Jeffrey Dill
Joined: 23 Jul 2007 Posts: 52 Location: Pleasant view, TN
Posted: Sun Jun 22, 2008 8:36 pm Post subject: Why do I have a flap handle? Model 2 |
I was sick for about six months, but got my medical back and am back to learning about this model 2 I rebuilt. I had a great day on Saturday. Flew some formation against a Thorpe Scooter, whose owner was delighted to be the faster of the two airplanes.
With about 20 hours in the airplane, I have gotten so that I never touch the flap handle. What is it there for? To be able to fly slower without stalling? I guess I can go back and check how much difference that makes, but I fly final at least at 55 regardless, which is plenty above stall speed with any flap setting. You guys tell me that the flap handle is there to trim the airplane, but something about that doesn't square well. The faster you go, the more the nose wants to rotate up; that is basic longitudinal stability. To trim nose down, you must shift the center of lift backwards by putting flaps down further. Flaps are drag, right? Now, let me see if I have this straight. When I get to going fast, I either hold the stick pressure, or I add drag. Putting flaps down is going to fix the problem one way or the other because it is going to kill all the speed!Corollary question:What flap setting gives the best speed
What are the three bolt holes at the leading edge of my horizontal stab? Am I free to experiment with using any of the three? Since my stab struts do not have turnbuckles, I would be warping the leading edge by choosing a higher angle of incidence. Any problem with that?
One more thing regarding my 582. I have the carbs adjusted exactly even with each other with open throttle, I can't get them any closer. I am seeing some difference in EGT between cylinders at high power. Should I open up the cooler one a few turns?
Wa-Hoo!, I am loving it.
_________________ Jeff Dill
Model 2 |
Guy Buchanan
Posted: Mon Jun 23, 2008 4:12 am Post subject: Why do I have a flap handle? Model 2 |
At 09:36 PM 6/22/2008, you wrote:
| Quote: | Flaps are drag, right? Now, let me see if I have this straight. When
Well, any trim is drag, the question is, what system generates the
least drag. I have found that the elevator, probably because of its
long arm, generates less drag than using the flaps for trim. I
therefore installed an elevator trim tab. Once I did I then fiddled
both until I had maximum speed in cruise. I found the cruise speed,
though, to be fairly insensitive to configuration.
| Quote: | What are the three bolt holes at the leading edge of my horizontal
You're free to experiment, but only if you put adjustment capability
on your struts, or make three pairs of struts. I wouldn't bend
anything. (I think most run their stab LE as "flat" as possible,
(high LE,) which makes for less trim drag and less pitch stability.)
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Jun 23, 2008 5:48 am Post subject: Re: Why do I have a flap handle? Model 2 |
RE: Trimming with flaps and EGTs
Jeff, Pulling the flap handle up pitches the nose down. Don't worry about losing speed with this set up for trimming...it is a kitfox. My Classic 4 cruises at 75 and needs just 1/2 inch or less of up flap handle to trim the nose down to level hands off. I can't see any loss of speed on the indicator. I get on my snowmobile when I want to go really fast.
The carb pistons (slides) should be set even at closed throttle They should both contact the idle screw stop at the same time as throttle is closed. Then check to see that they both move up at exactly the same time when throttle is advanced. They should be just clear of the top of the carb throat at full throttle. Be sure the throttle handle hits it's stop at full throttle so the force is not on the cables.
The carb main jet controls fuel and thus EGT at full throttle. Different EGT between cylinders is not unusual. It can easily be a temp gage error. Switch the probes in the exhaust manifold Y to trouble shoot it. If it is in spec (I think 45 degrees F difference) and runs good and smooth, don't worry about it. It is mostly a base line reading to monitor for changes anyhow. Check the spark plug color for the final decision.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
matronics(at)bob.brennan. Guest
Posted: Mon Jun 23, 2008 6:22 am Post subject: Why do I have a flap handle? Model 2 |
I also have a model 2 with a 582, and am finding new uses for the flaps all
the time. According to the Kitfox pilot's manual the first notch adds mostly
lift and a little drag, the second notch adds lots of drag and a little
lift.
I'm not sure how many Kitfox pilots use it as a STOL aircraft but that was
the emphasis of the original designs, and the flaperons were the major part
of that. My Kitfox is hangered in my barn and will be flown into and out of
wherever I can, hence my choice of a good STOL aircraft. In fact I trained
at a very short grass farm strip with mostly trikes and large obstacles no
matter which way you land.
