pdeits(at)comcast.net Guest
Posted: Sun Mar 05, 2006 11:25 am Post subject: E-mag/P-Mag |
Planning to go with this ignition system. They allow the choice of either aviation or automotive style plugs.
Price aside, what is recommended and why?
Vanremog(at)aol.com Guest
Posted: Sun Mar 05, 2006 5:49 pm Post subject: E-mag/P-Mag |
In a message dated 3/5/2006 11:29:35 A.M. Pacific Standard Time,
pdeits(at)comcast.net writes:
I wish you better luck than I had with this system. Are you planning to
keep one mag?
GV (RV-6A N1GV O-360-A1A, C/S, Flying 774hrs, Silicon Valley, CA)
jabowenjr(at)hotmail.com Guest
Posted: Sun Mar 05, 2006 6:17 pm Post subject: E-mag/P-Mag |
Can you tell us a little more about the Emag/Pmag bad luck you had. I am
also considering this option. Thanks for the info.
Jim Bowen
RV-8
| Quote: | From: Vanremog(at)aol.com
Reply-To: rv-list(at)matronics.com
Subject: Re: E-mag/P-Mag
Date: Sun, 5 Mar 2006 20:46:06 EST
keep one mag?
flyeyes(at)mac.com Guest
Posted: Sun Mar 05, 2006 6:30 pm Post subject: E-mag/P-Mag |
On Mar 5, 2006, at 1:21 PM, D Paul Deits wrote:
I'm not sure anybody really knows the answer to this, although there
appears to be anecdotal evidence on both sides.
I'm currently running one E-mag with auto plugs, and a Bendix Mag
with aircraft plugs. I originally had aircraft plugs on the E-mag,
but changed them out after talking to all the pretty much everybody I
could at Oshkosh. I switched because I didn't see a good way to open
the gap on aircraft plugs to the recommended larger gap with the
electronic ignition.
The engine may have gotten a little smoother with the auto plugs,
but that may be my active imagination. There was no measurable
change in performance with the switch between plugs.
The engine is noticeably smoother and has noticeably more power on
the E-mag alone than the mag alone when you cycle the switches in
flight at cruise settings.
I'm planning to replace the left Bendix mag with a P-mag at the
annual. I will probably leave the aircraft plugs in place for at
least a while, so I have a direct comparison. Long term, unless I
notice a performance difference or have service issues, I'm planning
to go with the auto plugs.
James Freeman
martin(at)gbonline.com Guest
Posted: Sun Mar 05, 2006 7:07 pm Post subject: E-mag/P-Mag |
Lightspeed is better. Most of the racers use Lightspeed
Call Klaus Savior at Lightspeed Ign for details.
Dick Martin
N233M RV8
the Fast one
Paul,
The choice of aircraft or auto plugs is determined by the type of ign wire
you use. If you use the 8 1/2 mm MSD auto racing wire the auto plugs are im
my opinionsuperior. I have a lightspeed dual ign and am happy with it . It
is far superior to any other ign that I have experience with. The
lightspeed delliversa full40 thousand plus volt full capacitance discharge
system, whereas the others are usually 20 or 30 thousand volt inductive
inductive systems. The difference being a lower charge as well as the
ability to precisely time the spark as well the duration and intensity of
the spark as provided by the Lightspeed ign. The Lightspeed costs more but
in the long run, works better. Most of the racers use Lightspeed. Contact
Klaus Savior of Lightspeed for details.
Dick Martin
RV8 N233M
the fast one
dsvs(at)comcast.net Guest
Posted: Sun Mar 05, 2006 7:27 pm Post subject: E-mag/P-Mag |
Posted: Sun Mar 05, 2006 8:17 pm Post subject: E-mag/P-Mag |
In a message dated 3/5/2006 6:18:24 P.M. Pacific Standard Time,
jabowenjr(at)hotmail.com writes:
Once again I have offered to discuss only with those who contact or call me
directly.
Posted: Mon Mar 06, 2006 5:37 pm Post subject: E-mag/P-Mag |
