Thoughts on new wingtips?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
dashvii(at)hotmail.com
PostPosted: Sat Jun 07, 2008 11:57 am    Post subject: Thoughts on new wingtips? Reply with quote
To all, I want to know what you all think about the new wingtip extensions. Do you like the look of the increased wingspan? Do you like the wingtips and how they flare out at the end? Anybody planning on ordering a set? I want to hear from both sport pilot and non-sport pilot builders alike. I'd like to kind of get a tally of which group wants them more. It's something that will really allow the sport pilots to maximize their aircraft while at the same time, I believe it will allow for non sport pilots to add looks and climb performance, and probably a slight decrease in fuel consumption at cruise. Brian W.
Now you can invite friends from Facebook and other groups to join you on Windows Live™ Messenger. Add them now! [quote][b]
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
saniewskig(at)bellsouth.n
PostPosted: Sat Jun 07, 2008 12:44 pm    Post subject: Thoughts on new wingtips? Reply with quote
I think they look great, I am looking to build a Light Sport and the Lightning looks to be the ticket. I hope to test fly the aircraft soon.
pennington(at)q.com
PostPosted: Sat Jun 07, 2008 12:59 pm    Post subject: Thoughts on new wingtips? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Brian
I like the appearance of the new wing tips. I think they look much more sporty. I understand Nick is flight testing them.
Preliminary reports suggest they reduce take off roll, increase climb rate, reduce stall speed and do not reduce cruise speed. I would be interested in their performance during accelerated stalls, but so far, everything seems very positive. How can you lose?
If final testing verifies the above, I will use them on my new Lightning.
Happy flying.
Gary Pennington
Wayne Lenox
PostPosted: Sat Jun 07, 2008 2:36 pm    Post subject: Thoughts on new wingtips? Reply with quote
Brian
My Lightning is in build and has the new tips. I like the look and hope the preformance. Nick has flown the test bed Lightning and did report on its preformance. I live out west and will fly above 9000ft much of the time, the tips should help.
Wayne
ist">http://www.matronics.com/Navigator?Lightning-List
tronics.com
www.matronics.com/contribution
[url=_blank]Make your vacation more memorable with a luxurious vacation rental. Click now![/url]
sales(at)billandruth.net
PostPosted: Sat Jun 07, 2008 2:48 pm    Post subject: Thoughts on new wingtips? Reply with quote
Hi Wayne,
I have decided to install the new wing tips as well and am on the "list" to get them.  I'm curious as to how you came about getting a set at this time when they don't appear to be available generally as yet.  Do you have any info that you can share with the group?  Bill Applegate, kit #49 in Tucson, Az.
Wayne Lenox wrote:
Brian
Wayne
-- Brian Whittingham <dashvii(at)hotmail.com> (dashvii(at)hotmail.com) wrote:
tronics.com
selwyn
PostPosted: Sat Jun 07, 2008 5:19 pm    Post subject: Re: Thoughts on new wingtips? Reply with quote
pennington(at)q.com wrote:
<xml><xml><endif>
I won´t be buying the tips as they are. It is a little hard to tell from the photos but while the actual tip profile looks good, I am not so sure that the increase in span will suit the plane so well but that is just personal preference and would need a look at the real thing to tell.
As for performance, I am not a US sport pilot so the no flap stall speed is of little concern to me and the flap stall and approach speeds seem OK. The Lightning is never going to be a paddock aeroplane and mid 50kt approach speeds are fine for tarmac or reasonable grass strips.
The flight effects are interesting though. The lower stall speed, reduced takeoff roll and climb rates could be explained by the increase in wing area and span but the claim of no change in cruise is counter intuitive. Increasing span and wing area would normally lead to increased drag at cruise speeds so it may be that the tip profile is actually doing something to airflow to lower induced drag.
If that is the case then what I would like to see is a wingtip with the new profile but without the increase in span. That would look better than the standard tip and should capture any improvement in cruise performance attributed to the tips without drawbacks of increased wing area on cruise performance. Low speed handling would probably be little changed from the standard tip.
Cheers.
Rick
PostPosted: Sat Jun 07, 2008 5:44 pm    Post subject: Thoughts on new wingtips? Reply with quote
Subject: Re: Thoughts on new wingtips?
Date: Sat, 7 Jun 2008 18:19:24 -0700
Hmmm,
Hold on a minute...with an higher aspect ratio(among other things) it is possible the cruise at altitude can actually INCREASE!
Does it with the new tips?
I don't know...we shall see!