I use no flaps when flying alone with light fuel load on takeoff, notch one
if I have a passenger and/or fuel load. Landing at a "normal" airport I
would not use flaps, but dropping in to a short grass field over a 50ft+
tree I use 1 notch after turning to final which noses down and floats so I
can accurately plan phase 2, then put on notch 2 just over the obstacle so a
steep descent doesn't increase airspeed and I can flare in the shortest
possible distance. I also use 2 notches under any conditions if I am light
and don't want to float forever on the flare
A word of caution though, also from personal experience, don't use flaps on
landing in anything other than straight flight. On a model 2 you can
seriously run out of control authority with flaps, low airspeed, and a steep
turn. My instructor called it "falling off the wing" with a wing low and the
stick full over to the other side and the airplane heading sideways towards
the ground. Dumping flaps is too late at that point, so I learned to just
never do it!
Oh and one more use for flaps - 1 notch on a clear summer's day, throttle
back, fling open the doors, diddle the stick up, and enjoy the view! (Using
the wheel as a footrest can be fun too, but possibly not legal...)
Bob
Jeffrey Dill
Posted: Mon Jun 23, 2008 11:03 am Post subject: Re: Why do I have a flap handle? Model 2 |
That has been my experience too, that flap position does not seem to affect my cruise speed, but no controlled study so far. I am finding that trimming for high speed is more flap than I would want on final.
I have not bothered to put notches in my flap handle. I can set an infinite range without stops to prevent too far forward or two far aft, using the leather washer design to hold the handle where I put it. I have paid the price for having this configuration and am trying to at least mark the safe limits. Up to at least three stories to tell on that one, the last one resulted in quite an air-show at the controlled field. I believe I experienced the lack of roll authority you referenced in the flare, even though the flaps were at a setting that still gave full authority to the ailerons. I swear another factor, as I was trying to get that right wing to go down, was adverse yaw pulling the left one backwards.
I am still getting a little skip at mid range from the engine. It has been since last September that I played with the mixture screw. That is when I put #45 idle jets in it. It idles better but still some four cycling, but much better. I have to read up again to remember what I can achieve by adjusting the mixture screws.
Model 2 |
msm_9949(at)yahoo.com Guest
Posted: Mon Jun 23, 2008 12:04 pm Post subject: Why do I have a flap handle? Model 2 |
Don't overanalyize it Jeff. It works. Pull up the flap lever in flight and the nose comes down. From my experience in a M2, that's about all the flaps are really good for. Lemme guess, your forward cylinder EGT runs 50-100 degrees cooler than the aft, right?
Marco Menezes N99KX
Mod 2 582-90 C-Box 3:1
--- On Mon, 6/23/08, Jeffrey Dill <1dillfamily(at)comcast.net> wrote:
[quote]From: Jeffrey Dill <1dillfamily(at)comcast.net>
Subject: Why do I have a flap handle? Model 2
Date: Monday, June 23, 2008, 12:36 AM
[quote]--> Kitfox-List message posted by: "Jeffrey Dill" <1dillfamily(at)comcast.net> I was sick for about six months, but got my medical back and am back to learning about this model 2 I rebuilt. I had a great day on Saturday. Flew some formation against a Thorpe Scooter, whose owner was delighted to be the faster of the two airplanes. With about 20 hours in the airplane, I have gotten so that I never touch the flap handle. What is it there for? To be able to fly slower without stalling? I guess I can go back and check how much difference that makes, but I fly final at least at 55 regardless, which is plenty above stall speed with any flap setting. You guys tell me that the flap handle is there to trim the airplane, but something about that doesn't square well. The faster you go, the more the nose wants to rotate up; that is basic longitudinal stability. To trim nose down, you must shift the center of lift backwards by putting flaps down further. Flaps are drag, right? Now, let me see if I have this straight. When I get to going fast, I either hold the stick pressure, or I add drag. Putting flaps down is going to fix the problem one way or the other because it is going to kill all the speed!Corollary question:What flap setting gives the best speed What are the three bolt holes at the leading edge of my horizontal stab? Am I free to experiment with using any of the three? Since my stab struts do not have turnbuckles, I would be warping the leading edge by choosing a higher angle of incidence. Any problem with that? One more thing regarding my 582. I have the carbs adjusted exactly even with each other with open throttle, I can't get them any closer. I am seeing some difference in EGT between cylinders at high power. Should I open up the cooler one a few turns? Wa-Hoo!, I am loving it. -------- Jeff Dill Model 2, 767JD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=189219#189219 [quote][b]
Float Flyr
Posted: Mon Jun 23, 2008 1:25 pm Post subject: Why do I have a flap handle? Model 2 |
Manitoba used to have laws against riding on the running boards of any
vehicle (Harley owners loved that one) but I don't know of any law
restricting putting your foot on the wheel... how about hang gliders where
the feet are the wheels?? I think You're legal.
