Mike Whisky
Posted: Sat May 17, 2008 10:38 am Post subject: Ignition Cable clamp |
Who knows where I can get two of these ignition cable clamps (for three cables)!
Michael
Zuerich, Switzerland
103 KB |
398 Time(s) |
_________________ RV-10 builder (flying)
#511 |
Posted: Sat May 17, 2008 11:01 am Post subject: Ignition Cable clamp |
I don't know a source, but you can take a plain ADEL clamp (a 1 1/4"
should do it) and remove the rubber part. Put a screw through the hole
and tighten up a nut. Place a 3/8" thick piece of 'something' in the
clamp and squeeze in a vise to make the clamp oblong. Replace the
rubber part and you should have a usable clamp.
Linn
Michael Wellenzohn wrote:
Albert Gardner
Posted: Sat May 17, 2008 11:55 am Post subject: Ignition Cable clamp |
Are you thinking of the Engine Baffle Ignition Wire Seals like on aircraft
Spruce cat/ page 272? Or something else?
Albert Gardner
Yuma, AZ
RV-10 N991RV |
Posted: Sat May 17, 2008 5:52 pm Post subject: Ignition Cable clamp |
Duh!!! Good question!!!! If he is looking for the baffle feed-through
clamps ..... makes my suggestion seem pretty stupid!!!
But then again, if someone is looking for ignition clamps that attach to
the valve covers ..... Bingo!!!
Linn
do not archive!!
Albert Gardner
Yuma, AZ
Mike Whisky
Posted: Sun May 18, 2008 1:37 am Post subject: Re: Ignition Cable clamp |
Linn,
I I am looking for the ignition clamps that attach to
the valve covers as you said the Adel Clamp modification is one way. However I wonder if there are the clamps for one and for two cables there must be also some out there for three did all six cylinder engine owners manufacture them themselves?
Michael
#511 |
Posted: Sun May 18, 2008 5:37 am Post subject: Ignition Cable clamp |
Linn,
Another good question!!!! Most all engines come with an ignition
harness and those clamps, and I've seen clamps that were pretty ragged
..... even missing the plastic and they put electricians tape on the
wires for anti-chafe!!! If you really want the 'real' clamps, then I'd
start looking at the magneto manufacturers themselves. I have a
downloaded Aircraft Spruce catalog on my workshop computer, but can't
get it to download on this one. The clamps may be available thru Spruce
...send them an email. I suspect that with a long ..... really long
... distance phone call and shipping it may be easier for you to make
your own.
Linn
