		1rv4
				 Posted: Mon May 12, 2008 5:48 am    Post subject: Gearleg fairings |
				An update on the trim problem I am having with the gearleg fairings. I re
 rigged the port fairing, by digging out all the foam and refoaming top and
 bottom. I moved the gearleg fairing ,trailing edge outboard, by 3/16 of an
 inch at the top and an 1/8 at the bottom, now the ball is less than one
 width out at full throttle. It didn't take much change in the fairing to
 make a big difference in the trim.. Milt suggested I jack the plane up to
 take the weight off before setting the final angle, but I don't really have
 the facilities to get the legs hanging like that.. I did try to make the
 fairings teardrop shaped when I glassed the trailing edge together, and
 looking carefully at the final result they didn't hold a consistent shape
 top to bottom, so maybe its acting like an airfoil and not only causing drag
 but setting up a sideways pressure also. (Just a theory).
                    Thanks for all the help, what an awesome aircraft!
        Chris
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		nico(at)cybersuperstore.c Guest
				 Posted: Mon May 12, 2008 6:37 am    Post subject: Gearleg fairings |
				Do you see a difference in speed with the fairings and wheel pants fitted?
