallest connector i can find that will mount in my panel and deliver a ground and 12 volt pos. to the appropiate plug in. this will avoid frequent plugging and unplugging at the gps
sorry for any confusion.
bob noffs
Posted: Sun Jul 06, 2008 5:43 am Post subject: power to handheld gps. |
bob noffs wrote:
| Quote: | hi all,
bob noffs
Hi Bob,
I'd just wander into the nearest Radio Shack & pick up a mating
miniature phone plug & jack. They look like the connector on headphones
for iPods & other mp3 players, but you can get them with just tip &
barrel (2 conductors), instead of tip, ring & barrel. Use the tip as
positive & the barrel as ground. Jack goes in the panel (obviously) &
plug goes on the end of your power cable to the gps. They come in
several different diameters; I'd pick one that does *not* match your
iPod's audio connector. Go smaller with the gps connector, if you can
find one. That will avoid the danger of plugging an iPod's audio output
into 12VDC power. Or, hide the power jack under/behind the panel so that
passengers will be unlikely to find it.
The snap-action of the detent in the tip of the plug will keep it
plugged in unless you pull it out. In my not-so-humble opinion, a
locking connector in this type application just leads to damaged
connectors & wiring, while the spring loaded connector will just unplug
if you snag the wire, & you can plug it back in instead of repairing it
(at the end of the flight).
There are dozens of other small connectors available, but most either
lock in place or have no practical holding system, like the typical
coaxial barrel connectors for power found on cordless phones, etc. If
you can live with the lack of any latching feature, the coaxial barrel
connectors are the best bet to help insure that nothing else will fit
the jack.
If the iPod/power connector issue worries you, you could actually use an
RJ-11 telephone plug & jack but they require somewhat more specialized
tools than a soldering iron & solder. And since they lock, there's the
danger of damage if you snag the wire with something.
Posted: Sun Jul 06, 2008 5:46 am Post subject: power to handheld gps. |
Charlie England wrote:
| Quote: | bob noffs wrote:
> hi all,
> bob noffs
Hi Bob,
headphones for iPods & other mp3 players, but you can get them with
just tip & barrel (2 conductors), instead of tip, ring & barrel. Use
the tip as positive & the barrel as ground. Jack goes in the panel
(obviously) & plug goes on the end of your power cable to the gps.
They come in several different diameters; I'd pick one that does *not*
match your iPod's audio connector. Go smaller with the gps connector,
if you can find one. That will avoid the danger of plugging an iPod's
audio output into 12VDC power. Or, hide the power jack under/behind
the panel so that passengers will be unlikely to find it.
unplug if you snag the wire, & you can plug it back in instead of
repairing it (at the end of the flight).
the jack.
an RJ-11 telephone plug & jack but they require somewhat more
specialized tools than a soldering iron & solder. And since they lock,
there's the danger of damage if you snag the wire with something.
I forgot the most obvious answer, the one I used for my gps: just buy
the mating cable for the gps & hard-wire it into the a/c's electrical
system, with a short pigtail through the panel at the gps mounting
location. Drill your hole, add a bushing, & poke the connectorless end
of the cable through the hole prior to routing to power & ground.
nuckolls.bob(at)cox.net Guest
Posted: Sun Jul 06, 2008 7:13 am Post subject: power to handheld gps. |
At 08:41 AM 7/6/2008 -0500, you wrote:
<ceengland(at)bellsouth.net>
>bob noffs wrote:
>>hi all,
>> bob noffs
>Hi Bob,
>I'd just wander into the nearest Radio Shack & pick up a mating miniature
>phone plug & jack. They look like the connector on headphones for iPods &
>other mp3 players, but you can get them with just tip & barrel (2
>conductors), instead of tip, ring & barrel. Use the tip as positive & the
>barrel as ground. Jack goes in the panel (obviously) & plug goes on the
>end of your power cable to the gps. They come in several different
>diameters; I'd pick one that does *not* match your iPod's audio
>connector. Go smaller with the gps connector, if you can find one. That
>will avoid the danger of plugging an iPod's audio output into 12VDC
>power. Or, hide the power jack under/behind the panel so that passengers
>The snap-action of the detent in the tip of the plug will keep it plugged
>in unless you pull it out. In my not-so-humble opinion, a locking
>connector in this type application just leads to damaged connectors &
>wiring, while the spring loaded connector will just unplug if you snag
>the wire, & you can plug it back in instead of repairing it (at the end
>of the flight).
