Issues you encountered during initial flights of y...
NYTerminat(at)aol.com
PostPosted: Sun Jun 01, 2008 5:52 pm    Post subject: Issues you encountered during initial flights of y... Reply with quote
Ralph,
That was a great video. I concur that depending on what you are used to flying it is initially pitch sensitive.
To Kevin my experience was a heavy left wing and a drop in landing for my first flight.
You should definitely get some dual time in a 701, biggest difference to me was the fast sink rate at slow speed and reduced throttle. As a big plus is the quick response when you add the throttle. It just takes some time to become one with the 701. Great STOL performance and I love it more each flight.
Bob Spudis
N701ZX/ 150HRS/ 912ULS
In a message dated 6/1/2008 6:44:37 P.M. Eastern Daylight Time, sanson.r(at)xtra.co.nz writes:
--> Zenith701801-List message posted by: "jetboy" <sanson.r(at)xtra.co.nz>
For me the pitch nose up change at takeoff and power setting vs. elevator authority on landing had to be learned with anticipation. This is a designed in effect of having the high mounted elevator to make use of the propwash and I don't consider it a problem just a factor to be ready for. Its very forgiving even in one of my dumber moments lifting off in a quartering tailwind before I had rudder control I kept the nose low while being drifted towards the fence until proper flying speed was there.
The best first flight video is here. Non 701 pilots may need counseling to watch. Its a reasonably accurate representation of the direct handling available.
http://youtube.com/watch?v=GHFfkxNy7Co
Ralph
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