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
thesupe(at)hotmail.com Guest
Posted: Mon Jun 23, 2008 1:31 pm Post subject: Why do I have a flap handle? Model 2 |
The skip at midrange you mention sounds like your midrange mixture is to rich. The idle circut will not have much effect at midrange, that is controlled by the jet needle and needle jet. If the EGTs are low and the sparkplugs are black in color, I would raise the clip one notch on the jet needle. Jim Chuk Avids Kitfox 4 Mn
| Quote: | Subject: Re: Why do I have a flap handle? Model 2
Date: Mon, 23 Jun 2008 12:03:09 -0700
Jeff Dill
Model 2, 767JD
http://forums.matronics.com/viewtopic.php?p=189375#189375
Introducing Live Search cashback . It's search that pays you back! Try it Now
Float Flyr
Posted: Mon Jun 23, 2008 1:38 pm Post subject: Why do I have a flap handle? Model 2 |
I was given a little trick to setting up the idle screws on the Bing 54 carbs. First thing was to remove the carbs from the plane and back the idle screws to a point where the slides bottom right out. Then lift the slide withyour finger and let it drop you will hear a sound as it bottoms. Turn the idle screw in a fraction of a turn and do the same thing again until the sound of the bottoming dulls. This is the point where the idle screw first makes contact with the slide. Do this to both carbs. Turn in the idle screw on both carbs exactly the same number of turns. This part I’m a bit fuzzy on. I think it’s around 1 ½ turns. Either way when you adjust one carb adjust the other the exact same amount.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
7.29 KB |
9934 Time(s) |
Kitfox III-A
Posted: Mon Jun 23, 2008 1:43 pm Post subject: Why do I have a flap handle? Model 2 |
And the wind on my toes is SOOO refreshing...
gary.algate(at)sandvik.co Guest
Posted: Mon Jun 23, 2008 3:44 pm Post subject: Why do I have a flap handle? Model 2 |
I have used my flaps in the reflex position and found that I can gain a couple of extra miles per hr in cruise - I also have to use a little forward pressure to counter the nose up trim.
Being a model 4, I don't have the serious reduction in aileron movement when using flap so I experiment a lot with it.
regards
Gary
Gary Algate
Classic 4 / Jab2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission. [quote][b]
taildragon(at)msn.com Guest
Posted: Mon Jun 23, 2008 4:03 pm Post subject: Why do I have a flap handle? Model 2 |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I concur, Gary. During Phase I, I experimented with flaps in reflex and found a few knots. I have the HS in the lowest position and a trim tab on the elevator.
Roger
KF4-1200, 912UL
Jeffrey Dill
Posted: Tue Jun 24, 2008 3:06 am Post subject: Re: Why do I have a flap handle? Model 2 |
As I said, I had a great day Saturday. I attached a picture taken in flight at 85 MPH. If you use your imagination, I think you can see the position of the elevator trailing edge down. I was pushing and it would seem like this un-faired position might be adding drag. I would like to raise the leading edge of the Horizontal stab, but have been told not to warp it (which it already is a bit set in the middle hole) and I am not apt to cut and weld a longer strut.
As for the midrange skip, I had a two cycle guy move the needle valve. Was it the jet needle, or the needle jet? The one with the four clip positions. He moved it one notch and looked at the plugs after running it and then moved it back in fear that it was running too hot. So I will leave those alone. I guess I might play with the mixture screws; I have not touched those since changing the idle jets.
94.51 KB |
754 Time(s) |
Model 2 |
Lynn Matteson
Posted: Tue Jun 24, 2008 9:41 am Post subject: Why do I have a flap handle? Model 2 |
The jet needle is a needle, and the needle jet is the thing that the
needle goes into and comes out of...think male (needle) and female
(jet). I can't for the life of me think whey they have to refer to
the jet needle as a "jet" needle, but I CAN understand why they call
the jet a needle jet, so as not to be confused with the main jet, or
the idle jet. Like everything else in aviation, confusion seems to be
abundant.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/538 hrs
On Jun 24, 2008, at 7:06 AM, Jeffrey Dill wrote:
strut.
Jeff Dill
Model 2, 767JD
http://forums.matronics.com/viewtopic.php?p=189531#189531
http://forums.matronics.com//files/lead2_955.jpg
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Jeffrey Dill
Posted: Wed Jun 25, 2008 4:28 am Post subject: Re: Why do I have a flap handle? Model 2 |
Over-analyzing again; I plead guilty. It occurred to me that the minimum flap drag at cruise speed is probably synonymous with the point of least resistance for the flaps. In other words, if I relax the torque on the flap handle bolt to the point where it no longer stays where I put it, the flaps will fair to the point of least resistance (for the flaps, not necessarily the airplane as a whole). I can mark where they go at cruise speed and that ought to be the least drag setting for the flaps, and I suspect the airplane as a whole.
Model 2 |