>coaxial barrel connectors for power found on cordless phones, etc. If you
>connectors are the best bet to help insure that nothing else will fit the jack.
>Charlie
I forgot the most obvious answer, the one I used for my gps: just buy the
mating cable for the gps & hard-wire it into the a/c's electrical system,
with a short pigtail through the panel at the gps mounting location. Drill
your hole, add a bushing, & poke the connectorless end of the cable
There are some additional options to consider for hand-held
power connections in the cockpit. See:
http://www.aeroelectric.com/Pictures/Connectors/Power/Hand_Held_Power.jpg
http://www.aeroelectric.com/Pictures/Connectors/Power/RS274-010.jpg
http://www.aeroelectric.com/Pictures/Connectors/Power/RS274-013.jpg
Posted: Sun Jul 06, 2008 10:12 am Post subject: power to handheld gps. |
thanks bob.
echristley(at)nc.rr.com Guest
Posted: Sun Jul 06, 2008 1:59 pm Post subject: power to handheld gps. |
Robert L. Nuckolls, III wrote:
The RS274-010/RS274-013 combination look like they would make for a
decent firewall pass-through. I'm sure the case is cheap pot metal, but
it still has to be a far cry above the typical plastic units. Protect
it from direct flames with a stainless steel panel, and I bet this would
perform just fine.
http://www.ronpaultimeline.com
tompkinsl(at)integra.net Guest
Posted: Mon Jul 07, 2008 9:46 am Post subject: power to handheld gps. |
Bob:
My experience is the smallest connectors are ones used in RC aircraft and car models. They are sort of a mini Molex connector. I was able to obtain then at a local hobby shop.
Hope this helps.
Larry Tompkins
Joined: 28 Mar 2008 Posts: 1973 Location: Riley TWP Michigan
Posted: Wed Jul 09, 2008 1:43 pm Post subject: power to handheld gps. |
At 10:40 AM 7/7/2008 -0700, you wrote:
| Quote: | Bob:
Hope this helps.
Are those the 0.1" spaced devices typical of that which
is supplied with servos? Those are used heavily in the
computer industry and are very useful assembly and
maintenance disconnects. I'd be wary of using them as
a service connection that sees a lot of mate/de-mate
also subject to having their companion wires tugged
on.
Devices typical of this service are:
http://www.molex.com/catalog/pdf/MX70545.pdf
http://www.molex.com/pdm_docs/sd/901560150_sd.pdf
I use a lot of these in my designs INTERNAL to
finished product but wouldn't recommend them
for the wild and wooly world of the airplane
cockpit.
Posted: Wed Jul 09, 2008 1:48 pm Post subject: power to handheld gps. |
At 10:12 PM 7/7/2008 -0400, you wrote:
| Quote: | Bob Noffs,<?xml:namespace prefix = o ns =
"urn:schemas-microsoft-com:office:office" />
Here are some Radio Shack parts that might work for you:
Size N Coaxial DC Power Plug (2-Pack)
$2.99
Model: 274-1573
Catalog #: 274-1573
<http://www.radioshack.com/product/index.jsp?productId 102488&cp=&sr=1&origkw=dc+plug&kw=dc+plug&parentPage=search>http://www.radioshack.com/product/index.jsp?productId 102488&cp=&sr=1&origkw=dc+plug&kw=dc+plug&parentPage=search
Size N Panel-Mount Coaxial DC Power Jack
$2.99
Model: 274-1576
Catalog #: 274-1576
<http://www.radioshack.com/product/index.jsp?productId 102489&cp=&sr=1&origkw=dc+jack&kw=dc+jack&parentPage=search>http://www.radioshack.com/product/index.jsp?productId 102489&cp=&sr=1&origkw=dc+jack&kw=dc+jack&parentPage=search
I really thought about adding these to the options
cited on my website but I've had too many problems
with general robustness. They're fine for hooking
wall-warts to your consumer product electro-whizzies
but I think a builder would become dissatisfied with
the choice some time in the future.
Good wire support and engagement retention are
useful in this application. This is my major complaint
about the legacy cigar lighter connectors used on
many automotive accessories. I'm always giving
the connector to my GPS a bit of a push to make
sure it's fully engaged after a few hours of
driving.
