How tight to make the plumbing fittings?
daveleikam(at)wi.rr.com
PostPosted: Wed Jul 02, 2008 5:12 am    Post subject: How tight to make the plumbing fittings? Reply with quote
How much torque should I apply to 37 degree flare fittings and other NPT fittings for brake and fuel line connections? Thanks for all the input everyone. Building is slowly accelerating as I move through the fuselage!
Dave Leikam
#40496 N89DA (Reserved)
Muskego, WI
bhughes(at)qnsi.net
PostPosted: Wed Jul 02, 2008 7:04 am    Post subject: How tight to make the plumbing fittings? Reply with quote
Aeroquip specifications 37 degree fittings.
Bobby
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Wednesday, July 02, 2008 7:11 AM
To: rhaugh(at)wi.rr.com; RV-10 matronics; Jeff Point
Subject: How tight to make the plumbing fittings?
Dave Leikam
Muskego, WI
Aeroquip_torq_specs.pdf
 Filename:  Aeroquip_torq_specs.pdf
 Filesize:  64.75 KB
 Downloaded:  241 Time(s)
ricksked(at)embarqmail.co
PostPosted: Wed Jul 02, 2008 8:42 am    Post subject: How tight to make the plumbing fittings? Reply with quote
This is invaluable for performance fittings, go to page 50 for torq anf hex flat options for torq, I pasted the PDF and also included the link.
Rick Sked
40185
http://hydraulics.eaton.com/products/pdfs/fc/A-SPPE-MC001-E2.pdf
 Filesize:  64.75 KB
 Downloaded:  231 Time(s)
