messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Fri Jun 13, 2008 4:36 pm Post subject: work hardening? |
Hi!
I have a piece of 6061-t6 0.090". I bent it ~20degrees in a brake, at least 3t bend radius. The metal slipped in the brake while bending so I hammered it almost flat with a few whacks of the 4# hammer. I then rebent it ~1" away. Will the flatenning of the original bend case it to work harden enough to weaken it? This is on one of two pieces of 090 that sandwich a 3.5# piece of lead for the aileron counterweight. The other piece of 090 is fine.
Thanks!
_________________ Dan |
Ron Lendon
Posted: Fri Jun 13, 2008 5:10 pm Post subject: Re: work hardening? |
I was going to comment but I'm not sure we are working on the same airplane.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
ashontz
davids601xl(at)yahoo.com Guest
Posted: Mon Jun 16, 2008 7:56 am Post subject: work hardening? |
Hi Dan.
Work (or strain) hardening actually hardens the metal (and is some cases there is an increase in strength) but reduces its ductility. Ductility is REALLY important when it comes to cyclic loading and Vibration. From what I remember fom my engineering metallurgy courses elastic strain is when the material is deformed and bounces back to its original shape and doesn't strain harden. Plastic strain (deformation) where it doesn't go back to its original shape cause the strain hardening. In the end I don't feeel qualified to make a difinitive statement on the relative safety of your part. It will be subjected to cyclic loads and vibration. Ask yourself this " What would happen with a complete failure of this part? and is the part easily visible for inspections every walkaround"? Then make your call. Because I am a scratchbuilder and find most parts pretty easy to make over, I probably would just do another part. No answer I know but that's jst my 2 cents. (1 drop of gasoline)
David Barth
601 XL Plansbuilder 15% done?
Working on Wings
www.ch601.org
--- On Fri, 6/13/08, messydeer <messydeer(at)yahoo.com> wrote:
[quote]From: messydeer <messydeer(at)yahoo.com>
Subject: work hardening?
Date: Friday, June 13, 2008, 5:36 PM
[quote]--> Zenith-List message posted by: "messydeer"
Hi!
enough to weaken it? This is on one of two pieces of 090 that sandwich a [quote][b]
