Posted: Mon May 19, 2008 2:05 pm Post subject: FireFly Landing Gear Leg Strength Improvement |
At 10:02 PM 10/6/07 -0500, you wrote:
| Quote: | FireFlyer's
| Quote: | I looked at attaching a 1/8 inch diameter cable to the axle to leg
attachment bolt and running it to either the leg attachment bolt in the cage
or to the opposite leg just below the socket. By doing this, the 1.8G
improved to 3.9G for the leg attachment bolt, and to 5.2G when connecting to
the top of the opposite leg just below the socket.
This may be a good low cost and light weight improvement. More about how
these numbers were calculated can be seen at:
http://www.thirdshift.com/jack/firefly/firefly134.html
When, I get the parts fabricated and installed, I will put up another page.
FireFlyer's,
I finished putting it on today. How it was done can be seen at:
http://www.thirdshift.com/jack/firefly/firefly140.html
I used a loop of 3/32 inch OD diameter cable as it turned out to be the same
strength as a single strand of 1/8 inch cable, but required few parts. The
trick was to figure out how to properly pretension the cable. The total
added weight was five ounces. Tomorrow if the weather is ok, I hope to see
how it reacts to the 681 takeoff and landing.
Jack B. Hart FF004
Winchester, IN
Posted: Mon May 19, 2008 3:35 pm Post subject: FireFly Landing Gear Leg Strength Improvement |
Jack, are the cables supposed to stretch somehow? If not, haven't
you lost any
bounce/terrain suppression the gear were supposed to have?
Maybe big bungees?
Now if you had a rod pushing down at the intersection of the cables,
attached to a coil spring
inboard?...........
BB
On 19, May 2008, at 7:02 PM, Jack B. Hart wrote:
<jbhart(at)onlyinternet.net>
> FireFlyer's
> in the cage
> 1.8G
> connecting to
> about how
> another page.
FireFlyer's,
the same
parts. The
total
hope to see
Jack B. Hart FF004
Winchester, IN
