601XL O-200 Prop
floyd wilkes
PostPosted: Sat Jun 28, 2008 2:22 pm    Post subject: 601XL O-200 Prop Reply with quote
I would like to know what prop you are using with the O-200 engine.
I have the Sensenich W68ZK-57G which I was told is what AMD puts on the factory plane. I am not getting the proper RPM with it.
Wondering if I have wrong prop or an engine problem.
Floyd Wilkes
601XL O-200
Floyd Wilkes
psm(at)att.net
PostPosted: Sat Jun 28, 2008 2:57 pm    Post subject: 601XL O-200 Prop Reply with quote
Hi Floyd,
I am no prop expert, but the one used on the Jabiru in the FWF from
Pete is the Sensenich W64ZK-49. This is 4 inches shorter and has a
pitch 8 inches smaller. Considering the engine has 30 percent more
horsepower than the O-200, it sounds like you might have the wrong
one. One issue to consider is the Jabiru turns more RPMs than the
Continental so that might make a difference.
Culver has a a nice prop calculator online at
http://www.culverprops.com/pitchselection.htm. You might try it to
see what prop you should be using for your engine and speed.
Good luck,
Paul
XL getting close
jmaynard
PostPosted: Sat Jun 28, 2008 4:07 pm    Post subject: 601XL O-200 Prop Reply with quote
On Sat, Jun 28, 2008 at 03:22:59PM -0700, floyd wilkes wrote:
I would like to know what prop you are using with the O-200 engine. I have
plane. I am not getting the proper RPM with it. Wondering if I have wrong
Yes, tha W68ZK-57G is what's on my Zodiac. What kind of RPM are you seeing?
I'm not having trouble getting up above 2600 in cruise flight at full
throttle. I haven't paid attention to what it is on the takeoff roll,
though; if you'd like, and I manage to commit aviation tomorrow morning,
I'll take a look.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
floyd wilkes
PostPosted: Sat Jun 28, 2008 4:31 pm    Post subject: 601XL O-200 Prop Reply with quote
Static rpm is about 2240. In flight it will not go above 2400 in level
flight. It took a dive to hit 2700.
My rate of climb tests today maxed out at 520 ft/min.
Guess I better check out the motor. It is 0 SMOH and possibly could have a
problem.
Floyd Wilkes
601XL O-200
Floyd Wilkes
jmaynard
PostPosted: Sat Jun 28, 2008 6:06 pm    Post subject: 601XL O-200 Prop Reply with quote
Dumb question: How did you test this? Full power, on the ground, brakes
locked?
In flight it will not go above 2400 in level flight. It took a dive to
hit 2700. My rate of climb tests today maxed out at 520 ft/min.
I cruise at 2550 with no trouble at all, and that's throttled back a little.
I also get 800-1000 FPM climb right after takeoff solo with full fuel.
problem.
Yeah, this seems like something that needs checking. I couldn't begin to
tell you what to look at, though.
Jay Maynard, K5ZC
floyd wilkes
PostPosted: Sat Jun 28, 2008 7:29 pm    Post subject: 601XL O-200 Prop Reply with quote
Yes, static test is full throttle holding the brakes.
Thanks for your information. I will check the timing of the engine. With a
new overhaul, it is possible they have the valve timing off. Will check
that.
Floyd Wilkes
Floyd Wilkes
jmaynard
PostPosted: Mon Jun 30, 2008 4:37 pm    Post subject: 601XL O-200 Prop Reply with quote
This morning, I did this after my normal runup for a moment...and got 2350
RPM for a moment before I had to back off (the brakes could not hold the
aircraft).
Jay Maynard, K5ZC
floyd wilkes
PostPosted: Mon Jun 30, 2008 4:54 pm    Post subject: 601XL O-200 Prop Reply with quote
Thanks for checking.
I found my problem. The valve timing is off. Time for a little warranty
work!
My Dynon 180 was acting up a little so now will be a good time to send it in
for a checkup.
Hopefully I will have everything fixed and ready to go in a couple weeks.
Floyd Wilkes
Floyd Wilkes
