n212pj(at)gmail.com Guest
Posted: Tue Jun 24, 2008 2:01 pm Post subject: Loctite usage on brake line hardware |
Are folks using Loctite on the brake line threads into the M/C's? If so,
which type and where did you get it? If not, what did you use and where did
you get that?
John J
Tim Olson
Posted: Tue Jun 24, 2008 2:21 pm Post subject: Loctite usage on brake line hardware |
I think I just used liquid teflon tape....any auto parts store.
John Jessen wrote:
you get that?
John J
Posted: Tue Jun 24, 2008 2:29 pm Post subject: Loctite usage on brake line hardware |
John Jessen wrote:
Not me.
| Quote: | If so,
you get that?
I use three things on tapered pipe thread. I use teflon tape ..... No
flames here, he asked what I do ..... but be sure not to get it on the
first thread ..... , teflon paste, and 'fuel lube' ..... all with
excellent results. Hardware store for the first two and ACS for the third.
Linn
Posted: Wed Jun 25, 2008 6:54 am Post subject: Loctite usage on brake line hardware |
That's it? Nothing special and expensive? Geez. How disappointing...
Tim Olson
Posted: Wed Jun 25, 2008 8:15 am Post subject: Loctite usage on brake line hardware |
Linn,
I think John is refering to the pins/bolts that hold the caliper together, not the plumbing parts.
Rick Sked
40185
Posted: Wed Jun 25, 2008 8:43 am Post subject: Loctite usage on brake line hardware |
Opps I stand corrected, was the lines...I used fuel lube on mine, no leaks.
Rick Sked
