rflick(at)ovalinternet.ne Guest
Posted: Fri May 16, 2008 6:36 am Post subject: NSI parts |
hi. i am looking for an oil cooler set up for the NSI subaru. thanks ralph
kitfox(at)ida.net Guest
Posted: Fri May 16, 2008 7:04 am Post subject: NSI parts |
Hey Ralph
I think you will have to assemble your own system.
http://www.bakerprecision.com/hose.htm These guys have about all that you will need. I used all Aeroquip piping parts and fittings. They have less expensive copys for automotive. I would stay away from them. I put a remote oil filter adapter on. Had to get a new attachment nut made for more thread engagement. Mounted the oilfilter on the firewall. It uses small block Chev screw on filters and has a port for an oil temp probe. The radiator brand I can not remember. It was used on factory install for turbo Porshe.
Albert
MudLake, Id
5TD NSIT, CAP140
wingsdown(at)verizon.net Guest
Posted: Fri May 23, 2008 7:51 am Post subject: NSI parts |
If it is not turbo you can go to a smaller unit but here is a pic of how I did mine. I highly recommend the thermostat by pass unit. I have seen the coolers mounted on top as well, think John Anderson did it that way. May be some old shots stored. I don't have the cooler but I still have the breathers and some other NSI related gear to include a turbo block prepared by RAM.
Rick
360.8 KB |
313 Time(s) |