Rick
N727RB
Cheers.
http://forums.matronics.com/viewtopic.php?p=186732#186732
Instantly invite friends from Facebook and other social networks to join you on Windows Live™ Messenger. Invite friends now! [quote][b]
pennington(at)q.com
PostPosted: Sat Jun 07, 2008 5:47 pm    Post subject: Thoughts on new wingtips? Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Wayne
You say you live out West? I live in Tucson, Arizona.
Gary
Colin K.
PostPosted: Sat Jun 07, 2008 6:23 pm    Post subject: Thoughts on new wingtips? Reply with quote
Interesting thought Selwyn. I would guess that the tip could reduce induced
drag by reducing the wing-tip vortices.
Does the profile of the extension remain constant from the attachment end
some way out towards the tip?
If this is the case, could part of the extension be cut from the attachment
end giving a shorter overall extension while providing the same profile at
the attachment point? Nick?
Colin K.
OK
Lightning # 52 under construction.
http://www.mykitlog.com/cojaken
Colin K.
OK
pequeajim
PostPosted: Sat Jun 07, 2008 7:20 pm    Post subject: Thoughts on new wingtips? Reply with quote
Yes, but think of the thermals you could catch with the new extended wing
tips!!
(grin)
selwyn
PostPosted: Sat Jun 07, 2008 7:33 pm    Post subject: Re: Thoughts on new wingtips? Reply with quote
[quote
Hmmm,
Rick
N727RB
/quote
Yep, you are quite correct. I didn´t want to get into a discussion of aerodynamics with all it´s complexities and was thinking about low density altitudes. Where I am, most flying is below 5000 and almost never above 8500 due to a combination of regulation and terrain. At those levels a Lightning, with its wing loading, will have a low angle of attack at cruise and probably won´t gain much simply from the increased area supplied by the tips.
Cheers.
jhausch
PostPosted: Sun Jun 08, 2008 3:29 am    Post subject: Re: Thoughts on new wingtips? Reply with quote
I think they look good, but I do not think I'd take the option. Performance with standard tips appears to be more than acceptable.
It would be neat to see the standard "short" tips with the upswept feature and maybe integrated areas for the nav lights. However, that's what I'd call a "low-priority-want".
Wayne Lenox
PostPosted: Sun Jun 08, 2008 3:29 am    Post subject: Thoughts on new wingtips? Reply with quote
Gary
My airport is AZ05. Gila Bend AZ. I will not be there until November with N123WL. Hope to finish build by end of June.  My wife and I are in Shelbyville,TN for summer and it is very HOT.
Wayne
Gary
PostPosted: Sun Jun 08, 2008 3:55 am    Post subject: Thoughts on new wingtips? Reply with quote
Selwyn basically pointed out the reasoning. With a very low cruise altitude it probably wouldn't do much, but an extra foot or so on the end of the wing will not add too much drag. If the upswept does anything it will help not only to counteract any loss of performance due to drag, but also act as if it were an even longer span wing. I am encouraged by no perceived loss of roll. If you want to see an example of a wing that was made longer and increased cruise speed just go to the Smithsonian.  Howard Hughes racer had two sets of wings. The clipped set was for low altitude straight line speed and the longer wings were for cross country cruise performance. The decrease in wing loading helps with fuel consumption as well. Brian W.
Date: Sat, 7 Jun 2008 20:33:55 -0700
To: lightning-list(at)matronics.com
--> Lightning-List message posted by: "selwyn" <selwyn(at)ellisworks.com.au>
[quote
Hmmm,
Rick
N727RB
/quote
Cheers.
http://forums.matronics.com/viewtopic.php?p=186749#186749
&g============
pennington(at)q.com
PostPosted: Sun Jun 08, 2008 4:53 am    Post subject: Thoughts on new wingtips? Reply with quote
I know what you mean about hot. As you know, Tucson, (and Gila Bend), are hot too.
I have flown over to Gila Bend a couple times. Very little air traffic from Tucson.
My kit will ship by the end of June. I've got a long way to go.
Have fun with the build. I look forward to seeing photos.
Gary
landonp(at)bigpond.com
PostPosted: Mon Jun 09, 2008 12:25 am    Post subject: Thoughts on new wingtips? Reply with quote
Hi Brian
They definitely improve looks, but before I order I need to know more about? e.g attachment - Is it as per original ? With extra wing loading will that be sufficient (if the same)? Additional weight ? What are key benefits or detriments ? Pricing ? Can I trade non fitted ,originals in? Does strobe kit fit these ?
BK
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
