dvanlanen
Posted: Tue Jul 01, 2008 7:21 am Post subject: P-Touch Wire Labeling Question |
I came across suggestions on the list for using the Brother P-Touch labeling system to label wires. I purchased a PT-1830 printer and the flexible ID tape, which is designed specifically for “flag” labeling wires, cables, etc. I needed to “flag” label the small servo wires (26 AWG) because they are too small for using the label wrap / heat shrink method. A couple of days after applying the labels, I noticed that they started to come loose.
Has anyone else used this tape to “flag” label any of their wires, and if so, what was your experience? Am I doing something wrong?
Dave [quote][b]
bbradburry(at)bellsouth.n Guest
Posted: Tue Jul 01, 2008 8:02 am Post subject: P-Touch Wire Labeling Question |
I am using the exact same equipment and having very similar experiences. The flags don’t seem to come all the way off, but they get loose and can move up and down the wires. They make a product with stronger adhesive, but the tape is stiffer and the results are similar. The stronger adhesive works for labeling my fuse box tho’.
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave VanLanen
Sent: Tuesday, July 01, 2008 11:18 AM
Subject: AeroElectric-List: P-Touch Wire Labeling Question
Dave | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
bob(at)bob-white.com Guest
Posted: Tue Jul 01, 2008 8:27 am Post subject: P-Touch Wire Labeling Question |
For low volume marking, I've found that making a label by writing on
3/32 white shrink tubing with a fine line Sharpie does a good job. For
the 26 AWG wire, you might need to put a piece of 1/16 shrink on
before shrinking the label on. I've used the 3/32 on 22 AWG Tefzel,
and it sticks in place, but if you push on it, it will come loose and
slide on the wire.
Bob W.
On Tue, 1 Jul 2008 10:17:58 -0500
"Dave VanLanen" <davevanlanen(at)sbcglobal.net> wrote:
| Quote: | I came across suggestions on the list for using the Brother P-Touch labeling
tape, which is designed specifically for "flag" labeling wires, cables, etc.
I needed to "flag" label the small servo wires (26 AWG) because they are too
Has anyone else used this tape to "flag" label any of their wires, and if
Dave
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
3.8 Hours Total Time and holding
Cables for your rotary installation - http://roblinstores.com/cables/
rshannon
Posted: Tue Jul 01, 2008 8:43 am Post subject: P-Touch Wire Labeling Question |
FWIW, on smaller gauge wires, I use a label maker with the flexible tape and, using the smallest font, make a label that's cut with extra white space equal to the width of the letters. I then trim the 1/2" wide tape lengthwise on top and bottom, so the tape width is about 1/4". Then I wrap the tape around the wire perpendicular to the wire, attaching it to the wire and itself. A true flag. Have not had one come off yet.
Ron
frank.hinde(at)hp.com Guest
Posted: Tue Jul 01, 2008 9:11 am Post subject: P-Touch Wire Labeling Question |
Wow is it really worth all the effort it takes to do this?
I mean I have built two airplanes, and flown about about 1000hours between them the latest is IFR and the 601 Zodiac VFR.
I did not label a single wire in either airplane and can't see any reason I should so far.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Shannon
Sent: Tuesday, July 01, 2008 9:40 AM
Subject: Re: AeroElectric-List: P-Touch Wire Labeling Question
Ron
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
Posted: Tue Jul 01, 2008 10:19 am Post subject: P-Touch Wire Labeling Question |
Hi Frank,
It all depends on what happens someday when something goes wrong, or
you want to modify something. Maybe you enjoy a good puzzle. It will
be even more fun if you use only white wire too.
I think writing on shrink tubing is easier than all that snipping and
trimming.
Bob W. (Not advocating that anyone should do anything.)
On Tue, 1 Jul 2008 17:07:07 +0000
"Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> wrote:
| Quote: | Wow is it really worth all the effort it takes to do this?
Frank
Subject: Re: P-Touch Wire Labeling Question
Ron
rshannon
Posted: Tue Jul 01, 2008 2:05 pm Post subject: P-Touch Wire Labeling Question |
Frank,
I'm glad it's worked out for you, but even though I've been working with electronics all my life, I have hundreds of wires in the airplane and wouldn't even consider not labeling them. Perhaps you're joking, but if not, the reasons labeling wires are part of best practices should be obvious: reduction or elimination of connection errors, ease of maintenance & troubleshooting for me and others, better resale value, AC-43 recommends it... etc., etc. The reason I personally prefer the trimmed label tape flags on small wires is just that they're easier for me to read when peering into my very cramped panel space. It takes less than a minute per wire to do.
Ron
On Tue, Jul 1, 2008 at 10:07 AM, Hinde, Frank George (Corvallis) <frank.hinde(at)hp.com (frank.hinde(at)hp.com)> wrote:
[quote] Wow is it really worth all the effort it takes to do this?
Frank
RV4WGH(at)aol.com Guest
Posted: Wed Jul 02, 2008 4:13 am Post subject: P-Touch Wire Labeling Question |
I have a Brother labeling machine. However, for the wires, I made up labels using a word processor, No. 8 font. Cut them out and used heat shrink over them. Worked great. YMMV.
Wally Hunt
RV-4 Finishing Kit
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
dean.psiropoulos(at)veriz Guest
Posted: Wed Jul 02, 2008 9:51 pm Post subject: P-Touch Wire Labeling Question |
You're not doing anything wrong Dave:
I built a full IFR panel with big radio stack and I used the P-Touch PT-1400
portable handheld to label every wire at about 1 foot intervals. I did
experience the "unsticking" over time also but cured it with clear
heatshrink shrunk over the top of the wrapped labels(I didn't use the flag
technique on the 26 GA MAC servo wires, I just noted the color code on the
drawings). As one might guess "Frank", this was very time consuming but
with the wires made of Teflon and being such small diameter it was necessary
to avoid the labels coming off. Definitely worth it though, I know what goes
where and when I did my electrical checkout last fall there were only two
wires that were swapped (easily fixed). I hope I never have to touch it
again but if I do, I'll know exactly what I'm looking at.
Dean Psiropoulos
RV-6A N197DM
Finally finished (FAA Inspection next week, transition training on the 21st)
_______________________Original Message ___________________________________
| Quote: | From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: P-Touch Wire Labeling Question
| Quote: | Has anyone else used this tape to "flag" label any of their wires, and if
