yak52
Posted: Wed Jun 04, 2008 5:01 am Post subject: Zenith Builder |
Do you fit this profile?
1. I'm not an aeronautical engineer, but I read alot about crashes in other types of high speed, pressurized airplanes built 30 to fifty years ago and interpolate from that to this airplane.
2. I change the thickness of the metal in one or more parts of the airplane without consideration of the distribution of the stress loads to other parts of the airplane.
3. I add doublers to various parts of the airframe also without structural analysis.
4. I buy materials for construction, sometimes from foreign countries to save a buck- without getting certifications that the materials meet the standards.
5. I change the materials from 6061 to 2024 or some other alloy without getting information as to the appropriateness of that alloy in that part being verified.
6. I don't care what the airplane is designed for- I'm going to " yank and bank" because I could have done what Chuck Yeager did if only I had the chance. My only flight time was in a 152.
7. My medical expired 7-8 years ago.
8. My plane hasn't been finished although I've been working on it for 5+ years. I just keep on making changes to make it better and keep me from ever having to actually fly it.
9. I'm sure I "know" more than the designer, who is fat or lazy or incompetent and is trying to hide his mistakes by refusing to help in the accident investigation and nothing, including the facts is going to dissuade me from that knowledge. Plus, I called them once and they didn't get back to me within 30 minutes and I won't stand for being "dissed" by anybody.
10. I'm sure the FAA and NTSB are fat, lazy and incompetent and really don't care about these accidents which are surely caused by some design error and/or are in league with the designer or some tri-lateral commission to steal our precious freedoms or drain our precious bodily fluids.
11. I intend to make significant changes to the control surfaces based on a book I partially read once.
12. I never intend to go back and check the torque on bolts or cable tensions once the airplane is completed.
13. Despite all this, I fully intend to blame the designer for any incident that happens anywhere in the world for any kit ot clone ever built by anyone.
Welcome to the group.
moorecomp
Posted: Wed Jun 04, 2008 6:50 am Post subject: Re: Zenith Builder |
"Me Thinks Thou Doth Protest Too Much"
Craig Moore A&P
Mancelona, MI
Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Wed Jun 04, 2008 8:27 am Post subject: Zenith Builder |
Subject: Zenith Builder
To: "zenith-list(at)matronics.com" <zenith-list(at)matronics.com>
Date: Wednesday, June 4, 2008, 7:56 AM
| Quote: | Do you fit this profile?
4. I buy materials for construction, sometimes from foreign countries to save a buck- without getting certifications that the materials meet the standards." etc...etc.
Roger,
Can I make a suggestion to you? Try avoiding so much caffeine and back away from the computer for awhile. It might help your attitude and you won't "bounce" as much. It helped me.....
regards,
Larry H
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
japhillipsga(at)aol.com Guest
Posted: Wed Jun 04, 2008 9:55 am Post subject: Zenith Builder |
no.
Scotsman
Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
Posted: Thu Jun 05, 2008 5:47 am Post subject: Re: Zenith Builder |
Does this come naturally to you....if so seek help.
jshep00(at)centurytel.net Guest
Posted: Fri Jun 06, 2008 5:40 pm Post subject: Zenith Builder |
I complain about every thing but have no Ideas of my own.
Even though I know that al least 6 601's have had fatal crashes, 2 with the skins coming off and at least 2 with the lower spar cap failing, I feel the airplane is just fine and it always happens to someone else.
Even though the plans I bought show +6 and _6 "G"s I don't think there are any problems now that the designer has changed the -"G"s to -3 and reccomended a limit to the elevator - travel which may be a problem if your CG is not quite perfect.
Get the picture??? Think about it!!!!
This designer needs to step up to the plate and let those of us that are building according to his plans just what area of his design is prone to failure before his published and sold +6 -6 "G"s. and how to remedy the problem!!
I don't fit all of your criteria, and I have talked to Chris on many occasions about the changes to his design I have made. Some are just common sense.
PS Neither the skins or the wings on our 601 will come off...Something else will fail first.
agibeaut
Posted: Fri Jun 06, 2008 6:35 pm Post subject: Zenith Builder |
Sorry Jerry, you lost me with your innuendo based, quasi-logic.
--- On Fri, 6/6/08, Jerry Shepard <jshep00(at)centurytel.net> wrote:
[quote] From: Jerry Shepard <jshep00(at)centurytel.net>
Subject: Re: Zenith Builder
Date: Friday, June 6, 2008, 8:37 PM
problem!!
Posted: Fri Jun 06, 2008 6:50 pm Post subject: Zenith Builder |
we all have an adgenda,---- or do we????
Andrewlieser
Posted: Fri Jun 06, 2008 7:53 pm Post subject: Re: Zenith Builder |
Interesting side note; I previously owned a set of Sonex plans (set 929 dated prior to sport pilot licensing) and that design was rated at +6 /-6 in the aerobatic category and +6 /-3 in the utility category. A quick check of their website and it now shows +4.4 /-2.2 in the utility and +6/-3 in the aerobatic loading category. This makes me think that maybe manufacturers are getting a little more cautious since the sport pilot licensing began and would appear that this is not just a Zenith problem but rather all manufacturers are scared by less experienced pilots over controlling their designs. Just an FYI
_________________ Andrew Lieser
S/N 6-7045
http://websites.expercraft.com/andrewlieser |
eldenej(at)yahoo.com Guest
Posted: Sat Jun 07, 2008 7:33 am Post subject: Zenith Builder |
Jerry,
Let me ask that you elaborate on "the changes to his design I have made..." that will insure that "neither the skins or the wings on our 601 will come off."
Elden J. (do no archive)
--- On Sat, 6/7/08, Jerry Shepard <jshep00(at)centurytel.net> wrote:
[quote]From: Jerry Shepard <jshep00(at)centurytel.net>
Date: Saturday, June 7, 2008, 9:37 AM
d.goddard(at)ns.sympatico Guest
Posted: Sat Jun 07, 2008 8:19 am Post subject: Zenith Builder |
Perhaps given the current climate it would be best if you did that offline. While I have no doubt improvements are possible, the very notion appears to create a lot of acrimony
Posted: Sat Jun 07, 2008 9:18 am Post subject: Zenith Builder |
Dave,
Your point is a good one; I will do that.
Elden J.
--- On Sun, 6/8/08, Dave G. <d.goddard(at)ns.sympatico.ca> wrote:
[quote]From: Dave G. <d.goddard(at)ns.sympatico.ca>
Date: Sunday, June 8, 2008, 12:16 AM
Yak52(at)aol.com Guest
Posted: Sun Jun 08, 2008 5:06 am Post subject: Zenith Builder |
The +6-6 was ultimate load.
If you have made changes that will insure that the wings do not come off, I'm sure everyone agrees that you should keep it a secret. After all, only the "enlightened" should be saved; and you can gleefully count the crashes of those who didn't come to worship at your throne. More importantly, without that information, your changes can never be examined, unlike Mr. Heintz who is under perpetual scrutiny and criticism by members of this group. .
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
