davemader(at)bresnan.net Guest
Posted: Sun Mar 05, 2006 10:10 am Post subject: leaking fuel pump overflow |
Can anybody tell me. I have approx. 50 hrs on a rebuilt 0-360
Lyc. on my RV-6. When I look at the belly after a few flying
sessions there is a small dark brown streak coming from the overflow
tube extending out about 1-2 inches. Must be fuel because of no other
liquids in this area. My fuel pump does vary anywhere from 2 to 5 lbs.
Should I be concerned?
Dave Mader
50 hrs, RV-6
denis.walsh(at)comcast.ne Guest
Posted: Sun Mar 05, 2006 1:14 pm Post subject: leaking fuel pump overflow |
Tell us what the overflow tube is.
If it is the vent tube from the engine driven fuel pump on a low
pressure system it should not have anything coming out of it. If
something is coming out of it you should be concerned.
My fuel stains turn brown after a period of time. Not sure why but
presume it is lead from all that stuff in 100LL.
Denis Walsh
On Mar 5, 2006, at 11:05 AM, DAVE MADER wrote:
lbs.
Dave Mader
50 hrs, RV-6
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Sun Mar 05, 2006 9:03 pm Post subject: leaking fuel pump overflow |
Hi Dave,
I have not seen a response to your email, so:
You might have a slight amount of crank case fluids due to a leak around the
area where the actuating arm reaches into the accessory case.
The pump is designed so that if one of the diaphragms fails the leaked fuel
will exit via the overflow fitting and out the tubing you describe instead
of running into the crankcase. I probably don't need to tell you that fuel
getting into the crankcase can be very dangerous. We are talking potentially
lethal.
It's a total guess on my part that crankcase fluids might be the culprit. I
am basing this guess on the "dark brown streak" that you describe.
A call to a trusted AME or engine shop might provide some good information.
Others on the list could have good advise.
Let us know how it goes,
Jim
_________________ "I never make mistreaks" |
bicyclop(at)pacbell.net Guest
Posted: Sun Mar 05, 2006 9:26 pm Post subject: leaking fuel pump overflow |
Don't some bushplanes like beavers and such have a system to pump fuel
into the oil to thin it for cold starts? It then boils off as the engine
warms up and the oil becomes viscous again.
Pax,
Ed Holyoke
khorton01(at)rogers.com Guest
Posted: Mon Mar 06, 2006 3:04 am Post subject: leaking fuel pump overflow |
Yes, but that system only has fuel going into the oil when commanded,
and they have to follow a specific warm up procedure to be sure all
the fuel is boiled off before they use high power. This is
completely different from a leak in a fuel pump which could put fuel
into the oil continuously.
Kevin Horton
engine
Pax,
Ed Holyoke
Posted: Mon Mar 06, 2006 12:41 pm Post subject: leaking fuel pump overflow |
Jim
It was my understanding that this overflow would dump fuel overboard
instead of into the crankcase. So, I guess that the only thing I thought you
would get from this tube would be fuel if the diaphragm leaks. How would
crankcase fluids get into this tube?....are you saying the diaphragm might'
have a leak or the mating surface between the pump and engine? I am just
trying to make sense of this since I have never had a fuel pump apart and
can't visualize it.
Dave Mader
On Sun, 5 Mar 2006 20:59:52 -0800
"Jim Jewell" <jjewell(at)telus.net> wrote:
Hi Dave,
lethal.
Jim
Posted: Mon Mar 06, 2006 9:13 pm Post subject: leaking fuel pump overflow |
Makes sense,
Ed
