speckter(at)comcast.net Guest
Posted: Wed Mar 08, 2006 9:32 am Post subject: Fuel Filter Location |
I had my filter backordered from Van's. That gave me time to think. (never
a good idea) Is the location in the tunnel a problem for maintanance? I
would think that it would be better on the firewall with a heat shield
around it. Comments
Gary 40276
rv10es(at)earthlink.net Guest
Posted: Wed Mar 08, 2006 11:30 am Post subject: Fuel Filter Location |
The filter and the pump come pre assembled as a unit. Yes, I think
that it is not in an ideal location for maintenance but you will have
less chance of vapor lock also.
rob kermanj
On Mar 8, 2006, at 12:30 PM, Gary Specketer wrote:
<speckter(at)comcast.net>
think. (never
maintanance? I
around it. Comments
Gary 40276
Posted: Wed Mar 08, 2006 1:55 pm Post subject: Fuel Filter Location |
Mine did not come with the filter. In fact when I ordered it it took 3
people to figure out what to send me. They had no clue what the RV10 uses.
Does that filter disassemble for cleaning, or replace filter unit or what?
Gary
Posted: Wed Mar 08, 2006 4:06 pm Post subject: Fuel Filter Location |
I have not taken it apart but it will open with a wrench. Did you
not order it from van? I was wrong, The filter comes separate, it is
the pump and the check valve that comes together.
rob kermanj
took 3
RV10 uses.
or what?
Gary
