gpjann1(at)netzero.net Guest
Posted: Tue Jun 10, 2008 3:02 pm Post subject: Fractured starter ring gear |
The installation instructions received with the Ultra Low profile front starter kit does not contain the type of ring gear or starter. The entire unit was mounted as per instructions, including the rear starter bracket.
I am also having problem with the JD Regulator. I've been through three Reg and feel that the #5 wire to the battery using a circuit breaker is the problem. I'm get good readings on the volt and amp meters when Alt is switched on, but alt doesn't connect when running alt without battery.
Any help would be appreciated.
GPJ
My email address is gpjann1(at)netzero.com
____________________________________________________________
Fabulous Spa Getaway!
Enter for your chance to WIN great beauty prizes everyday!
